EcoFlow Rigid Solar Panel Mounting Feet
Regular price $24.00 CAD
Sale price $24.00 CAD Regular price $24.00
-$0
  • Compatible with EcoFlow 100W and 400W Rigid Solar Panels.
  • An all-black design offers a low-key installation that blends in well with your roof
  • Lightweight and robust, crafted from anti-corrosive, waterproof aluminum alloy, suitable for long-term installation and use.
  • Package includes 4 × M6 hexagon screws, 4 × M6 spring washers, 4 × M6 flat washers, 4 × M6 large flat washers, 4 × M6 flange nuts.
Recommended Tools (Not Provided):
  • Adjustable Wrench
  • Tape Measure
  • Safety Glasses
  • Work Gloves
*The solar system should be installed, adjusted, and repaired by professional, qualified electrical maintenance personnel who are familiar with the installation structure and operation of solar panel installations.
$24 CAD
⚠️ Firmware Update Required for 1T2 Accessory
To use the 1T2 accessory properly, all compatible main units must be updated to the latest firmware version. Without the required firmware, you may experience operational issues.
Required firmware versions:
  • DELTA 3 Max Plus: v7.80.98.44 or above
  • DELTA 3 Ultra Plus: v7.80.98.46 or above
If you have not received the firmware update, please contact our customer support team to have it pushed to your device. To complete the upgrade, connect each EB to the main unit separately — the process requires two separate upgrades. Once both upgrades are complete, the 1T2 accessory will function normally.
Select your language
Turn on Growave
