EcoFlow BLADE Robotic Lawn Mower - BLADE + Lawn Sweeper Kit - EcoFlow CA
EcoFlow CA
(Members-only) BLADE + Lawn Sweeper Kit EcoFlow BLADE Robotic Lawn Mower EcoFlow BLADE Robotic Lawn Mower
$3,999.00 CAD
Regular price $3,999.00 CAD
Sale price $3,999.00 CAD Regular price $4,599.00
-$600
Up to EcoCredits for cash deduction
• Industry's First Robotic Lawn Sweeping Mower
• Wire-free Boundaries
• X-Vision Obstacle Avoidance
• Wide Cutting Range
• Anti-theft
• Rain Sensor
• Comprehensive After-sales Services
$3,999 CAD $4,599 -$600
EcoFlow BLADE
Let it Mow!
Leaf the hard work to us.
BLADE offers the complete lawn treatment, from a quick trim to an entire restyle. Attach the Lawn Sweeping Kit to remove unwanted debris, such as leaves, sticks, and waste, from your yard. You'll have the best-looking lawn in the neighborhood without any of the effort.
Virtually magic.
With our virtual boundary-setting technology, save time and energy without the need to lay pesky wire barriers. Set BLADE's mowing limits using the EcoFlow app within minutes, whether it's to stay within the confines of your yard, avoid specific objects, or even link two lawns. We've even got you covered if you move home or do some landscaping with easy-editable boundaries at the tap of a button.
Keep on Mowing With X-Vision Tech
Extensive warranty of up to 4 years
Dedicated 1-1 service team
Replacements instead of repairing
Free accessories for life
With the EcoFlow Lawn Sweeper Kit*, BLADE can sweep the lawn while mowing and collecting leaves/waste/sticks, etc. automatically.
No AC outlet nearby, no problem. Use the Smart Extra Battery to power your BLADE Charging Station no matter where you are. Plug in your solar panels and run BLADE using clean, renewable energy.
What’s in the box
EcoFlow BLADE
EcoFlow BLADE
Charging Station
Charging Station
Power Adapter (varies by region)
GNSS Antenna
GNSS Antenna
Quick Start Guide
Quick Start Guide
Other Accessories
Other Accessories
SPECS
Product Type
Robotic Lawn Mower
16.2 kg / 36 lbs
<660*440*310 mm
IP Rating
IPX5
Battery Life
120 min, more than 400 ㎡
Sensor
IMU Sensor, Lift Sensor, Rain Sensor, Wheel Encoder, Lidar, Camera
Fully-Charged Working Time
240 min
Cutting Width
260 mm
Cutting Height
20-76 mm
Climbing Ability
27°
Vertical Obstacle Climbing
40 mm
Recharging Time
130 min
Refrigeration Power Rating
GPS, Beidou, Galileo, GLONASS
Bluetooth Channel
2400-2483.5MHz
Charging Station Input Voltage
36V
Charging Station Input Current
5A
Charging Station Output Voltage
25.2V DC Max
Charging Station Output Current
7A Max
