Best-Selling DELTA Pro
The prime choice of 286k worldwide homes
This state of-the-art high-capacity power station powers 286,000+ homes in over 100 countries. Become a proud DELTA Pro owner today and save big!
Enjoy solar energy with up to 50% savingsFast charge with up to 23% conversion rateFull charge with solar in as fast as 3.8 hr
First portable home battery designed for home backup.
Power for any situation.
From tailgate power to extreme blackouts that last for days on end, DELTA Pro offers a capacity of up to 25kWh, so you're covered for any situation.
All the AC output you’ll need.
A single DELTA Pro unit packs a 3600W AC output, which can be expanded up to 4500W with X-Boost technology. Power 99.99% heavy-duty devices at home, outdoors, or at work. You can even pair two units together to achieve 7200W.
Multi Charge delivers record-breaking speeds at 6500W. To reach 6500W, you can opt for these charging methods.
Simple, sustainable, and affordable whole-home backup power solutions with an output power of up to 7200W and a whopping 21.6kWh capacity for security and comfort. Easily chain together two DELTA Pros using the Double Voltage Hub. The solution provides a convenient home battery system without rewiring or running dangerous extension cables through your home.
A clean energy alternative.
Power your entire home.
With the Double Voltage Hub, DELTA Pro* provides unparalleled AC output of up to 7200W and 240V. Run 99% of all home appliances, even high-wattage clothes dryers and electric heaters, so you can keep your home running smoothly.*Double Voltage Hub requires two EcoFlow DELTA Pro units.
Smart energy management.
Travel without limits.
Connect DELTA Pro with an Extra Battery for a huge capacity of 7.2kWh, and stay powered for up to a week*. Run daily essentials such as a fridge, laptop, coffee maker, and even the air conditioner. You'll have the power to experience all that nature has to offer.
EV backup charging solution.
Power that means business.
How thick is the 2-meter-long (xx ft) Infinity Cable for DELTA Pro?
3+8 ports, power cable 10AWG, signal cable 22AWG.
How can I achieve a capacity of 25kWh?
What is the noise level of the DELTA Pro?
What are the output specifications of the DELTA Pro?
Can the Extra Battery directly charge DELTA Pro?
When using the Double Voltage Hub, do I have to turn on the DELTA Pro first? Can the Double Voltage Hub directly power on the DELTA Pro?
What is the peak power of the DELTA Pro Double Voltage Hub? Is there a duration limit?
What is the standby power consumption of the DELTA Pro?
Does it support dual charging (AC charging and DC charging)?
Why is the DELTA Pro unable to charge/power my devices?
Is the DELTA Pro compatible with the Smart Home Panel 2?
Can I use a DELTA Pro unit instead of a DELTA Pro Smart Extra Battery to connect to another DELTA Pro? If I want to connect two DELTA Pro units, what do you recommend?
3600Wh
Extra Battery
4500W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
Anderson Port
12.6V, 30A
AC Charging Input
Solar Charging Input
1600W Max, 11-150V, 15A Max
Car Charging Input
Support 12V/24V battery, 8A
Connection
Wi-Fi, Bluetooth
Approx. 99lbs/45kg
Dimension
