Get off the grid with EcoFlow's 110W Solar Panel for renewable energy wherever you end up.
Universal
Seamless
Foldable
Portable
Powerfully portable
With an industry-leading 23% conversion rate, it's far lighter and approx. 10% smaller than similar portable solar panels on the market. That means a faster, easier charge wherever you are.
Self-supportable
Take it camping, on a road trip or in your backyard with a case that doubles as a stand. Unzip and prop up your panel at just the right angle to ensure maximum solar coverage.
Waterproof & Durable
Designed to withstand your adventurous lifestyle, this panel is IP68 certified. That means we dunked it underwater for 72hrs in lab conditions. Just to make sure*. Built with a high-strength composite, it can take a beating too. That's an all-weather ready panel designed to stand the test of time.
It comes with a carry case too.
On the go? Keep your panel folded up and protected while you hit the road. Save valuable trunk space and go easy knowing your panel is safe. Once you arrive, simply unfold, prop up and start generating clean, green electricity.
Title
RIVER mini
RIVER
RIVER Max
RIVER Max Plus
RIVER Plus
RIVER Pro
DELTA mini
DELTA 1000
DELTA 1300
RIVER
RIVER Max
RIVER Pro
RIVER Plus
RIVER Max Plus
DELTA mini
DELTA 1000
DELTA 1300
DELTA mini
DELTA Max(1600)
DELTA Max(2000)
1.110W Solar Panel 2.110W Solar Panel Bag 3.110W Solar Panel User Manual
Compare The Models
110W Solar Panel
Rated Power: 110 Watts
Unfolded : 62.5 x 20.2 x 1.0 in
Efficiency : 21-22%
Warranty : 12 Months
$499
160W Solar Panel
Rated Power: 160 Watts
Unfolded : 61.8 x 26.8 x 1.0 in
Efficiency : 21-22%
$599
Unfolded Dimensions
20.2*62.5*0.8 in /178.5*42.0*2.5cm
Folded Dimensions
20.2*16.5*0.8 in/42.0 x 48.0 x 2.5cm
Weight
8.8lb (4kg)
12 months
Rated Power
110W (±5W)
Efficiency
22%–23%
Connector Type
Solar Connector
Open Circuit Voltage
21.8V (Vmp 18.4V)
Short Circuit Current
6.5A (Imp 6.0A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−4°F to 185°F
Folded Dimensions
