EcoFlow NextGen 160W Portable Solar Panel EcoFlow NextGen 160W Portable Solar Panel EcoFlow NextGen 160W Portable Solar Panel EcoFlow NextGen 160W Portable Solar Panel
Regular price $299.00 CAD
Sale price $299.00 CAD Regular price $299.00
-$0
· ETFE coating; built to last
· IP68 rating protects against water and dust
· The solar to XT60 charging cable is included in EcoFlow portable solar panels
Accessories
$299 CAD
Generate even more energy
With the portable solar panel industry's first use of TOPCon solar technology,
we've raised the bar on conversion efficiency, reaching 25%.
Charge faster with a more compact panel.
Capture more solar with an adjustable angle
With a newly integrated solar angle guide and stand,
adjust the angle of the panel by 30 degrees in seconds to get the most sunshine at all times.
Durable and waterproof
With an IP68 waterproof rating, our NextGen 160W Solar Panel maintains its high performance even in extreme weather conditions, including rainfall. It's dust-resistant, too.
Designed to withstand high temperatures while still ensuring high levels of solar generation.
Lightweight and portable
Generate solar energy anywhere with our compact-designed panels. Fold away to store in your van or closet, pull them out in seconds to start using.
EcoFlow Solar Panel Comparison
Original vs. NextGen
NEW
EcoFlow NextGen Portable Solar Panel
EcoFlow Solar Panel
EcoFlow Solar Panel
Cell Type
N Type TOPCon
monocrystalline silicon
P Type PERC
Conversion Efficiency
Weight
(5.1 kg-7.2 kg)
(5.6 kg-9.5 kg)
Stand Type
30-60° Integrated Adjustable Stand
Separate Kickstand Case
Additional Feature
Integrated Solar Angle Guide
No Solar Angle Guide
What’s in the box
MC4 to XT60i Charging Cable
Protective Bag
Protective Bag
Quick Start Guide, Safety Instructions & Warranty Card
Rated Power
160W (±5W)
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25.00%
Weight (Solar Panel)
Approx. 12.3 lb (5.6 kg)
Unfolded: 23.6×63.4×1.0 in./600×1610×25 mm
Folded: 23.6×22.5×1.3 in./600×572×32 mm
Connector Type
MC4
Warranty (US)
12 months
Open Circuit Voltage
21.3V (Vmp 18.6V)
Short Circuit Current
9.1A (Imp 8.6A)
Waterproof & Dustproof
Select your language
