EcoFlow RIVER 2 Solar Generator (PV110W)
Regular price $529.00 CAD
Sale price $529.00 CAD Regular price $798.00
-$269
  • Lightweight at only 7.7 lbs.
  • Generates up to 784Wh daily.
  • A 600W AC output with X-Boost.
  • Up to 23% conversion guarantees a fast solar charging speed: 0-100% in 3 hours (1 set).
  • LiFePO4 battery and IP68 dust and water resistance.
  • Smart remote control with EcoFlow app.
  • 5-year warranty for RIVER 2 and 12-month warranty for 110W Portable Solar Panel.
**RIVER 2 and 110W Portable Solar Panel will be shipped separately.
Shipment services to Alaska, Puerto Rico, and Hawaii are temporarily suspended.
Number of 110W Solar Panel
$529 CAD $798 -$269
⚠️ Firmware Update Required for 1T2 Accessory
To use the 1T2 accessory properly, all compatible main units must be updated to the latest firmware version. Without the required firmware, you may experience operational issues.
Required firmware versions:
  • DELTA 3 Max Plus: v7.80.98.44 or above
  • DELTA 3 Ultra Plus: v7.80.98.46 or above
If you have not received the firmware update, please contact our customer support team to have it pushed to your device. To complete the upgrade, connect each EB to the main unit separately — the process requires two separate upgrades. Once both upgrades are complete, the 1T2 accessory will function normally.
Power. Never Been This Easy
Charge 0-100% in 1 Hour
Fastest charging speeds ever.
RIVER 2 beats the industry standard of charging speeds, fully charging in only 60 minutes. That's 5x faster than other portable power stations on the market and 38% quicker than previous generations. Fully charge RIVER 2 while you pack your bags, so you'll always be ready for a last-minute trip.
LiFePO4 Battery Chemistry
With upgraded long-lasting LFP battery chemistry at its core, charge and empty RIVER 2 Series over 3000 times. That's pretty much 10 years of everyday use1 and 6x longer than the industry average. With LFP cells, RIVER 2 Series is safe, durable, and highly efficient, even in warm temperatures.
The first power station that's TÜVRheinland certified.
RIVER 2 Series is a cut above the rest as the first portable power station in the world to get certified. With it's high safety standard, the TÜVRheinland certification means the security and reliability of RIVER 2 Series is guaranteed.
5-year Warranty
Our state-of-the-art Battery Management System (BMS) constantly monitors the voltage, current, and temperature of RIVER 2 with multiple aspects of protection, extending its life to the max.2
4 Ways to Charge
Charge anywhere.
With 4 different ways to top up the RIVER 2 Series, there's a recharge option no matter what.3 From fast AC to 12V in-car charging when you're on the go.
AC ChargingCar ChargingSolar ChargingUSB-C Charging
Why not harness renewable energy while you camp or head off on a trip? Plug in a couple of portable solar panels to fully recharge off-grid in as fast as 3 hours.
X-Boost Up to 600W
Small size. Big power.
RIVER 2 has an AC output of up to 300W. Need to power a blender or desktop? Crank it up to 600W with X-Boost mode to run up to 99% of consumer electronics.
Lightweight at only 3.5 kg
With a compact portable design, taking travel-friendly power off-grid has never been this easy. With a light-weight that's 30% lighter than the previous generation, RIVER 2 is ready to power all your outdoorsy escapades, from boondocking to BBQs at the beach.
<30ms EPS Auto-switch
Ultra-fast home backup switchover.
With a switchover speed of less than 30ms, you won't even know the power was down. Use RIVER 2 as an emergency power supply for overnight outages to keep essentials running from a CPAP machine to your fish tank.
EcoFlow App
Control at your fingertips.
Use the EcoFlow app to control and monitor RIVER 2, even from afar. View charging levels, customize settings, and adjust charging speeds, all from the convenience of your phone.
Learn More >
Power. Anywhere. Anytime.
1. RIVER 22.AC Charging Cable3. Car Charging Cable4. Quick Start Guide5. 110W Solar Panel6. Solar Charging Cable
*The solar charging cable is sent together with the solar panel.
256Wh (20Ah 12.8V )
Approximately 7.8lbs
9.6 x 8.5 x 5.7inches
AC Input
100-120V 50Hz/60Hz, 360W Max
Solar Input
11-30V 110W, 8A Max
Car Input
12V/24V, 8A, 100W Max
USB-C Input/Output
5/9/12/15/20V 3A, 60W Max
120V 50Hz/60Hz, 300W (Surge 600W)
DC Output
12.6V 8A, 100W Max
5V 2.4A 12W Max per port
DC5521 Output
Cell Chemistry
App Control
Wi-Fi, Bluetooth
Discharge Temperature
-10°C to 45°C (14°F to 113°F)
Charge Temperature
0°C to 45°C (32°F to 113°F)
Optimal Operating Temperature
20°C to 30°C (68°F to 86°F)
Storage Temperature
-10°C to 45°C (20°C to 30°C is best)/14°F to 113°F (68°F to 86°F is best)
1. Using RIVER 2 six times a week, 3000 full 100% cycles will last 9.6 years until it drops to 80%.
3. When charging and discharging at high wattage, RIVER 2 Max and RIVER 2 Pro may make a noise up to 62db.
Payment options through Affirm Canada Holdings Ltd. (“Affirm”). Your rate will be 0–31.99% APR (where available and subject to provincial regulatory limitations). APR offered is based on creditworthiness and subject to an eligibility check. Not all customers will be eligible for 0% APR. Payment options depend on your purchase amount, may vary by merchant, and may not be available in all provinces/territories. Actual payment option terms will be shown at checkout. A down payment (or a payment due today) may be required. Affirm accepts debit cards and PAD as forms of repayment on payment options. Select payment options may be eligible for repayment in the form of credit cards. Please review the terms and conditions of your credit card when using it as a form of repayment. Sample payment options may be: a $800 purchase could be split into 12 monthly payments of $72.21 at 15% APR, or 4 interest-free payments of $200 every 2 weeks. For more information, please seehttps://www.affirm.com/en-ca/how-it-works.
Thanks for sharing!
Select your language
