EcoFlow Power Hat
EcoFlow Power Hat EcoFlow Power Hat
$129.00 CAD
Regular price $129.00 CAD
Sale price $129.00 CAD Regular price $159.00
-$30
Power all your adventures.
*Size:
Medium-Large size: 56-58 cm
Large-XLarge size: 59-61 cm
    1. Solar charging on the go
    2. Captures solar energy from all angles without any blind spots.
    3. Dual USB-A & USB-C ports for charging two devices simultaneously.
    4. Lightweight at only 13.1 oz (370 g), easy to pack.
    5. IP65 waterproof and dust proof-rated, ideal for hiking, beach trips, fishing, and outdoor activities.
    6. Available in two head sizes 22.8/24 in (M:58/L:61 cm) with adjustable hook and loop for the perfect fit.
    Be the First to Unlock New Arrivals
    $129 CAD $159 -$30
    Adjustable M to XL size
    Featuring an adjustable hook-and-loop design inside the hat for a snug fit without obstructing vision.
    360-Degree Coverage, Solar Charging On the Go
    Traditional solar panels require adjusting to ensure optimal sunlight exposure. EcoFlow Power Hat maintains the optimal angle at all times, eliminating the need for manual adjustments. It charges a mobile phone fully in as fast as 3-4 hours.
    *Assuming the phone battery capacity is 4000mAh
    Dual Ports for Charging Two Devices at Once
    Charge two devices at the same time, such as neck fans, Bluetooth headphones, and mobile phones.
    UPF50+, Sun and UV Protection
    The EcoFlow Power Hat comes with a lab-tested UV penetration rate of 0%, achieving a sun protection factor of UPF50+. With sun and UV protection, it lets you face the sun without worrying about sunburn or overheating.
    Up to 24% Thermal-to-Electrical Conversion for A Cooler Wearing Experience
    During the charging process, the brim's solar panels convert up to 24% of absorbed heat into electricity. Compared to a standard black hat, it has a lower surface temperature, providing a cooler experience.
    Foldable Design, Easy to Carry
    Lightweight and comfortable for extended wear. Easily folds and fits into a backpack for convenient storage, making it the ideal choice for hiking.
    IP65 Waterproof and Dustproof-rated Suitable for outdoor use
    Works well in wet environments like by the sea or lake,and can be used in light rain.
    Resistant to sand and dust, splash-proof, and crack-resistant, making it durable and
    suitable for outdoor use without needing delicate handling.
    Suitable for Outdoor Scenarios
    Ideal for hiking, mountain climbing, fishing, beach outingss, outdoor tasks, and more.
    Perfect for solar charging during an outdoor activity while alsco providing sun protection
    What‘s In The Box
    Rated Power
    STC12W(+/-1w)
    Cell Type & Efficiency
    Perc Monocrystalline Silicon, 23-24%
    Medium-Large:7-71/4/ 56-58 cm/22-22.8"
    Large-X-Large: 73/8 - 7 5/8 / 59-61 cm/23.2-24"
    Open Circuit Voltage
    7.8V
    13 oz (370g)
    Maximum Operating Voltage
    6V
    Output Ports
    USB-A/USB-C
    Maximum Operating Current
    2A
    Output
    5V 2.4A Max
    Short Circuit Current
    2.2A
    Waterproof & Dustproof
    IP65
    Can the hat string be replaced with other types?
    Yes, it can be replaced as long as the diameter of the stringis around 5 mm. You can refer to the quick guide for replacement instructions.
    Is it normal for the phone's charging level to decrease in outdoorscenarios?
    Under certain conditions, this is normal. For the hat to effectively charge your phone, the required light intensity needs to be at least 300-400W/m2 (between 9 ANM and 3 PM, on lightly cloudy or slightly hazy days with direct sunlight). If the light conditions are lower than this (on heavily cloudy days, rainy days, or in shaded areas), the phone will show that it is charging, but the charging power will be less than the power consumption, resulting in thephone's battery level decreasing.
    Can the hat be washed?
    Yes, it can be washed, but do not soak the hat in water or vwash it in a washing machine. The IP65protection rating does not support waterproofing for soaking. You can clean the hat by wiping it with a damp cloth or rinsing it with water while covering the rubber plug of the junction box. During the cleaning process, avoid bending the solar chip excessively as it may crack and affect the power output.
    Will uneven lighting conditions on the solar panel (e.g., onehalf ofthe hat in the sun and the other half in the shade) affect chargingg?
    Yes, but it will not prevent charging. It will only reduce the ctharging speed. The unshaded area can still generate power normally and will not be affected by the shaded part.
    Can the hat store power?
    The hat does not contain a battery, so it does not have any poower storage capability.
    Does using the phone while charging it in sunlight affect the chargingprocess?
    No, but the phone's power consumption will increase, and thecharging power remains constant, which will result in a slower charging speed.
    Is there a difference in charging performance for different phones,and does the hat support fast charging?
    Yes, different brands and models may charge at different speedswhich is normal. This is especially noticeable under low light conditions, as different phones have varying requirements for low-speed charging. This product only supports a maximum charging requirrement of 5V 2.4A and does not support QC and PD fast charging protocols.
    Is it normal for one device to be usable while theother is not whencharging these two devices simultaneously?
    Yes, this is normal. Under insufficient light conditions, the energymay not be enough to supply two devices simultaneously. The priority of charging depends on the devices' charging strategies. For example, under low light conditions, if an iPhone and a Samsung phone are charging together, the iPhone may draw more current, causing the Samsung phone to charge very slowly or not charge at all.
    Select your language
