Portable Solar Panels
Recommend
Up to date
Recommend
Ascending price
Price descending
This is a test
22.6% Conversion Rate | IP68
Regular price
from
$899.00 CAD
Sale price from $899.00 CAD
Regular price $1,399.00
per
• Charge faster with high 400W solar intput  • Up to 23% conversion rate • Durable, multi-layered materials • Self-supporting with an adjustable angle • IP68 waterproof rating • One-piece folding d...
-$1,249
Regular price
from
$399.00 CAD
Sale price from $399.00 CAD
Regular price $599.00
per
Up to 25% conversion efficiency rate · 30-60° adjustable angle bracket and integrated solar angle guide · ETFE coating; built to last · Lightweight and compact; ultra portable · IP68 rating protec...
-$400
25% Conversion Rate
Regular price
from
$299.00 CAD
Sale price from $299.00 CAD
Regular price $349.00
per
· Up to 25% cutting-edge solar conversion efficiency rate · Use TOPcon solar cells that work well in low light and high-temperature environments, maintaining high power output. · Built to last with...
-$367
22.8% Conversion Rate | IP68
Regular price
from
$299.00 CAD
Regular price $499.00
per
Only $199 for the 110W Portable Solar Panel. Disccount auto-applied at checkout • Portable and lightweight • Up to 23% conversion rate • Self-supporting • Durable with IP68 waterproof rating • On...
-$579
25% Conversion Rate | IP68
Regular price
$169.00 CAD
Sale price $169.00 CAD
Regular price $179.00
per
*Note: The 60W Portable Solar Panel is Type-c Version. - Up to 25% conversion rate - Extremely compact to easily fit into small spaces - IP68 waterproof rating, protects against unexpected weather...
-$10
Regular price
from
$99.00 CAD
Sale price from $99.00 CAD
Regular price $139.00
per
Designed for Type-C charging: Charge your gadgets directly. 45W Portable Solar Panel (Type-C) includes a Type-C output port to direct charge devices like phones, laptops, and air pumps. Extremely...
-$89
Regular price
$749.00 CAD
Sale price $749.00 CAD
per
• Charge faster with high 400W solar intput  • Up to 23% conversion rate • Durable, multi-layered materials • Self-supporting with an adjustable angle • IP68 waterproof rating • One-piece foldi...
-$650
Regular price
$279.00 CAD
Sale price $279.00 CAD
per
· Up to 25% conversion efficiency rate · 30-60° adjustable angle bracket and integrated solar angle guide · ETFE coating; built to last · Lightweight and compact; ultra portable · IP68 rating prot...
-$320
25% Solar Efficient N-Type TOPCon Cells; IP68 Waterproof
Regular price
from
$349.00 CAD
Sale price from $349.00 CAD
Regular price $699.00
per
Over 10°C/50℉ Heat Insulation with Air Gap Technology 25% Solar Efficient N-Type TOPCon Cells Custom-designed for Each Tesla Model Integrated Design with Your Vehicle IP68 Waterproof Damage-Free...
-$599
25% Conversion Rate
Regular price
$249.00 CAD
Sale price $249.00 CAD
per
-$100
Accessories
XT60 | XT60i
Regular price
$54.00 CAD
Sale price $54.00 CAD
Regular price $24.99
per
Solar to XT60 Charging Cable Connect a solar panel to an EcoFlow power station for clean, efficient, and reliable power wherever you go. The EcoFlow Solar to XT60 Charging Cable (3.5m) allows you t...
Regular price
$29.99 CAD
Sale price $29.99 CAD
Regular price $29.99
per
Product Description The EcoFlow Solar Extension Cable (3m) extends the XT60 Solar Cable  (3.5m) by an additional 3m. Highlights Provides additional cable length, which allows you to keep an EcoFlow...
Keep Sunlight at A 90° Angle
Regular price
$19.99 CAD
Sale price $19.99 CAD
Regular price $19.99
per
Catch Every Ray of Light: Keep sunlight at a 90° angle and concentrate the sun’s rays onto the surface of your solar panel. The Solar Angle Guide gives you a way to maximize solar exposure. Serious...
Regular price
$19.00 CAD
Sale price $19.00 CAD
Regular price $19.00
per
Product Description The EcoFlow Solar Parallel Cable connects solar panels in parallel to an EcoFlow power station (DELTA/RIVER Series). Highlights Connects solar panels in parallel to improve the...
Thanks for sharing!
Select your language
