EcoFlow Smart Home Panel 2 EcoFlow Smart Home Panel 2 EcoFlow Smart Home Panel 2
$2,499.00 CAD
Regular price $2,499.00 CAD
Sale price $2,499.00 CAD Regular price $2,699.00
-$200
Smart Home Panel 2 will be shipped in mid-December.
-Intelligent subpanel for home battery systems
-20 ms auto switchover
-EcoFlow app control
-Modular design
* The EcoFlow DELTA Pro Ultra Battery allow 15 days for shipment.
Recommend
Accessories
$2,499 CAD $2,699 -$200
An intelligent subpanel for outage protection and savings in one.
The EcoFlow Smart Home Panel 2 is the center of your whole-home backup solution, working alongside EcoFlow DELTA Pro Ultra, generators, and solar panels to protect your home. With a fast, automatic switchover, you'll have reliable backup whenever you need it. Its Smart Energy Management system extends backup duration and forecasts outages through hourly weather checks. Smart Home Panel 2 customizes your energy usage based on time-of-use rates and your home's solar energy production.
The commanding force behind your power system.
The Whole-Home Backup System Hub
EcoFlow Smart Home Panel 2 is the hub of the powerful EcoFlow DELTA Pro Ultra that allows you to get the full potential out of your energy system. Connect your home circuits with up to 3 plug-and-play inverters and 15 stackable 6kWh batteries, itnot only takes care of your backup for even longer but allows you to control and run every single household appliance.EcoFlow Smart Home Panel 2 is not only future-proofed to work with our next-gen power solutions, but it works with EcoFlow DELTA Pro, too.
Even plan B has a plan B.
Compatible with Solar and Gas Generators
EcoFlow Smart Home Panel 2 can manage your energy from various sources, including solar and gas. With the sun's rays, brighten your home with cost-effective green energy and dramatically reduce your electricity expenses.When the weather turns gray and you're all out of sunshine, a seamless connection to any 3-12kW portable gas generator ensures your home stays energized without a hitch.
The nights of fumbling for a torch are over.
20-Ms Auto-Switchover
When an outage hits, there's no need to brave the dark, cold night to switch to your backup manually. EcoFlow Smart Home Panel 2's automatic switchover feature ensures your home remains powered even when you're away. Forget spoiled food and damaged appliances. Embrace uninterrupted power so that life never stops.
Leave the power prep to the pro.
EcoFlow App
EcoFlow Smart Home Panel 2 ensures your home is blackout-proof with ample energy at all times. Even when an outage lingers on, it's business as usual.
Backup Extension
Emergency Weather Prep
Categorize your home circuits into three levels of power supply priority with Circuit Control mode. Ensure protection for the most mission-critical tasks and massively extend backup time.
With automatic storm warnings mode, batteries fully recharge 24 hours before an extreme weather event. Locking energy until an outage occurs. EcoFlow Smart Home Panel 2 monitors the weather hourly, updating the system based on the forecast, offering a more precise backup strategy.
Savings just roll on in.
With the EcoFlow App
With Backup Reserve mode, EcoFlow Smart Home Panel 2 secures an assigned battery percentage. Fear an impending outage? Set a higher reserve for home backup. For everyday use, set a lower portion and customize your EcoFlow Smart Home Panel 2's performance using Self-Power, Scheduled Tasks, or TOU Modes to lower your energy bills.
TOU Mode
Based on Time Of Use peak and off-peak rates and your energy habits, EcoFlow Smart Home Panel 2 intelligently manages battery charge and discharge, significantly offsetting electricity costs.
Self-Power Mode
Once battery capacity exceeds the pre-set reserve, solar begins to top up energy supplies while powering the home to lower utility bills.
See your entire energy strategy at work.
EcoFlow App, PowerInsight & Web Dashboard
View real-time energy insights for your home anywhere you go. On your phone, wall-mounted dash, or even online. Get a complete home energy consumption overview as well as solar and gas input, battery capacity, and much more. With EcoFlow Smart Home Panel 2 comes PowerInsight, a wall-mounted screen, and a web dashboard, accessible anywhere online.
EcoFlow app
EcoFlow PowerInsight
Web dashboard
Monitor, control, and customize your power usage at your fingertips.
Home Energy Manager, an all-in-one dedicated monitor.
A full suite of data and customizations accessible online.
Fits into your home with ease.
Modular design
To work with your home layout, decor, and to save space, we've split EcoFlow Smart Home Panel 2 into two modules—a battery connection box and a distribution panel. Install each separately or together with less wiring and more flexibility to place your batteries.
What’s in the box
QuickLook
Dimensions (in)
Distribution Panel: 24.8 x14.9 x 6.7 in
Battery Connection Box: 6.9 x 14.4 x4.3 in
Distribution Panel+Battery Connection Box: 32.4x144.9x6.7 in
Net Weight (lb)
Distribution Panel: 39.7 lb
Battery Connection Box: 7.2 lb
Distribution Panel + Battery Connection Box: 52.9 lb
10 Years
Output
Output Voltage
120V/240V
Wire Diameter
14-6AWG
Circuit Breaker Current
Max. 60A
Number of Loads
12
Control
App Remote Control
Output Wiring Methods
L1/L2/N/PE
Grid Access Input
Input Voltage
120V/240V
Input Frequency
60Hz
Max. Input Current
100A
Wire Diameter
4AWG
Max. 100A
Generator Access Input
Input Voltage
120V/240V
Input Frequency
60Hz
Max. Gas Generator Input
12kW
Wire Diameter
1AWG
Max. 50A
Home Backup Access Input
Input Voltage
120V/240V
Input Frequency
60Hz
Max. Input Current
30A (one battery)
Max. Input Power
7200W (one battery)
Environmental Data
Operating Temperature
-30°C - 49°C (-22°F-120°F)
Storage Temperature
-40°C - 70°C (-40°F-158°F)
Max. Operating Altitude
6561.6 ft
Relative Humidity
100%
Protection Level
Distribution Panel: NEMA TYPE 3R rainproof
Battery Connection Box: NEMA TYPE 1
Communication Methods
Wi-Fi & Bluetooth & Ethernet
Thanks for sharing!
Select your language
