Buy EcoFlow DELTA Pro Portable Power Station - 2*DELTA Pro + Double Voltage Hub
EcoFlow DELTA Pro + Double Voltage Hub
1 Review
Regular price $6,100.00 CAD
Sale price $6,100.00 CAD Regular price $8,998.00
-$2,898
  • Installation-free Forget expensive and complicated systems, it’s easier than ever to prepare for blackouts with a plug-and-play design. Simply connect to your breaker panel via a power inlet box or transfer switch for instant home backup.
  • Clean home backup alternativeExchange noisy, high-maintenance gas generators for quiet and reliable home backup and convenient EV charging.
  • Power almost everything | Already have two DELTA Pros? Get an extra Double Voltage Hub now and pair two units to hit the massive 7200W and 240V output to power your entire home, including high-wattage ones.
  • Up to 1 week of power Expandable capacity from 7.2 to 21.6 kWh with extra batteries, store energy and keep your critical circuits running for up to a week.
  • Fast recharging between outages With the signature X-Stream technology, ideal for fast charging between short outages.
Note:
1. 1x 1.5m NEMA L14-30P to L14-30R cable is included in this bundle to hook up the Double Voltage Hub into your home’s power inlet box.
2. The Double Voltage Hub requires two EcoFlow DELTA Pro units.
$6,100 CAD $8,998 -$2,898
⚠️ Firmware Update Required for 1T2 Accessory
To use the 1T2 accessory properly, all compatible main units must be updated to the latest firmware version. Without the required firmware, you may experience operational issues.
Required firmware versions:
  • DELTA 3 Max Plus: v7.80.98.44 or above
  • DELTA 3 Ultra Plus: v7.80.98.46 or above
If you have not received the firmware update, please contact our customer support team to have it pushed to your device. To complete the upgrade, connect each EB to the main unit separately — the process requires two separate upgrades. Once both upgrades are complete, the 1T2 accessory will function normally.
Simple, sustainable, and affordable whole-home backup power solutions with an output power of up to 7200W and a whopping 21.6kWh capacity for security and comfort. Easily chain together two
A clean power alternative
Replace noisy, smoky generators with a silent and fume-free portable home battery solution. Unlike generators, these batteries are flexible to use both outdoors and indoors to run all your essentials during a blackout. And, with the help of solar energy, they can easily be recharged during an extended outage.
Power your entire home with 240V and 7200W
Battery backup has never offered this kind of output. The Double Voltage Hub doubles the AC output to 7200W and 240V, so you can run 99% of all home appliances, including high-wattage ones like a clothes dryer or electric heater. Note: The Double Voltage Hub requires two EcoFlow DELTA Pro units.
Expands from 7.2-21.6kWh
With DELTA Pro’s expandable capacity, enjoy peace of mind and prepare your home with up to 1 week of essential energy storage with Extra Batteries. Expand your ecosystem and get limitless energy with solar panels and duel-fuel smart generators.
Recharge your EV anytime, anywhere.
Keep going for miles when your electric vehicle runs out of battery. Either at home or on the go, DELTA Pro will have you back on the road in no time.
Select your language
