EcoFlow RAPID Charger (45W, Retractable Cable, GaN) - Black
EcoFlow RAPID Charger (45W, Retractable Cable, GaN) EcoFlow RAPID Charger (45W, Retractable Cable, GaN)
$42.99 CAD
Free Shipping on $70+
Regular price $42.99 CAD
Sale price $42.99 CAD Regular price $69.99
-$27
45W Fast Charging: Multi-port, single port max 45W output; Ultra-fast charging, compatible with various electronic devices (tablets, phones, earbuds, gaming consoles)
Space-Saving & Portable Design: Save desktop power resources with one charger that handles multiple devices. A retractable design prevents cable tangling, so no more messy tangles. A built-in flip-out wall plug saves more space.
Multi-Device Charger: 1× USB-C ports, 1× 70cm retractable USB-C cable
Color
Black
White
$42.99 CAD $69.99 -$27
Subscribe to get 5% off and updates of RAPID
Multi-Functional Fast Charging for Everyday Convenience
GaN Technology
45w Fast Charging
All-in-One Charging Solution
Powerful and Compact Design with GaN Technology
Boasting a volume smaller than an Apple 45W Adapter,this charger's compact design ensures it seamlessly fits into your setup without encroaching on space or interfering with other devices.
Ultra-fast charging, compatible with various devices (tablets, phones, earbuds, gaming consoles and more)
1h44min to fully charge an iPhone 16
1h21min to fully charge an Galaxy S25
Save desktop space with one charger that simultaneous handles the charging needs two USB-C devices. When travelling, its tangle-free design makes storage and transportation hassle-free.
- 45W USB-C output port
- 70 cm Retractable USB-C Cable
- Foldable Wall Plug
Advanced Durability
Superior Safety
Enhanced Stability and Reliability
Designed for a secure connection, the plug went through 4kg weight bearance tests and 3000-time plug and unplug tests without damage.The retractable cable has passed a 10,000-time twisting test, ensuring years of daily-use durability.
Advanced Protection, Maximum PerformanceProtected by EcoFlow's X-Guard
EcoFlow RAPID maintains its fast charging levels 24/7 with around-the-clock safety checks. Its temperature sensor tests and adjusts for overheating up to 60,000 timesevery minute, while the V0-level fireproof shell delivers robust external protection.
Versatile Length, Various Setups
At Home
Remote Work
Travel
At Home
At Home
Remote Work
Remote Work
Travel
Travel
Travel
Travel
45W Max Multi-Port Charging
Compatible with 99% of Daily-use Electronic Devices
45W Multi-Port Charging
One-Port
Two-Port
Learn More About EcoFlow
Dimension
61*55*35.2mm (Built-in Cable: 70cm)
Weight
133.2±10g
Total Output
45W
Output: Type-C Cable/Type-C2: 5V=3A/9V=3A/12V=3A/12V=3A/15V3A/20V-2.25A 45W Max
Type-C Cable+Type-C2:20W+20W 40W Max
Single Output
C1 (Cable): 45W
C2: 45W
Outlets
2
APP Support
No
Is it normal for the charger to get hot?
It is normal for the device surface to heat up under high power transmission. The device has multiple built-in protection mechanisms and can be used with confidence.
what devices are compatible?
This charger is compatible with laptops, phones, tablets, earphones, smartwatches, gaming consoles, and other devices with USB-C or USB-A ports, such as MacBook Pro/Air, iPhone, iPad, Dell XPS, and Samsung Galaxy.
PPS/PD3.2/PD2.0 ,QC4+/QC4.0/QC3.0/QC2.0/APPLE2.4A/BC1.2/DCP1.5A
Why can not some devices be charged at the maximun rated power?
This product is designed with high-strenght metal materials and a reinforced hinge structure. The pins have been tested for multiple folding times, ensuring excellent durabilite. Under normal use, frequent folding will not cause looseness or breackage, maintaining a stable connection and portabilith for a long time. To extend the service life, it is recommended to avoid excessive force or oblique operation when folding/unfolding.
How many times can the plug be folded? Is it easy to loosen or break?
This product is constructed with high-strength metal materials and a reinforced hinge design. The plug prongs have undergone multiple folding tests, demonstrating excellent durability. Under normal usage, frequent folding will not cause looseness or breakage, ensuring a stable connection and portability over the long term. To extend the product’s lifespan, it is recommended to avoid excessive force or angled operations when folding or unfolding.
What is the size of the adapter? How portable is it? Can it be carried in a carry-on bag on a plane?
The 65W model measures 52.5 × 51 × 51.3mm and the 45W model measures 61 × 55 × 35.2mm.Both models feature foldable plug designs for easy portability, making them suitable for daily commuting or business travel.
Campaign Period Period
EcoFlow RAPID Power Bank officially launches on August 25, 2025. The EcoFlow RAPID Power Bank Series Launch Campaign (hereinafter referred to as "campaign period") runs from August 25, 2025, 12:00 AM (PDT) to September 7, 2025, 11:59 PM (PDT).
Eligibility of Participants
This promotion is available to all Canada residents with a valid shipping address in continental Canada (Offers are not valid in Northwest Territories, Nunavut, or Yukon.) who are 18 years or older as of August 25, 2025 (hereinafter referred to as "Participants").
Launch Benefits
Benefit 1: Double EcoCredits+ Free Gift in Purchase
  • For orders with a pre-tax subtotal of $79.99 or more:
Receive one (1) free EcoFlow RAPID 20W GaN Charger with 60W Cable(MSRP: $24.99 CAD).
Limit one charger per order.
  • For orders with a pre-tax subtotal of $149.99 or more:
Receive one (1) free EcoFlow RAPID 65W GaN Charger with 100W Cable(MSRP: $69.00 CAD).
D.For canceled/returned orders: all double EcoCredits will be fully reversed, and for orders over $79.99, the undamaged charger must be returned with the product; partial refunds (including price adjustments) will proportionally deduct EcoCredits, with failure to return the charger resulting in its value being deducted from the refund amount.
Benefit 2: Get More for Less
A. 5-10 units purchased: 7% discount for all units; 11-20 units purchased: 9% discount for all units;10+ units purchased: 10% discount for all units. The discount applies automatically at checkout.
B. Only valid for the same product in the same order on our official EcoFlow website (ca.ecoflow.com). Cannot be combined with other promotions.
C. This discount can't be stacked with other coupons.
D. If you request a partial return, the applicable discount will be recalculated based on the remaining quantity. And the refund amount will be adjusted accordingly.
E.If a product purchased through a referral link is returned or exchanged, it will follow the standard return and exchange procedures as outlined in the EcoFlow Return and Refund Policy.
F. The referrer's unique referral link may not be shared, sold, or used in any way except by the referrer alone to obtain qualified referrals; referrers are limited to one qualified referral for each referred customer; in other words, additional/repeat purchases made by a referred customer are not counted as additional qualified referrals. Referral links shared to or obtained through other sources (such as through a posting to a third-party intermediary or website) will not be honored.
G. If the referrer and referee share an IP/device, only the referred person may receive a reward. EcoFlow may prohibit a referrer from participating in the program or receiving a credit or reward, at EcoFlow's sole discretion, if EcoFlow determines that such referrer is attempting to undermine the fairness, integrity, or legitimate operation of the program in any way by cheating, hacking, deception, or any other unfair playing practices or intending to annoy, abuse, threaten, or harass any other referrers or any representatives of EcoFlow.
H.For other questions regarding the referral program, please refer to:https://www.ecoflow.com/ca/referral
Coupon Terms
C. Coupons are valid only for customers in Canada and may only be used on ca.ecoflow.com.
General Terms
B. Delivery service is unavailable for orders shipped to Northwest Territories, Nunavut, or Yukon. Please refer to our shipping policyfor more details.
E. During the promotion, all orders must comply with EcoFlow's purchase agreement and return policy.
This promotion is not available for wholesale or distributor orders.
Select your language
