EcoFlow DELTA 3 Portable Power Station (Refurbished) EcoFlow DELTA 3 Portable Power Station (Refurbished) EcoFlow DELTA 3 Portable Power Station (Refurbished)
$549.00 CAD
Regular price $549.00 CAD
Sale price $549.00 CAD Regular price $999.00
-$450
* 5 fast recharging methods (AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), Multicharging)
*5-year warranty
EcoFlow Smart Generator 3000 (Dual Fuel)
$1,099 CAD
$499 CAD $849 CAD
$1,099 CAD
$499 CAD $849 CAD
$1,099 CAD
$499 CAD $849 CAD
$549 CAD $999 -$450
AC Charging
Car Charging
Generator Charging
Multi-Charging
With EcoFlow's X-Stream technology and 1500W AC input, DELTA 3 charges from 0-100% in 56 minutes. A 30-minute charge provides hours of emergency backup before a power outage.
Solar Input with 500W MPPT, Full Charge in 2 hrs²
EcoFlow DELTA 3 with 500W MPPT charges fully in 2 hrs, even with limited sunlight. Outdoors, it recharges during lunchtime.
Hybrid Power with Generator, Full Charge in 56 Minutes with 1500W AC Input⁴
Multi-Charging (AC + Solar), Full Charge in 56 Minutes with 1500W Input⁵
With 1500W max input, it takes 56 minutes to fully charge. During daily use, plug in both AC and solar to charge DELTA 3 , prioritizing solar to save money.
EcoFlow DELTA 3 supports 99% of household devices, including refrigerators, TVs, and computers. Plus, with X-Boost, continuously power appliances over 2200W, such as ovens (2150W), hair dryers (1800-2500W), and kettles (1200-3000W). Perfect for home backup, RV, and outdoor usage, this powerhouse ensures you're never left in the dark.
Home backup
Outdoors
RV
Professional work
30 dB Ultra-quiet Operation.
An intelligent energy management system powered by EcoFlow Oasis.
*EcoFlow DELTA 3 are compatible with Extra Battery of DELTA 3 Plus, DELTA Pro 3, DELTA 2 Max, DELTA 2.
Smaller Size, Same Power
1 Extra Battery, 5 x the Power
LFP Battery
IP65 Battery Pack
BMS
13 Outputs
Compact and lightweight
Approx. 397.6*202*283.6mm
(15.7*8.0*11.2in.)
Approx. 12.5kg
(27.6 lbs)
1024 Wh
Extra Battery
Support DELTA 2 EB, DELTA 2 Max EB, DELTA Pro 3 EB, and DELTA 3 EB (Up to 5kWh)
Total Output Ports
13
2200W
USB-A Output (Fast Charge)
2 ports, 18W Max
2 ports, 100W Max
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A Max
AC Charging
1500W
DC Charge Input, 11V-60V 500W Max
1500W
Car Charging
800W, in 1.3 Hour
LFP (LiFePO4 battery)
4000 cycles to 80+% capacity
Connectivity
IP65
UPS
<10ms
Noise
600W<30db;1200W<40db
5 years
Footnotes
* Download the EcoFlow PowerManager App to activate the NAS support function on your computer, then install the NUT Server software on your NAS system, connect your DELTA 3 Plus, and activate HID support. The formal launch version will come later in December.
Thanks for sharing!
Select your language
