EcoFlow DELTA 2 Max + 220W Portable Solar Panel + 800W Alternator Char - DELTA 2 Max + 220W Solar Panel + 800W Alternator Charger
EcoFlow DELTA 2 Max + 220W Portable Solar Panel + 800W Alternator Charger
$2,299.00 CAD
Regular price $2,299.00 CAD
Sale price $2,299.00 CAD Regular price $3,997.00
-$1,698
⚡️ 48Hrs Flash Sale Ends in
Days
Hours
Minutes
Seconds
• Expandable capacity: 2-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit a capacity of 6144Wh. Ideal for home backup, RVing, outdoors or ever everyday use.
• Built to last 6x longer: Get 10 years of daily use until hitting 80% of its original capacity. That's down to its LFP battery chemistry giving you 3000+
cycles.
• Huge AC output: With X-Boost mode get up to 3400W output power to run 99% of home appliances. Power 15 devices at once including6 AC outlets.
• Fastest recharging: World's fastest AC recharging and X-Stream dual AC+Solar charging speeds. Up to 1000W solar input to charge in as fast as 2.3
hours.
• Capture more energy: 99% MPPT efficiency maximizes solar generation anytime.
• High conversion efficiency rating: guarantees a faster solar charging speed. 0-100% in 2.6 hours (4 sets), 3.5 hours (3 sets) and 5.4 hours (2 sets)
• Customized in-app energy management: Prioritize solar or AC charging, view input and output power, battery levels and more
• Comprehensive warranties: DELTA 2 Max includes a 5-year warranty and 12 months for the 220W Bifacial Solar Panel.
• 5-Year warranty: 5 years for DELTA 2 Max, 12 months for NextGen 220W Solar Panel.
Subscribe DELTA 2 Max for latest updates
$2,299 CAD $3,997 -$1,698
Ultimate Power for Life Outdoors
Expandable up to 6kWh
Enjoy more power for group trips, extended adventures, or emergency backup—all from one modular system.
Built for Every Scenario
Power up your RV life, outdoor adventures, and home backup
RVing & Outdoors
Home Backup
DIY Projects
Filmmaking & Photography
*Note: Runtime is based on powering a single appliance. All test results shown are based on intemal testing and may vary depending on usage conditions.
4 ways of industry-leading fast charging
Car Charging
AC Input
AC + Solar Dual Charging
10 Years of Reliable Power
Reliable energy for daily life, built to power you for over a decade.
Smart Power Control at One Click
Anywhere. Anytime. Have full control of your DELTA 2 Max with the EcoFlow app.
Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
Stay worry-free during blackouts. AC Always On Mode keeps your power button active throughout outages and recovery, so your appliances stay on without interruption.
Customize AC or solar input for backup power or energy savings. Prioritize solar energy via the EcoFlow app when using X-Stream AC + solar dual charging.
Always ready for power. Get notified via the app when the battery is low.
Extensive 5-Year Warranty
Why choose EcoFlow DELTA 2 Max
DELTA 2 Max
DELTA 2 Max
AC Charging Cable
AC Charging Cable
User manual & warranty card
2048Wh
Extra Battery
6 outlets, 2400W total (Surge 4800W)
X-Boost 3400 W
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
AC Charging
X-stream Fast Charge 1800W, 15A
AC Input Voltage
100-120V~ max. 15A 50Hz/60Hz
Car Charging
Support 12V/24V battery, 8A
EcoFlow WAVE& WAVE 2 & GACIER &Smart generator
Supported
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Net weight (lbs)
50 lbs
Net weight (kg)
23kg
Select your language
