EcoFlow RIVER Pro Extra Battery - Default Title
EcoFlow CA
$299.00 CAD
3 Reviews
Regular price $299.00 CAD
Sale price $299.00 CAD Regular price $399.00
-$100
• DOUBLE CAPACITY FROM 720Wh to 1440Wh
• POWER A WIDE RANGE OF APPLIANCES
• COMPACT AND PORTABLE
$299 CAD $399 -$100
The RIVER Pro Extra Battery doubles the capacity of RIVER Pro from 720Wh to 1440Wh, giving you the freedom to customize your power for any adventure.
The RIVER Pro weighs just 15.9 lbs and the RIVER Pro Extra Battery weighs 15.4 lbs, making them both portable and easy to transport. The RIVER Pro + Extra Battery can easily fit in a car trunk, on a campsite, or indoors, giving you the power to take your adventure anywhere.
How to Connect the RIVER Pro Extra Battery to the RIVER Pro
1. Power off BOTH the RIVER Pro and RIVER Pro Extra Battery before attempting to connect them together.
2. Open the Power Expansion Port cover on RIVER Pro to access the Power Expansion Port. Connect the Expansion Power Cable to the RIVER Pro Expansion Power Port. Tighten the screws on the Expansion Power port securely.
3. Open the Expansion Port Cover of the RIVER Pro Extra Battery to access the Expansion Power Port. Connect the free end of the Expansion Power Cable to the RIVER Pro Extra Battery Power Expansion Port. Tighten the screws on the Expansion Power port securely.
4. Turn on the power button of the RIVER Pro or RIVER Pro Extra Battery. Fully charge the devices for the first time and ensure the voltage is consistent to maximize the performance. If the display of the RIVER Pro shows the Extra Battery Icon, the connection is successful.
What RIVER Pro + Extra Battery Can Power?
*The duration and times of the appliances indicated in this table are for reference only.
Specifications
General Info
Net Weight16.0 lbs (7.3kg)
Dimension11.3 x 7.1 x 8.3 in (28.8 x 18 x 21 cm)
Charge Temperature32-113°F +/- 5°F (0-45°C +/- 3°C)
Discharge Temperature-4-113°F +/- 5°F (-20-45°C +/- 3°C)
Color Black
Warranty24 months
Testing and certificationUL CE FCC RoHS RCM
Outputs
Expansion Power Port24.4V - 33.6V, 720W Max
Input
Expansion Power Port33.6V, 660W Max
Battery Info
Capacity720Wh (28.8V)
Cell ChemistryLithium-ion
Cell Type18650
Shelf Life1 year (after fully charged)
Life Span800 Cycles to 80%+ capacity
ProductQuantity
RIVER Pro Extra BatteryX 1
Expansion Power CableX 1
User Manual
X 1
User Manual
  • Click to Download RIVER Pro Extra Battery User Manual
