DELTA 3 Max Series Portable Power Station (2048Wh) | EcoFlow CA - DELTA 3 Max (2048Wh) / DELTA 3 Max (2048Wh) + 400W Solar Panel
Member Exclusive Product
EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh)
Regular price $1,779.00 CAD
Sale price $1,779.00 CAD Regular price $2,099.00
-$320
DELTA 3 Max Plus (2048Wh)
1. 3000W Powerful Output: 6000W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws.
2. 5 Ways to Charge, Ready in Just 43 Mins: Ready in Just 43 mins (0-80%) with generator charging.
3. 2-10kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop.
4. Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most.
1. 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws.
2. 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging.
3. Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product.
Common Features
1. Long-Lasting, Durable, and Reliable: Equipped with automotive-grade full-tab LFP cells, offering 10 years of reliable power, 24/7 protection BMS, and EV-grade CTC structure that protects against overnight condensation and off-road bumps during transport.
2. 10ms Auto-Switch: Fast enough to keep critical devices like NAS systems and servers running smoothly.
3. 25dB Whisper-Quiet Operation: Ultra-low noise (≤25dB at 600W).
4. OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. Storm Guard Mode automatically activates backup power before extreme weather hits. Self-Powered Mode and Scheduled Tasks save you money daily.
5. Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
⏰ Flash Sale Ends in
Days
Hours
Minutes
Seconds
Series
Product
$1,779 CAD $2,099 -$320
⚠️ Firmware Update Required for 1T2 Accessory
To use the 1T2 accessory properly, all compatible main units must be updated to the latest firmware version. Without the required firmware, you may experience operational issues.
Required firmware versions:
  • DELTA 3 Max Plus: v7.80.98.44 or above
  • DELTA 3 Ultra Plus: v7.80.98.46 or above
If you have not received the firmware update, please contact our customer support team to have it pushed to your device. To complete the upgrade, connect each EB to the main unit separately — the process requires two separate upgrades. Once both upgrades are complete, the 1T2 accessory will function normally.
Payment options through Affirm Canada Holdings Ltd. (“Affirm”). Your rate will be 0–31.99% APR (where available and subject to provincial regulatory limitations). APR offered is based on creditworthiness and subject to an eligibility check. Not all customers will be eligible for 0% APR. Payment options depend on your purchase amount, may vary by merchant, and may not be available in all provinces/territories. Actual payment option terms will be shown at checkout. A down payment (or a payment due today) may be required. Affirm accepts debit cards and PAD as forms of repayment on payment options. Select payment options may be eligible for repayment in the form of credit cards. Please review the terms and conditions of your credit card when using it as a form of repayment. Sample payment options may be: a $800 purchase could be split into 12 monthly payments of $72.21 at 15% APR, or 4 interest-free payments of $200 every 2 weeks. For more information, please seehttps://www.affirm.com/en-ca/how-it-works.
Select your language
Unlock Exclusive Member Savings
Member Price
$3,358.00
Original Price
$3,598.00
