Buy EcoFlow DELTA Pro Portable Power Station - DELTA Pro + 400W Solar Panel + Free Transfer Switch - EcoFlow CA
EcoFlow CA
EcoFlow DELTA Pro Portable Power Station - Disaster EcoFlow DELTA Pro Portable Power Station - Disaster EcoFlow DELTA Pro Portable Power Station - Disaster EcoFlow DELTA Pro Portable Power Station - Disaster
$5,399.00 CAD
Hot
Video
Hot
Regular price $5,399.00 CAD
Sale price $5,399.00 CAD Regular price $6,397.00
-$998
Up to EcoCredits for cash deduction. Log in
$699 CAD
$5,399 CAD $6,397 -$998
Title Title
Title
Description
Power for any situation.
All the AC output you’ll need.
A single DELTA Pro unit packs a 3600W AC output, which can be expanded up to 4500W with X-Boost technology. Power 99.99% heavy-duty devices at home, outdoors, or at work. You can even pair two units together to achieve 7200W.
Multi Charge delivers record-breaking speeds at 6500W. To reach 6500W, you can opt for these charging methods.
Simple, sustainable, and affordable whole-home backup power solutions with an output power of up to 7200W and a whopping 21.6kWh capacity for security and comfort. Easily chain together two DELTA Pros using the Double Voltage Hub. The solution provides a convenient home battery system without rewiring or running dangerous extension cables through your home.
A clean energy alternative.
Power your entire home.
With the Double Voltage Hub, DELTA Pro* provides unparalleled AC output of up to 7200W and 240V. Run 99% of all home appliances, even high-wattage clothes dryers and electric heaters, so you can keep your home running smoothly.*Double Voltage Hub requires two EcoFlow DELTA Pro units.
Smart energy management.
Travel without limits.
Connect DELTA Pro with an Extra Battery for a huge capacity of 7.2kWh, and stay powered for up to a week*. Run daily essentials such as a fridge, laptop, coffee maker, and even the air conditioner. You'll have the power to experience all that nature has to offer.
EV backup charging solution.
Power that means business.
Unleash your creativity.
Take energy on the go and get the creative juices flowing. Whether you're a filmmaker capturing precious moments or just want to work on the go, DELTA Pro's impressive output and large capacity can power all your equipment, ensuring a smooth workflow no matter where you are.
Customize a simple, reliable and sustainable home backup system to keep your essential circuits running when a blackout hits. Ensure peace of mind with the easily integrated whole-home backup kit: DELTA Pro, Transfer Switch, and Power Cord.
All the AC ports support 3600W (US) output?
For US version, you can only have max 3600W AC output on the 30A AC port.
What's the max input DELTA Pro can achieve?
How many solar panels can I use at the same time?
Can I run a 240V device on the 120V US version?
How do I update the firmware?
How do I recharge DELTA Pro at 200V-240V in a 100V-120V region?
3600Wh
Extra Battery
4500W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
Anderson Port
12.6V, 30A
AC Charging Input
Solar Charging Input
1600W Max, 11-150V, 15A Max
Car Charging Input
Support 12V/24V battery, 8A
Connection
Wi-Fi, Bluetooth
Approx. 99lbs/45kg
Dimension
