EcoFlow 175W Rigid Solar Panel - Refurbished
$249.00 CAD
Regular price $249.00 CAD
Sale price $249.00 CAD Regular price $349.00
-$100
· Up to 25% cutting-edge solar conversion efficiency rate
· Use TOPcon solar cells that work well in low light and high-temperature environments, maintaining high power output.
· Built to last with an IP68 waterproof rating
· Use in various scenarios, including Class B vans and home
· Fast and easy installation
$249 CAD $349 -$100
Generate even more energy
Utilizing Revolutionary N-Type TOPCon Solar Cells
With N-Type TOPCon solar cell technology, we've raised the bar on conversion efficiency, reaching heights of 25%. Generate and store more more sunshine than ever before.
Designed to weather any storm
Coated with Highly Protective Lamination and Tempered Glass
Built with a robust anti-corrosive aluminum frame, it's designed for years of solar-ray collection. Its TOPcon cells are coated with highly protective lamination and tempered glass and comes with an IP68 waterproof rating to enhance performance and offer long-lasting durability.
With just the right specs to maximize roof space
Industry-first design exclusively for Class B vans
Long-lasting solar solution for your home
Perfectly Tailored for Home Use
Ready to install on any surface
Pre-Drilled Slots for Secure Mounting
With pre-cut holes along the panel's perimeter, the 175W rigid panel is ready to mount on your van or off-grid build. Pair with the Rigid Solar Panel Mounting Feet for a secure attachment to any surface.
Just plug and play with your power system
Universally Compatible Solar Cable
Using an all-inclusive solar connector, connect with any existing third-party solar system. Charge 48V power systems and portable power stations with single or multiple panels.
EcoFlow 175W Rigid TOPCon Solar Panel Charging Times
How to choose your solar panel
What‘s In The Box
Rated Power
175W (+/-3W)
Cell Type
N Type TOPCon Monocrystalline Silicon
Efficiency Rating
Up to 25%
Weight (Solar Panel)
20.5 lb (9.3 kg)
46.3×30×1.2 in (1176 x 762 x 30 mm)
Connector Type
Photovoltaic Connectors (Adaptable to MC4 Connectors)
Warranty (US)
5 Years
Waterproof & Dustproof Rating
Short Circuit Current
8.3 A
Open Circuit Voltage
25.5 V
Maximum Operating Voltage
22.3V
7.85A
Thanks for sharing!
Select your language
