EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated)
Regular price $5,499.00 CAD
Sale price $5,499.00 CAD Regular price $8,598.00
-$3,099
Only $7,649 for the DELTA Pro Ultra + Extra Battery + Free Trolley. Disccount auto-applied at checkout
The only
portable power station certified to both UL1973 and UL9540, offering extreme reliability for home use.
-6kWh-90kWh capacity, whole house backup for weeks with comfort
-Auto-switchover, prolonged backup, and energy bill savings with EcoFlow Smart Home Panel 2
-5 Charging Options, even plan B has a plan B
Battery automatically starts self-heating if the temperature is lower than 0℃, allowing the battery to run as normal
Help me Choose
Get Free Quote
Customer Support Hotline
Installation Service
Installation Consulting Service for EcoFlow Smart Home Panel 2
Enjoy a free installation consultation when you purchase the Smart Home Panel 2. We will connect you with a fully-trained local electrician and provide tracking from order to installation. Share your information or contact our support team directly: support@ecoflow.com
1
Order Placement
2
Schedule Installation
3
Finalize Appointment
4
Installation by Certificated Electricians
*Service includes consultation only, not installation.
How does it work?
Check out the exclusive bundle, which includes the installation fee, for a seamless end-to-end service from order to installation.
1
Order Placement
2
3
Installation by Electrician
*Check the detailed Terms and Conditons at the bottom of this page.
Please confirm that installation service is available in your area before making a purchase.
We regret to inform you that our installation services are temporarily unavailable in your area. Please share your information with us for free online technical support or, depending on your location, help accessing on-site installation services.
The installation service is available in your area. Please share your information with us for free online technical support or depending on your location, help accessing on-site installation services
Please enter a valid U.S. ZIP code (e.g. 12345).
The Federal Solar Tax Credit, or the Residential Clean Energy Credit, provides a 30% financial incentive for U.S. taxpayers installing residential solar systems, including battery storage with a capacity above 3kWh. This credit helps reduce upfront costs, making solar and storage solutions more affordable for homeowners.
Want to Know When Prices Change?
Subscribe to a Price Alert, and we'll notify you when the price for this product changes.
You have successfully subscribed to the price drop alert
Call us at +1 231-888-7164 with any pre-order or after-sale questions.
Recommend
EcoFlow Trolley (DELTA Pro Ultra)
$299 CAD $399 CAD
EcoFlow DELTA Pro Ultra Smart Extra Battery (Recommended Accessory)
$3,799 CAD $4,799 CAD
$299 CAD $399 CAD
$299 CAD $399 CAD
Subscribe DELTA Pro Ultra for latest updates
$5,499 CAD $8,598 -$3,099
The Most Powerful Whole-Home Backup Solution
Month-Long Power Security.
6-90kWh Capacity
One Unit Covers Every Appliance.
One Hour Of Solar For One Day Of Power.
5.6kW-16.8kW Solar Input
By Leveraging High And Low-PV Technologies, A Single Inverter Sets New Portable Solar Input Standards With A 5.6kW Input*. Connect Three Inverters For A Monumental 16.8kW, Gaining A Full Day's Home Energy In 60 Minutes. Whether You Prefer A Portable Setup Or A Rooftop Solar System, You Can Achieve True Energy Independence.
Flexible Solar Systems
Rigid Solar System
With Its Flexible Plug-And-Play Design And Unrivaled Solar Input, EcoFlow DELTA Pro Ultra Empowers You To Tailor Your Solution To Fit Your Energy Needs. EcoFlow DELTA Pro Ultra Includes A PV Locking Feature, Assuring Safety And A Solid Energy Connection.
Always In Charge
With a Generator or EV pile
Always In Charge
Always In Charge
You Won't Even Notice The Grid Was Down.
0 Ms Downtime, 0 DB Silent Backup
Peace of mind with an advanced design.
EcoFlow X-Cooling
Boost Performance with BMS
Our state-of-the-art LFP tech and advanced battery management system (BMS) regulates vital data, ensuring the safety, longevity, and high performance of EcoFlow DELTA Pro Ultra.With each battery offering a cycle life of 3500+, you'll get years of use before capacity drops to 80%. Even then, it keeps powering on.
Operating temperatures: -20°C to 45°C
290V high voltage tolerance
6144Wh, 102.4V⎓60A
30kWh (5 x DPU Battery)
AC Continuous Output
7200W
Expanable Capacity(System*)
90kWh (15 x DPU Battery)
AC Surge Output
10.8kW
Scalability(System*)
21.6kW
IP Rating
IP54
Battery Cycle Life
UPS
DC Output
12.6V⎓30A, 378W Max
AC Output Socket (Backup UPS)
2 x 120V, 20A Max per port
1 x 120V/240V, 30A Max
USB-A
AC Output Socket (Online UPS)
1 x 120V, 30A Max
USB-C
AC Input
Solar Charging Input
Total 5600W, 2 ports
Inverter Dimension
Inverter Net Weight
31.7 kg (70 lb)
Battery Dimension
Battery Net Weight
50.7 kg (111.8 lb)
5-year warranty
Connection
Bluetooth & Wi-Fi & 4G
Discharging temp
-20°C to 45°C | -4°F to 113°F
Charging temp
Storage temp
Select your language
