EcoFlow RIVER Extra Battery - Default Title
EcoFlow CA
$179.00 CAD
2 Reviews
Regular price $179.00 CAD
Sale price $179.00 CAD Regular price $249.00
-$70
• DOUBLE CAPACITY FROM 288Wh TO 576Wh
• EcoFlow RIVER + EXTRA BATTERY = EcoFlow RIVER MAX
• RECHARGE FROM 0% TO 80% WITHIN 1 HOUR
• COMPATIBLE WITH 80% HOME APPLIANCES
$179 CAD $249 -$70
Compact and portable, EcoFlow RIVER is an ideal recreational power which gives you the accessibility to handy wall outlets. EcoFlow RIVER is the perfect companion for camping, overlanding, tailgating, boating, etc. Feel free to attach and detach the Extra Battery to meet your needs now and later.
How to install EcoFlow RIVER Extra Battery?
1. Please make sure that the EcoFlow RIVER is turned off. Take out the screwdriver from the extra battery module kit and locate the four screws on the bottom cover.
Note: Please pay attention to prevent static electricity during the installation process.
2. Please remove the 4 screws and the bottom cover. The extra battery module should be positioned as shown in the figure.
3. Align the male and female battery sockets and connect them. Close the bottom cover. Take the four long screws from the kit and screw them on the screw mouth.
4. Put the EcoFlow RIVER upright and turn it on. The extra battery's ambient light will turn on. If the extra battery module indicator light is shown on the EcoFlow RIVER 's display, it is activated successfully. If the ambient light or the extra battery module indicator light is not active, repeat the installation steps and then check the connection.
What EcoFlow RIVER + Extra Battery Can Power?
*The duration and times of the appliances indicated in this table are for reference only.
Specifications
General Info
Net Weight5.5 lbs (2.5kg)
Dimension11.2 x 7 x 2.3 in (28.5 x 18 x 5.9 cm)
Charge Temperature32-113°F +/- 5°F (0-45°C +/- 3°C)
Discharge Temperature-4-113°F +/- 5°F (-20-45°C +/- 3°C)
Color Black
Warranty24 months
Battery Info
Capacity288Wh (28.8V)
Cell ChemistryLithium-ion
Shelf Life1 year (after fully charging the device)
Cycle Life500 Cycles to 80%+ capacity
Testing and certificationUL Standard CE FCC RoHS RCM
ProductQuantity
EcoFlow RIVER Extra BatteryX 1
Long ScrewsX 4
Cross Screw Driver
X 1
User Manual
X 1
User Manual
  • Click to Download EcoFlow RIVER Extra Battery User Manual
