Already have an account? Sign In
Up to EcoCredits for cash deduction
Electric Vehicle Charging: With the grounding adapter, use a DELTA Pro or DELTA 2 Max/DELTA Max/DELTA 2 to charge your EV safely as an emergency backup power, giving you the extra mile.
For DELTA Pro:
For DELTA 2 Max, DELTA Max, DELTA 2:
Only use the USB-C Cable included with a portable power station grounding adapter. The Cable does not have any charging function, and other USB-C cables should not be used instead.
Adding product to your cart
Your shopping cart is empty
