100% secure shopping
Reliable warranty
Free shipping
EcoFlow RIVER Pro + 110W Solar Panel
Regular price
$1,547.00
Sale
$1,547.00
Regular price
$1,849.00
Sold out
per
As low as $88/mo or 0% APR.
Number of Solar Panel
  • 1
  • 2
View cart
TO DOUBLE THE CAPACITY OF RIVER Pro,CLICK HERE RIVER Pro EXTRA BATTERY
The EcoFlow RIVER Pro is a compact, portable power station that is built for taking your adventure into the great outdoors. Whether you are camping, over-landing, tailgating, or boating, the RIVER Pro provides reliable power that lets you take your adventure anywhere.
  • 3 x 600W AC OUTLETS AND 720Wh CAPACITY
  • RECHARGE FROM 0-80% WITHIN 1 HOUR
  • DOUBLE CAPACITY FROM 720Wh to 1440Wh
  • POWER A WIDE RANGE OF APPLIANCES
Stay off the grid with EcoFlow 110W Solar Panel Charger. Made up of efficient monocrystalline silicon cells,  it can recharge DELTA and your electric devices, and keep your equipment running without interruption when connected to our portable power station.
  • COMPATIBLE WITH MOST GENERATORS
  • UPGRADE HIGH EFFICIENCY
  • PORTABLE & FOLDABLE KICKSTAND PANEL
Customer reviews
4.0 563 Reviews
  • 5 star
    75%
  • 4 star
    60%
  • 3 star
    10%
  • 2 star
    8%
  • 1 star
    1%
Reliable warranty
Free shipping
X-Boost Smart Algorithm
The EcoFlow X-Boost technology gives you the ability to use the 600W inverter to power essential devices like kitchen appliances and tools up to 1800W. This unique technology is perfect for outdoor adventures when you need to power your favorite devices on the go. Please conduct full test on a case-by-case basis to confirm the X-Boost feature works with your appliances. Use X-Boost with devices below 1200W for the best product experience.
Faster Recharging Speed
EcoFlow's X-Stream fast charge technology eliminates the need for carrying around bulky power adapters. The RIVER Pro supports AC charge input up to 660W and can charge from 0-80% within 1 hour, achieving a full charge in 1.6 hours.
Power that Grows with You
From a solo road trip to group camping, the RIVER Pro has expandable power that unleashes your weekend adventures. If you are planning on taking a long journey or have more power-heavy applications in mind, add the RIVER Pro Extra Battery to double the device capacity from 720Wh to 1440Wh.
3 AC Outlets
Step into the wild with complete peace of mind with the RIVER Pro. Whenever you are having a backyard adventure with the family or powering a completely off-grid adventure, the RIVER Pro powers essential appliances and devices.
Smart Solar Charging
The RIVER Pro can be charged with two 110W solar panels connected in parallel in 4.5 to 9 hours, which gives you the freedom to enjoy clean energy wherever you are.
Compact and Portable
Weighing just 15.9 lbs, the RIVER Pro features an easy-to-carry handle, which makes it portable and easy to transport. It can easily fit in a car trunk, on a campsite, or indoors, giving you the power to take your adventure anywhere.
Power a Wide Range of Devices
The RIVER Pro comes with three AC outlets. (Note that the total rated wattage of the three AC outlets is 600W (surge 1200W)). With a built-in 600W inverter, the RIVER Pro can power devices up to 1800W with the X-Boost mode on. This provides support for a wide range of essential devices such as a fridge, TV, laptop, hairdryer, and more.
Note: It is not recommended to use the RIVER series power station to power heavy-duty devices e.g., air conditioners, ovens or washing machines.
Warning: DO NOT use RIVER series portable power station AC charging cables on DELTA series power stations. EcoFlow takes no responsibilities for any damages caused by customers' failure to follow instructions. Doing so will void the warranty.
EcoFlow110W Solar Panel High Compatibility
Adjust the Kickstand of EcoFlow 110W Solar Panel
EcoFlow Solar Panel Waterprrof Design
How to Chain EcoFlow 110W Solar Panels
Solar Panel Connection Tutorial
What EcoFlow RIVER Pro Can Power?
*The duration and times of the appliances indicated in this table are for reference only.
With single 110W Solar panel, the charging time could be:
  • DELTA  16-32 hours
  • RIVER 370 5-10 hours
     *   Depending on the angel of panel and weather condition.
EcoFlow DELTA Power Station with 110W Solar Panel
Specifications of RIVER Pro
General Info
Net Weight*16.8 lbs (7.6kg)
Dimension*11.4 x 7.1 x 9.3 in (28.9 x 18.0 x 23.5 cm)
Charge Temperature32-113°F +/- 5°F (0-45°C +/- 3°C)
Discharge Temperature-4-113°F +/- 5°F (-20-45°C +/- 3°C)
Color Cyber Black
Warranty24 months
Charging
Charge MethodAC Wall Outlet, 12V Car Adaptor, Solar Panel
Full Recharge Time1.6 Hours (AC)
6.5 Hours (12/24V Car Adaptor)
4.5-9 Hours (Using 2x110W Solar Panels in parallel with full sun)
7.5-15 Hours (Using 1x160W Solar Panel with full sun)
Battery Info
Capacity720Wh (28.8V)
Cell ChemistryLithium-ion
Shelf Life1 year (after fully charged)
Cycle Life800 cycles to 80%+ capacity
Management SystemsBMS, Over Voltage Protection, Overload Protection,
Over Temperature Protection, Short Circuit Protection
Low Temperature Protection, Low Voltage Protection,
Overcurrent Protection
Testing and certificationUL Standard, CE, FCC, RoHS, RCM
Input Ports
AC Charge Input PowerX-Stream Charge 660W Max
AC Charge Input Voltage100-120Vac(50Hz/60Hz); International Version 220-240Vac(50Hz/60Hz)
Solar Charge Input200W 10-25Vdc 12A Max
Car Charger12Vdc 8A Max
Output Ports
AC Output (x3)600W (Surge 1200W) total,120Vac( 50Hz/60Hz)
USB-A Output (x2)5Vdc, 2.4A, 12W Max, per port
USB-A Fast Charge (x1)5Vdc, 9Vdc, 12Vdc, 2.4A, 28W Max
USB-C Output (x1)5Vdc, 9Vdc, 12Vdc, 15Vdc, 20Vdc, 5A, 100W Max
Car Power Output (x1) 136W, 13.6Vdc, 10A Max
DC5521 Output (x2)13.6Vdc, 3A Max, per port
Specifications of 110W Solar Panel
Unfolded Dimensions
20.2*62.5*1.0 in (51.4*158*2.4 cm)
Folded Dimensions
20.2*16.5*1.0 in  (51.4*42*2.4 cm)
Weight13.2 lb(6KG)  Solar Panel 8.8lb (4KG)
Warranty12 Months
Rated Power110W(+/-5W)*
Efficiency21%-22%
Connector TypeMC4
Open Circuit Voltage 21.7V(Vmp 18.5V)
Short Circuit Current 6.3A(Imp 6.0A)
Cell TypeMonocrystalline Silicon
Operating & Storage Temperature-4° F to 185° F (-20° C to 85° C)
RIVER Pro Portable Power Station
ProductQuantity
RIVER ProX 1
DC5521-DC5525 CableX 1
1.5m MC4 to XT60 Solar Charging Cable
X 1
1.5m AC Charging Cable
X 1
1.5m Car Charging Cable
X 1
User ManualX 1
ProductQuantity
110W Solar Panel x 1
110W Solar Panel Bagx 1
110W Solar Panel User Manualx 1
EcoFlow 110W Solar Panel What's in the Box
User Manual
  • Click to Download RIVER Pro User Manual
  • Click to Download the 110W Solar Panel User Manuel
