EcoFlow Portable Power Station Grounding Adapter
Regular price $69.00 CAD
Sale price $69.00 CAD Regular price $69.00
-$0
Electric Vehicle Charging: With the grounding adapter, use a DELTA Pro or DELTA 2 Max/DELTA Max/DELTA 2 to charge your EV safely as an emergency backup power, giving you the extra mile.
 For DELTA Pro:
  1. Use the communication cable to connect with the communication ports (ethernet ports) of the grounding adapter and DELTA Pro.
  2. Use the AC power cable to connect the AC outlet of the grounding adapter and DELTA Pro.
  3. If using the double voltage hub to charge your electric vehicle, you need an extra NEMA 6-15P to C13 or NEMA 6-20P to C13 power cable to connect double voltage hub and the grounding adapter. Then use the communication cable to connect the communication ports (ethernet ports) of the grounding adapter and any DELTA Pro connected to double voltage hub.
 For DELTA 2 Max, DELTA Max, DELTA 2:
  1. Use the USB-C cable to connect with the USB-C port of the grounding adapter and the left USB-C port on the DELTA Max.
    DELTA 2 Max, DELTA Max, DELTA 2.
 Only use the USB-C Cable included with a portable power station grounding adapter. The Cable does not have any charging function, and other USB-C cables should not be used instead.
$69 CAD
⚠️ Firmware Update Required for 1T2 Accessory
To use the 1T2 accessory properly, all compatible main units must be updated to the latest firmware version. Without the required firmware, you may experience operational issues.
Required firmware versions:
  • DELTA 3 Max Plus: v7.80.98.44 or above
  • DELTA 3 Ultra Plus: v7.80.98.46 or above
If you have not received the firmware update, please contact our customer support team to have it pushed to your device. To complete the upgrade, connect each EB to the main unit separately — the process requires two separate upgrades. Once both upgrades are complete, the 1T2 accessory will function normally.
Payment options through Affirm Canada Holdings Ltd. (“Affirm”). Your rate will be 0–31.99% APR (where available and subject to provincial regulatory limitations). APR offered is based on creditworthiness and subject to an eligibility check. Not all customers will be eligible for 0% APR. Payment options depend on your purchase amount, may vary by merchant, and may not be available in all provinces/territories. Actual payment option terms will be shown at checkout. A down payment (or a payment due today) may be required. Affirm accepts debit cards and PAD as forms of repayment on payment options. Select payment options may be eligible for repayment in the form of credit cards. Please review the terms and conditions of your credit card when using it as a form of repayment. Sample payment options may be: a $800 purchase could be split into 12 monthly payments of $72.21 at 15% APR, or 4 interest-free payments of $200 every 2 weeks. For more information, please seehttps://www.affirm.com/en-ca/how-it-works.
Select your language
