Recommend
Up to date
Recommend
Ascending price
Price descending
XT60 | XT60i
Regular price
$54.00 CAD
Sale price
$54.00 CAD
Regular price
$24.99
Solar to XT60 Charging Cable
Connect a solar panel to an EcoFlow power station for clean, efficient, and reliable power wherever you go. The EcoFlow Solar to XT60 Charging Cable (3.5m) allows you t...
EcoFlow Solar Extension Cable
Regular price
$29.99 CAD
Sale price
$29.99 CAD
Regular price
$29.99
Product Description
The EcoFlow Solar Extension Cable (3m) extends the XT60 Solar Cable (3.5m) by an additional 3m.
Highlights
Provides additional cable length, which allows you to keep an EcoFlow...
Regular price
from
$469.00 CAD
Sale price
from $469.00 CAD
Regular price
$699.00
800W turbo alternato...
-$2,799
EcoFlow Solar Angle Guide
Keep Sunlight at A 90° Angle
Regular price
$19.99 CAD
Sale price
$19.99 CAD
Regular price
$19.99
Catch Every Ray of Light: Keep sunlight at a 90° angle and concentrate the sun’s rays onto the surface of your solar panel. The Solar Angle Guide gives you a way to maximize solar exposure.
Serious...
Regular price
$1,899.00 CAD
Sale price
$1,899.00 CAD
Regular price
$3,399.00
• Expand capacity up to 10.8kWh with 2 extra batteries
• Long-last...
-$1,500
EcoFlow Car Charging Cable
Regular price
$29.99 CAD
Sale price
$29.99 CAD
Regular price
$29.99
Product Description
Car Charging Cable with XT60i connector and car cigarette plug
Highlights
Designed to seamlessly connect your EcoFlow power stations to your vehicle's car charger through the c...
EcoFlow Smart Generator Adapter
Regular price
$69.00 CAD
Sale price
$69.00 CAD
Regular price
$69.00
Smart Generator Adapter will ship by the end of 2026.
*This adapter is necessary when the DELTA Pro 3/DELTA Pro is connected to the Smart Generator / Smart Generator (Dual Fuel)/Smart Generator 4...
EcoFlow Smart Generator 3000 (Dual Fuel)
Regular price
from
$1,099.00 CAD
Sale price
from $1,099.00 CAD
Regular price
$1,099.00
Note: The "automatic start-stop" function of Smart Generator 3000 (Dual Fuiel) is only compatible with DELTA 3 and DELTA 3 Plus.
Dual Fuel: gasoline and LPG
20kWh capacity with standard LPG ...
-$349
EcoFlow Solar Parallel Connection Cable
Regular price
$19.00 CAD
Sale price
$19.00 CAD
Regular price
$19.00
Product Description
The EcoFlow Solar Parallel Cable connects solar panels in parallel to an EcoFlow power station (DELTA/RIVER Series).
Highlights
Connects solar panels in parallel to improve the...
EcoFlow RIVER Extra Battery
Regular price
$179.00 CAD
Sale price
$179.00 CAD
Regular price
$249.00
• DOUBLE CAPACITY FROM 288Wh TO 576Wh
• EcoFlow RIVER + EXTRA BATTERY = EcoFlow RIVER MAX
• RECHARGE FROM 0% TO 80% WITHIN 1 HOUR
• COMPATIBLE WITH 80% HOME APPLIANCES
-$70
EcoFlow Smart Generator 4000 (Dual Fuel)
Regular price
from
$1,999.00 CAD
Sale price
from $1,999.00 CAD
Regular price
$1,999.00
- Dual Fuel: EPA version with LPG & gasoline.
- 4000W Peak AC Output
- 40% Higher Energy Efficiency
- 4 Modes of Self-starting
- App Control and Monitor
- 5 Safety Alerts
- Ergonomically Port...
-$1,700
Regular price
$38.99 CAD
Sale price
$38.99 CAD
Regular price
$75.99
-Multi-Port Charger: Charge 3 devices at the same time with 2 × USB-C ports and 1 × USB-A port.
-65W Fast Charging: High-speed charge a MacBook Pro 14 in, Samsung S24 Ultra and Google Pixel Boo...
-$37
EcoFlow RIVER Pro Extra Battery
Regular price
$299.00 CAD
Sale price
$299.00 CAD
Regular price
$399.00
• DOUBLE CAPACITY FROM 720Wh to 1440Wh
• POWER A WIDE RANGE OF APPLIANCES
• COMPACT AND PORTABLE
-$100
25% Conversion Rate | IP68
Regular price
from
$99.00 CAD
Sale price
from $99.00 CAD
Regular price
$139.00
Designed for Type-C charging: Charge your gadgets directly. 45W Portable Solar Panel (Type-C) includes a Type-C output port to direct charge devices like phones, laptops, and air pumps.
Extremely...
-$89
EcoFlow Alternator Charger XT60 Output Cable (1m)
Regular price
$79.00 CAD
Sale price
$79.00 CAD
Regular price
$79.00
Compatibility
The cable is compatible with EcoFlow or third-party portable power stations equipped with an XT60 input port.
If your vehicle starter battery or RV house battery operates at 24V, ens...
EcoFlow RAPID 20W GaN Charger with 60W Cable
Regular price
$24.99 CAD
Sale price
$24.99 CAD
Regular price
$24.99
- 20W Fast Charging: Fast charge your iPhone 15 to 50% in only 25 mins
- Compact Design: 40% smaller than standard chargers thanks to GaN. With a foldable plug, it fits comfortably into a pocket o...
EcoFlow 500W Solar Kit (4 x 125W Bifacial Modular Solar Panel)
25% Conversion Rate
Regular price
from
$1,199.00 CAD
Sale price
from $1,199.00 CAD
Regular price
$1,199.00
Note:
The 125W Bifacial Modular Solar Panel is currently sold as a 4-panel (500W) set.
Feature:
Modular design: Max parallel connection of 8 panels (1000W)
Adjustable angle (30-60°) for...
-$4,401
EcoFlow 60W Portable Solar Panel
Regular price
$169.00 CAD
Sale price
$169.00 CAD
Regular price
$179.00
*Note: The 60W Portable Solar Panel is Type-c Version.
- Up to 25% conversion rate
- Extremely compact to easily fit into small spaces
- IP68 waterproof rating, protects against unexpected weather...
-$10
EcoFlow Alternator Charger XT150 Output Cable (2m)
Regular price
$99.00 CAD
Sale price
$99.00 CAD
Regular price
$99.00
Compatibility
The cable is compatible with EcoFlow portable power stations or extra batteries that have an extra battery port (XT150).
Connection
Use the cable to connect the charger's Portable Pow...
EcoFlow Alternator Charger Custom Fit Output Cable (2m)
Regular price
$109.00 CAD
Sale price
$109.00 CAD
Regular price
$109.00
Compatibility
The cable is compatible with EcoFlow DELTA Pro, EcoFlow DELTA Pro 3, EcoFlow DELTA Pro Smart Extra Battery, EcoFlow DELTA Pro 3 Smart Extra Battery.
Connection
Use the cable to conn...
EcoFlow Extra Battery Flat Link Cable
Regular price
from
$99.00 CAD
Sale price
from $99.00 CAD
Regular price
$99.00
Highlights
Connects the DELTA Pro 3 to the DELTA Pro 3 Smart Extra Battery/DELTA Pro Extra Battery using the Extra Battery port on the back of the unit.
Specifications
Length: 2.8ft / 0.85m
*The...
EcoFlow DELTA 2 Smart Extra Battery (Refurbished)
Regular price
$399.00 CAD
Sale price
$399.00 CAD
Regular price
$879.00
• Expandable Capacity
• Convenient Recharging
• Fast Recharging
• Power multiple devices
• Control from anywhere
-$480
EcoFlow Alternator Charger Extended Fuse Cable (2m)
Regular price
$59.00 CAD
Sale price
$59.00 CAD
Regular price
$59.00
EcoFlow DELTA mini Bag
Regular price
$59.00 CAD
Sale price
$59.00 CAD
Regular price
$59.00
The EcoFlow DELTA mini Bag maintains the DELTA mini’s ease of use while protecting it from water, debris and damage while on the move.
Highlights
Made from lightweight, waterproof, and wear-resist...
45W Portable Solar Panel - Flash Sale
Regular price
$89.00 CAD
Sale price
$89.00 CAD
Regular price
$139.00
- Designed for hanging on vehicles, tents or backpa...
-$50
Hot
EcoFlow DELTA Pro Smart Extra Battery (Refurbished)
Regular price
$1,569.00 CAD
Sale price
$1,569.00 CAD
Regular price
$2,999.00
• Long-last...
-$1,430
