EcoFlow DELTA 2 + 2*110W Solar Panel + 800W Alternator Charger - EcoFlow DELTA 2 + 2*110W Solar Panel + 800W Alternator Charger
EcoFlow CA
$1,899.00 CAD
Write a review
Regular price $1,899.00 CAD
Sale price $1,899.00 CAD Regular price $2,996.00
-$1,097
Up to EcoCredits for cash deduction. Log in
$1,899 CAD $2,996 -$1,097
EcoFlow DELTA 2 Solar Generator is a must-have for any home that puts power security & comfort first. Ensure you're prepared with the power station made for almost any situation your family could find themselves in. All while staying green.
Make it a triple.
Expand capacity.
With a capacity of 1kWh to start with, you've got enough energy for your essentials for hours on end. Need even more? Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
Optimize your energy.
X-Stream tech means you can charge from 0%-80% in 50 mins,or 0-100% in 80 minutes with AC input, that's faster than you'll pack your trunk for the next road trip. Pair with solar panels and charge in as fast as 3-6 hours. With its MPPT (Maximum Power Point Tracking) smart algorithm, DELTA 2 can actively detect the voltage and current in real-time to reach the maximum power point with >98% efficiency.
Charge faster,
wherever you go.
A single portable solar panel with a unique folding design, our 110W portable solar panel combines powerful energy production with portability. To achieve a higher solar conversion efficiency of up to 23%, we use multi busbar monocrystalline cells, so you get even more energy to recharge your portable power station.
Built to last 6x longer.
Power pretty much anything.
A 1800W AC output means you can power more than 90% of your home appliances. That's your microwave, fridge, or even coffee maker covered in a blackout. Or, try plugging in up to 15 devices at once for when you're around the table with the family. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2400W thanks to X-Boost technology.
Control, monitor,
and manage your energy use.
Take solar power on the go.
EcoFlow's 110W portable solar panel is a camping or RV must-have. The compact design saves valuable space for your other travel essentials. When you're ready to head off on your next adventure, simply collapse the panel down to store in your van or car.
1. DELTA 2 2.AC Charging Cable3. Car charging cable 4. DC5521 to DC5525 cable 5.User Manual6. App quick start guide 7. Warranty card 8. 110w Portable Solar Panel
*The solar to XT60 charging cable is included in EcoFlow portable solar panels.
Specs of DELTA 2
1024 Wh
Extra Battery
6 outlets, 1800W total (Surge 2700W)
2200W
2 ports, 5V, 2.4A, 12W Max
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A, 38W Max
AC Charging
1200W
11-60V, 15A, 500W max
Car Charging
Support 12V/24V battery, 8A
Smart Genertaor Charging (DC)
1100W
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
27 lbs / 12 kg
Specs of 110W Solar Panel
Unfolded Dimensions
20.2*62.5*0.8 in /178.5*42.0*2.5cm
Folded Dimensions
20.2*16.5*0.8 in/42.0 x 48.0 x 2.5cm
Weight
8.8lb (4kg)
12 months
Rated Power
110W (±5W)
Efficiency
22%–23%
Connector Type
Solar Connector
Open Circuit Voltage
21.8V (Vmp 18.4V)
Short Circuit Current
6.5A (Imp 6.0A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−4°F to 185°F
