EcoFlow DELTA 3 Series Solar Generator (PV160W) | EcoFlow CA - DELTA 3 Plus + 160W Portable Solar Panel + 800W Alternator Charger
EcoFlow DELTA 3 Plus + 160W Solar Panel + 800W Alternator Charger
$1,899.00 CAD
Regular price $1,899.00 CAD
Sale price $1,899.00 CAD Regular price $2,397.00
-$498
⏰48Hrs Flash Sale Ends in
Days
Hours
Minutes
Seconds
• Built to last 6x longer: Get 10 years of daily use until hitting 80% off its original capacity. That's down to its LFP battery chemistry giving you 3000+ cycles.
• Huge AC output: With X-Boost mode get up to 2200W output power to run 99% of home appliances.
• Capture more energy: 99% MPPT efficiency maximizes solar generation anytime.
• Up to 25% conversion with a unique bifacial design to guarantee a fast solar charging speed.
• Comprehensive warranties: DELTA 3 Plus/DELTA 3 includes a 5-year warranty and 12 months for the NextGen 160W Portable Solar Panel.
Subscribe DELTA 3 Plus for latest updates
$1,899 CAD $2,397 -$498
DELTA 3 Series
AC Charging
Car Charging
Generator Charging
Multi-Charging
Solar Input with 1000W MPPT, Full Charge in 70 Minutes²
EcoFlow DELTA 3 Plus with 500W MPPT × 2 charges fully in 70 minutes, even with limited sunlight. Outdoors, it recharges during lunchtime.
With 1500W max input, it takes 56 minutes to fully charge. During daily use, plug in both AC and solar to charge DELTA 3 Plus, prioritizing solar to save money.
EcoFlow DELTA 3 Series supports 99% of household devices, including refrigerators, TVs, and computers. Plus, with X-Boost, continuously power appliances over 2600W, such as ovens (2150W), hair dryers (1800-2500W), and kettles (1200-2600W). Perfect for home backup, RV, and outdoor usage, this powerhouse ensures you're never left in the dark.
Outdoors
RV
Home backup
Professional work
30 dB Ultra-quiet Operation.
*EcoFlow DELTA 3 Series power stations are compatible with the following Extra Battery models via an Alternator Charger XT150 Output Cable: DELTA 3 Extra Battery, DELTA 2 Extra Battery, DELTA 2 Max Extra Battery, and DELTA Pro 3 Extra Battery.
Smaller Size, Same Power
1 Extra Battery, 5 x the Power
LFP Battery
IP65 Battery Pack
BMS
13 Outputs
Compact and lightweight
Net Weight (kg)
≤12.5kg
1024 Wh
Extra Battery
Supports the following Extra Battery models via an Alternator Charger XT150 Output Cable: DELTA 3 Extra Battery, DELTA 2 Extra Battery, DELTA 2 Max Extra Battery, and DELTA Pro 3 Extra Battery.
Total Output Ports
13
2600W
USB-A Output (Fast Charge)
2 ports, 36W Max
2 ports, 140W Max
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A Max
AC Charging
1500W
2 ports, DC Charge Input, 11V-60V 500W Max*2
1500W
Car Charging
800W, in 1.3 Hour
LFP (LiFePO4 battery)
4000 cycles to 80+% capacity
Connectivity
IP65
UPS
<10ms
Noise
600W<30db;1200W<40db
5 years
Footnotes
Select your language
