EcoFlow Smart Generator 4000 (Dual Fuel) EcoFlow Smart Generator 4000 (Dual Fuel) EcoFlow Smart Generator 4000 (Dual Fuel)
$5,298.00 CAD
Regular price $5,298.00 CAD
Sale price $5,298.00 CAD Regular price $6,498.00
-$1,200
Only $1,949 for the Smart Generator 4000. Discount auto-applied at checkout.
- Dual Fuel: EPA version with LPG & gasoline.
- 4000W Peak AC Output
- 40% Higher Energy Efficiency
- 4 Modes of Self-starting
- App Control and Monitor
- 5 Safety Alerts
- Ergonomically Portable Design
- LCD HD Screen
Recommend
$5,298 CAD $6,498 -$1,200
Industry’s Fastest 3200W DC Fast Charging System
Higher efficiency, more reliable when connected with EcoFlow DELTA Pro 3
Unlock unmatched power and reliability with the EcoFlow Smart Generator 4000 (Dual Fuel) and EcoFlow DELTA Pro 3 hybrid setup. Featuring industry-leading 3200W DC fast charging and up to 40% improved efficiency, they excel in various scenarios, from backup power to on-the-go charging.
1
2
3
More Energy-Saving & Efficient
EcoFlow Smart Generator (Dual Fuel) 4000 not only offers significant fuel savings but also generates fewer emissions. Compared to traditional fuel generators, it can save 40% of fuel when fully charging EcoFlow DELTA Pro 3. This means that with the same 1 gallon of fuel, this smart generator provides 1kWh more power.
Power Backup Made Smart and Simple
With four intelligent self-starting backup modes (when paired with EcoFlow DELTA Pro 3), power backup has never been easier.
Customizable start/stop
Night-care mode
PV-priority mode
Smart reverse charging
At night, once the power consumption reaches a certain level, the smart generator will automatically start to replenish power, eliminating the need to get up in the middle of the night to reset it.
Monitor the remaining power of the EcoFlow DELTA Pro 3 energy storage in real-time, predict future power consumption and measure the power generation from PV, and auto-recharge it in time to ensure a peaceful night's sleep and rest for your family and neighbors, avoiding noise during charging at night or during peak power consumption periods.
Recharge the EcoFlow DELTA Pro 3 with PV panels, automatically prioritizing PV charging for savings and environmental benefits while minimizing noise from continuous generator operation. Need more power quickly as an outage approaches? One tap in the EcoFlow app switches back to PV and Smart Generator charging combo for swift reinforcement.
It provides a reverse power supply to the generator battery through EcoFlow DELTA Pro 3 to wake up the generator and start charging it at the same time. Also, to prevent the Smart Generator battery failure caused by long-term storage or extremely low temperatures, it protects household electricity during severe weather scenarios.
Dual Fuel for Double Peace of Mind
Rest easy knowing that LPG and gasoline are readily accessible, ensuring you can quickly obtain fuel for backup power and alleviating concerns about fuel shortages during emergencies.
Gasoline Power
Propane Power
The smart engine produces 8kWh in single gasoline tank, you could power your home appliances for 8-hours at 25% load.
Simply plug in a 20lb propone tank and allow you access to a 24kWh power, secured and keep your family a whole day of cozy life in a outage.
Control from Anywhere with Just One Tap
Use the EcoFlow app to monitor and control energy consumption and equipment operation. Get real-time key alerts like CO concentration, high & low temperature warnings, etc., to ensure safety. View faults and maintenance prompts for easy upkeep.
Multiple Start/Stop Methods for Easy Operation
EcoFlow Smart Generator 4000 (Dual Fuel) offers intelligent and elegant start/stop methods for various scenarios, providing greater convenience.
5 Quick Start Methods
① Manual pulling cord start
② Electric button start
③ Reverse charging by portable power stations
④ App start (Bluetooth/Wi-Fi)
⑤ Scheduled automatic start.
6 Shutdown Methods
① Knob switch off
② One-click shutdown (electric button)
③ automatic shutdown
④ Scheduled-time shutdown
⑤ Low output shutdown*
⑥ App-controlled shutdown.
*When matched with a third-party portable power station, it automatically shuts down after the portable the power station is fully charged and a decrease in output power is detected.
Stay on Guard With Real-time Alerts
Receive 5 safety notifications directly through the EcoFlow app, ensuring remote or indoor users stay informed in real-time. All features(except fuel alerts) trigger automatic shutdowns to prioritize safety for you.
User-Friendly Design, Enhanced Portability
The ergonomic design with a built-in pull-rod allows easy transport from the garage or basement, making it simple to activate backup power. Its compact size ensures it doesn't take up too much space for storage and stays well-organized.
Generator Specs
83 lbs/38kg
24.9x15x20.8 in/633x381x529 mm
Type
Inverter Generator
Frequency
60Hz
Rated Voltage
120V
Rated Power
3200W with Gasoline, 2900W with LPG (4000W Peak Output with X-Boost Tech)
DC Output Voltage
40~60V
DC Current
56A max.
Engine Specs
Engine size
196cc
Type
Four-stroke
Fuel Type
Unleaded gasoline/LPG
Fuel Tank Capacity
6L / 1.58gal
Engine Oil Capacity
0.55L / 0.145gal
Noise Level (at 7m distance)
70 dB (full load)
Continuous Working Time (Gas)
2.8hr (full load), 8hr(1/4 load)
EcoFlow Smart Generator 4000 Compatibility
*Please note that EcoFlow Smart Generator 4000 is not compatible with Ecoflow Delta Pro Ultra/EcoFlow RIVER Series.
Compatibility here refers to the DC output charging and "automatic start-stop" function.
Thanks for sharing!
Select your language
