Buy EcoFlow Wave Portable Air Conditioner - Default Title
EcoFlow CA
$1,499.00 CAD
Regular price $1,499.00 CAD
Sale price $1,499.00 CAD Regular price $1,499.00
-$0
Fast cooling: With 4000BTUs, Wave can cool your tent, RV, or small to medium space in 8 minutes flat. That's the fastest for its size.
Extended runtimes: Get 3hrs of cooling with the add-on battery. Extend to 8 hours with timed mode to keep you cool all night long by auto alternating between cooling and fan settings.
Cool your way: Use the 1008Wh Add-On Battery, DELTA Max, or DELTA Pro for an extra runtime of up to 12 hours without plugging into an AC outlet. Plug into an AC outlet for cooling without a battery.
Charge anywhere:  Wall outlets, solar, car or even portable power station charging mean you've always got cooling when you need it.
Notes:
*If you want to power your AC with DELTA Pro or DELTA Pro Smart Extra Battery, please purchase DELTA Max Extra Battery Cable and DELTA Pro to Smart Generator Adaptor separately. Then you could conect them with your AC.
*If you want to power your AC with DELTA Max or DELTA Max Smart Extra Battery, please purchase DELTA Max Extra Battery Cable. Then you could conect it with your AC.
$1,499 CAD
The fastest cooling.
The longest running time.
Sustainable charging.
Smart controls & customization.
Wave Portable Air Conditioner Specs
Net weight
38.58 lbs
20.39 x 12.2 x 16.38 in
Wi-Fi
Supported
Bluetooth
Supported
AC input voltage/frequency
115V 60Hz
AC input power
Max 700W
Add-On Battery power
Max 600W
Solar charging input
11-35V Max 12A Max 200W
Car charging input
12 V/24V Max 8A Max 200W
Ambient temperature
5°C ~ 50°C (41°F ~ 122°F)
Cooling temperature settings
16°C ~ 30°C (60.8°F ~ 86°F)
Cooling capacity
1200W
Circulation air volume
290m"3"/h
Refrigerant/amount
R134a/14.1oz
Rated cooling power (AC/DC)
460W/410W
Max. cooling power
600W
Noise
<55dB
No-Drain Function
Supported
Shut Down When Full Function
Supported
Wave Add-on Battery Specs
Net weight
17.4lb
1008Wh
Terms & Conditions
1. The Pre-order campaign starts from May 12th to June 13th, 2022, PST.
2. The Pre-order campaign only applies in Canada and the United States.
3. There are three prices for each bundle (Super-early bird, early bird, and pre-order). Each price is subject to a quantity limit. Therefore, a price match guarantee is not provided.
4. The shipment of DELTA Pro/DELTA Max(2000) will be scheduled once they are in stock.
    The shipment of AC/AC extra battery/accessories will be scheduled in late June.
5. If you have any questions, please contact our Aftersales Service team at support@ecoflow.com
6. AC/AC extra battery/accessories come with a 12-month limited warranty counting from when you receive the physical goods. For more details about the warranty, please check the EcoFlow Warranty Policy Page.
7. After pre-ordering, you can request a full refund as long as the item has not been shipped. If you return your order within 30 days of receiving purchased items without any reason, we'll charge the initial transaction fee and shipping cost. To learn more about our Return & Refund Policy, please check here.
