EcoFlow Solar to Low-PV Port Charging Cable (EcoFlow DELTA Pro Ultra)
Write a review
Regular price $89.00 CAD
Sale price $89.00 CAD Regular price $89.00
-$0
Connect a solar panel to EcoFlow DELTA Pro Ultra for clean, efficient, and reliable energy.
Highlights
The EcoFlow Solar to Low-PV Port Charging Cable (EcoFlow DELTA Pro Ultra) allows you to connect an EcoFlow portable power station to a solar panel, and is compatible with EcoFlow DELTA Pro Ultra.
Specifications
Length: 8.2 ft (2.5 m)
Cable Type: CP30 Connector & Photovoltaic connector
$89 CAD
⚠️ Firmware Update Required for 1T2 Accessory
To use the 1T2 accessory properly, all compatible main units must be updated to the latest firmware version. Without the required firmware, you may experience operational issues.
Required firmware versions:
  • DELTA 3 Max Plus: v7.80.98.44 or above
  • DELTA 3 Ultra Plus: v7.80.98.46 or above
If you have not received the firmware update, please contact our customer support team to have it pushed to your device. To complete the upgrade, connect each EB to the main unit separately — the process requires two separate upgrades. Once both upgrades are complete, the 1T2 accessory will function normally.
Select your language
