EcoFlow Home Backup Kit: Manual Transfer Switch EcoFlow Home Backup Kit: Manual Transfer Switch EcoFlow Home Backup Kit: Manual Transfer Switch
Regular price $449.00 CAD
Sale price $449.00 CAD Regular price $499.00
-$50
Installation of the transfer switch must be performed by a qualified electrician under the guidance of the installation and operating instructions in compliance with all applicable electrical codes. Only viable with indoor circuit breaker panels.
• Plug & play home backup solution
• Clean and silent power alternative
• Completely pre-wired for easy installation
• Includes wattmeters
• Metal cabinet, designed for indoor use
• cULus 1008 Listed
Keep your critical home circuits running when blackout hits. Forget expensive and complicated system with this kit and your DELTA Pro. NOTE: Please consult a qualified electrician for installation. Only viable with indoor circuit breaker panels.
$1,999 CAD $4,499 CAD
3.6-25kWh Capacity
3600W Output
$2,799 CAD $4,499 CAD
4-48kWh Capacity
4kW-12kW Output
$449 CAD $499 -$50
⚠️ Firmware Update Required for 1T2 Accessory
To use the 1T2 accessory properly, all compatible main units must be updated to the latest firmware version. Without the required firmware, you may experience operational issues.
Required firmware versions:
  • DELTA 3 Max Plus: v7.80.98.44 or above
  • DELTA 3 Ultra Plus: v7.80.98.46 or above
If you have not received the firmware update, please contact our customer support team to have it pushed to your device. To complete the upgrade, connect each EB to the main unit separately — the process requires two separate upgrades. Once both upgrades are complete, the 1T2 accessory will function normally.
Payment options through Affirm Canada Holdings Ltd. (“Affirm”). Your rate will be 0–31.99% APR (where available and subject to provincial regulatory limitations). APR offered is based on creditworthiness and subject to an eligibility check. Not all customers will be eligible for 0% APR. Payment options depend on your purchase amount, may vary by merchant, and may not be available in all provinces/territories. Actual payment option terms will be shown at checkout. A down payment (or a payment due today) may be required. Affirm accepts debit cards and PAD as forms of repayment on payment options. Select payment options may be eligible for repayment in the form of credit cards. Please review the terms and conditions of your credit card when using it as a form of repayment. Sample payment options may be: a $800 purchase could be split into 12 monthly payments of $72.21 at 15% APR, or 4 interest-free payments of $200 every 2 weeks. For more information, please seehttps://www.affirm.com/en-ca/how-it-works.
Thanks for sharing!
Select your language
