EcoFlow DELTA 3 Ultra Plus (3072Wh) Portable Power Station EcoFlow DELTA 3 Ultra Plus (3072Wh) Portable Power Station EcoFlow DELTA 3 Ultra Plus (3072Wh) Portable Power Station EcoFlow DELTA 3 Ultra Plus (3072Wh) Portable Power Station EcoFlow DELTA 3 Ultra Plus (3072Wh) Portable Power Station EcoFlow DELTA 3 Ultra Plus (3072Wh) Portable Power Station EcoFlow DELTA 3 Ultra Plus (3072Wh) Portable Power Station
$1,999.00 CAD
Regular price $1,999.00 CAD
Sale price $1,999.00 CAD Regular price $3,599.00
-$1,600
1. 3600W Powerful Output: 7200W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 4600W such as clothing steamers, electric dryers, lawnmowers, and electric frying pans.
2. 3-11kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop.
3. Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most.
3. 6 Ways to charge, Ready in Just 48 Mins: Ready in Just 48 Mins (0-80%) with Solar + Generator Dual Charging
4. Long-Lasting, Durable, and Reliable: Equipped with automotive-grade full-tab LFP cells, offering 10 years of reliable power, 24/7 protection BMS, Class-B certification, and EV-grade CTC structure that protects against overnight condensation and off-road bumps during transport.
5. 2 Easy Ways to Connect to Your Home: Manual Transfer Switch and Inlet Box.
6. 10ms Auto-Switch: keep critical devices like NAS systems and servers running smoothly.
7. 25dB Whisper-Quiet Operation: Ultra-low noise (≤25dB at 600W).
8. OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. Storm Guard Mode automatically activates backup power before extreme weather hits. Self-Powered Mode and Scheduled Tasks save you money daily.
9. Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Product
$1,999 CAD $3,599 -$1,600
3kWh Portable Power Station with Smart Output Priority Tech
Long-Lasting Portable Home Backup. Unmatched Performance.
3600W Output, 7200W Surge—Powerful. Stable. Built to Handle It All
DELTA 3 Ultra Plus (3072Wh) delivers 3600W rated-output (7200W surge) , with X-Boost™ 3.0 technology, it supports devices up to 4600W—effortlessly handling heavy-duty appliances. The inverter samples AC voltage and current every 33μs with high precision with a DSP chip, ensuring a pure sine wave output with beyond grid-level stability—ideal for powering sensitive electronics reliably.
Kitchen
Living Room
Laundry Room
Office
RV Camping
Garage
Easily Scales Up—From Hours to Days
3–11kWh expandable capacity
Compatible with Smart Generators for unlimited runtime
Half-Day Outage
1-Day Outage
2-Day Outage
3-Day Outage
Covers essential power needs during a 4–10 hour outage—keeping food fresh, heat running, lights on, and communication devices charged. [3]
Require connecting 1 × DELTA 3 Ultra Plus + 2 × DELTA 3 Max Plus Smart Extra Battery or 1 × DELTA 3 Ultra Plus + 2 × DELTA Pro 3 Smart Extra Battery with EcoFlow Smart Extra Battery Expansior Adapter. The EcoFlow Extra Battery Expansion Adapter has released Canada local now.*
Delivers 1 days of outage protection—ensuring uninterrupted cooking, heating, lighting, and connectivity. [3]
Powers home essentials for up to 2 days [5] with 7kWh capacity—keeping your kitchen running, lights on, and devices connected. [4]
Supports a family of four through 3 days of everyday living [3] with 11kWh capacity—keeping food fresh, heat running, lights on, and entertainment devices charged. [5]
Go Hybrid—Extend Backup with a Smart Generator
Pair DELTA 3 Ultra Plus (3072Wh) with an EcoFlow Smart Generator [6] to achieve longer runtime—automatically switching between fuel and battery to keep you powered through multi-day outages or off-grid adventure.
6 Ways to Charge Up — Ready in Just 48 Mins [1]
6 Ways to Charge Up — Ready in Just 48 Mins <sup>[1]</sup>
Wall Charging
Generator Charging
Alternator Charging
Solar + Alternator Dual Charging
1800W Input, 0-80% in 89 mins. [9] EcoFlow’s exclusive Storm Guard Mode [10] monitors severe weather alerts and automatically triggers AC charging remotely using industry-leading X-Stream fast charging tech—so it can be ready long before a disaster hits.
Charges at up to 3200W via smart generator—0–80% in 53 minutes. With exclusive Generator Auto Start/Stop Mode, [11] the EcoFlow Smart Generator 4000 (Dual Fuel) recharges DELTA 3 Ultra Plus (3072Wh) automatically when battery levels run low—delivering hands-free backup power for storms, outages, and off-grid use.
1600W input, 0–80% in 101 mins. After the storm clears, just 101 mins of sunlight is all it takes to recharge DELTA 3 Ultra Plus (3072Wh). Pair it with EcoFlow 400W Solar Panels (25% high-efficiency) for reliable power during camping trips, van life, or off-grid living. [12]
1000W Input, 0-80% in 142 mins. With EcoFlow Alternator Charger Plus 1000, [13] get ready in just over 2 hours while on the move—10× faster than conventional solutions. [14]
3960W Input, 0-80% in 48 mins. Fastest charge in just 48 mins with 3960W dual input from solar panels and the Smart Generator 4000.
2600W Input, 0-80% in 60 mins. Dual input from 1600W solar and 1000W alternator charging keeps you powered faster than ever, even on the go.
Built to Last
From battery chemistry to structural design, DELTA 3 Ultra Plus (3072Wh) is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years. [2]
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Battery Protection
CTC Structure
Durable Qualities
Class B Certified
25dB [18]
EcoFlow’s advanced BMS uses a high-performance ARM Cortex chipset and intelligent algorithms to monitor your battery in real time. By tracking SOC, SOH, temperature, and more, it ensures peak performance, extended battery life, and worry-free operation.
Built with a cell-to-chassis (CTC) structure, DELTA 3 Ultra Plus (3072Wh) is drop-resistant (0.2m) —protecting against overnight condensation and off-road bumps during transport. You get stable power even in the most demanding conditions. [17]
DELTA 3 Ultra Plus (3072Wh) keeps your power flowing through freezing cold, scorching heat, humid environments (95% humidity tolerance), or coastal air (5% salt spray resistance). [17]
Certified to Class B EMC standards, it won’t interfere with TVs, Wi-Fi, or other home electronics.
Powered by X-Quiet™ 3.0, EcoFlow’s stepless fan control adjusts airflow smoothly to maintain precise thermal regulation—keeping your home or workspace peacefully quiet, even under heavy loads.
Monitor your energy usage, savings, and solar generation—all with one intuitive dashboard. Easily track battery status, real-time electricity rates, and financial savings.
Compatibility
What's In The Box
[1] 0-80% in 48 minutes was measured in optimal conditions using the EcoFlow Smart Generator 4000 (Dual Fuel) and Solar Panels, total 3960W input.
[2] Based on proper product usage, DELTA 3 Ultra Plus (3072Wh) is estimated to have a lifespan of approximately 10 years, according to internal simulation test data. This information is for reference only; actual user experience may vary.
[3] Multiple appliances' backup time based on ideal conditions; actual results may vary.
[4] Require connecting 1*DELTA 3 Ultra Plus (3072Wh) + 2* DELTA 3 Max Plus Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
[5] Require connecting 1*DELTA 3 Ultra Plus (3072Wh) + 2* DELTA Pro 3 Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
[6] EcoFlow Smart Generators are sold separately.
[7] Manual Transfer Swith is sold separately.
[8] This accessory should be purchased separately.
[9] All charging speed data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
[10] Feature requires preset activation via the EcoFlow App.
[11] To enable this feature, connect DELTA 3 Ultra Plus (3072Wh) to the Smart Generator using the charging cable and enable the preset in the EcoFlow App. Communication is handled via Bluetooth or Wi-Fi.
[12] EcoFlow Solar Panels are sold separately.
[13] EcoFlow Alternator Charger Plus 1000 will be launched soon and it's sold separately.
[14] Compared with car cigarette port charging.
[15] Refers to the internal resistance of EF Full-Tab LFP Cells being 1.5mΩ, which is 25% lower than the 2mΩ internal resistance of the previous EF #C33 Battery Cell.
[16] A 25% reduction in single-cell internal resistance. According to the heat generation formula Q = I²Rt, under the same current, a 25% reduction in resistance leads to a proportional 25% decrease in heat generation.
[17] Unless otherwise noted, all above data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
[18] Noise levels measured at 1m under 25°C ambient: ≤25dB (600W) for charging/discharging.[19] Unless otherwise noted, all images, videos, and screen display contents about the product itself on this page are for reference only. Actual product effects (including but not limited to appearance, color, and size) and screen display contents (including but not limited to backgrounds, UI, and illustrations) may vary.
[20] *DELTA 3 Ultra Plus works with:DELTA 3 Max Plus Smart Extra Battery, DELTA Pro 3 Smart Extra Battery, EcoFlow 800W Alternator Charger, EcoFlow Alternator Charger 600, EcoFlow Alternator Charger Plus 1000.
33.7±0.6kg
Dimensions (HWD)
613.1mm×327.71mm×394.95mm
Rated Capacity
3072Wh 51.2V 60Ah
Cell Chemistry
LFP(LiFePO4)
120V~60Hz 3600W total (surge 7200W),
20A(x4) Max per port, 30A(x1) Max per port
X-Boost
4600W
USB-A(x1): 5V-3A/9V-2A/12V-1.5A, 18W Max
USB-C(x1): 5/9/12/15V-3A, 20V/28V--5A, 140W Max(HID)
USB-C(x2): 5/9V/12V/15V-3A 20V-2.25A, 45W Max per port, total 45W
12V DC Output Port
12.6V-30A, 378W Total
Anderson: 30A Max (Shared power with car cigarette lighter)
Cigarette Lighter Output Port
12.6V-10A, 126W Total
CAR:10A Max (Shared power with Anderson port)
AC Input (Charge Only)
100-120V~15A 50/60Hz
Maximum PV Input Power(W)
1600W
Optimal operating temperature
20°C to 30°C (68°F to 86°F)
Charge Temperature
0°C-45°C(32°F-113°F)
Discharge Temperature
-10 to 45°C(14°F-113°F)
Storage Temperature
5-Year Warranty
Communication Method
Wi-Fi & Bluetooth
UPS
<10ms
Thanks for sharing!
Select your language
