EcoFlow DELTA Pro Ultra | Home Backup Power - EcoFlow CA | DELTA Pro Ultra + Smart Home Panel 2
EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated)
$8,199.00 CAD
Regular price $8,199.00 CAD
Sale price $8,199.00 CAD Regular price $11,297.00
-$3,098
-The only portable power station certified to both UL1973 and UL9540, offering extreme reliability for home use.
-6kWh-90kWh capacity, whole house backup for weeks with comfort
-Auto-switchover, prolonged backup, and energy bill savings with EcoFlow Smart Home Panel 2
-5 Charging Options, even plan B has a plan B
Battery automatically starts self-heating if the temperature is lower than 0℃, allowing the battery to run as normal
Help me Choose
Calculate rebates
Explore financing options
How to apply rebates
Customer Support Hotline
Get Free Quote
Ontario's Home RenovationSavings Program
BC Hydro rebates
Receive a $300 rebate per kWh, up to a maximum of $5,000 CAD
DELTA Pro Ultra + Smart Home Panel 2 (6kWh)
$1,800
DELTA Pro Ultra + Smart Home Panel 2 + Extra Battery (12kWh)
$3,600
DELTA Pro Ultra + Smart Home Panel 2 + 2 Extra Battery (18kWh)
$5,000 (max)
Receive a $500 rebate per kWh of installed storage capacity, up to a maximum of $5,000 CAD
$3,000
$5,000 (max)
$5,000 (max)
Canada Greener Homes Loan
Toronto Home EnergyLoan Program
Eligible Canadian homeowners can apply for an interest-free loan of up to $40,000 to support energy-efficient home upgrades, including solar panels, heat pumps, insulation, and battery storage systems, with repayment terms of up to 10 years. For more details, please visit the official website.
Eligible Toronto homeowners can borrow up to $125,000 for home energy upgrades, including rooftop solar PV panels and battery storage, with repayment terms of up to 20 years. For more details, go to the official website.
How to Claim Your Solar & Battery Rebate
Based on Ontario's Home Renovation Savings Program & BC Hydro rebates
1
Confirm your eligibility
Check if your home qualifies for solar and storage rebates.
2
Choose a Contractor & Get Approval
Find an EcoFlow Certified Contractor who can help submit the required pre-installation form.*Be sure to contact the contractor before making any purchase to ensure rebate eligibility.
3
Complete Your Upgrades
Purchase your equipment and have your licensed contractor install the system.
4
Receive Your Rebate
After your contractor submits all required documentation and your application is approved, you'll receive your rebate.
Call us at +1 231-888-7164 with any pre-order or after-sale questions.
Recommend
EcoFlow Trolley (DELTA Pro Ultra)
$299 CAD $399 CAD
EcoFlow DELTA Pro Ultra Smart Extra Battery (Recommended Accessory)
$3,799 CAD $4,799 CAD
$299 CAD $399 CAD
$299 CAD $399 CAD
$299 CAD $399 CAD
$299 CAD $399 CAD
Subscribe DELTA Pro Ultra for latest updates
$8,199 CAD $11,297 -$3,098
The Most Powerful Whole-Home Backup Solution
Month-Long Power Security.
6-90kWh Capacity
One Unit Covers Every Appliance.
One Hour Of Solar For One Day Of Power.
5.6kW-16.8kW Solar Input
By Leveraging High And Low-PV Technologies, A Single Inverter Sets New Portable Solar Input Standards With A 5.6kW Input*. Connect Three Inverters For A Monumental 16.8kW, Gaining A Full Day's Home Energy In 60 Minutes. Whether You Prefer A Portable Setup Or A Rooftop Solar System, You Can Achieve True Energy Independence.
Flexible Solar Systems
Rigid Solar System
With Its Flexible Plug-And-Play Design And Unrivaled Solar Input, EcoFlow DELTA Pro Ultra Empowers You To Tailor Your Solution To Fit Your Energy Needs. EcoFlow DELTA Pro Ultra Includes A PV Locking Feature, Assuring Safety And A Solid Energy Connection.
Always In Charge
With a Generator or EV pile
Always In Charge
Always In Charge
You Won't Even Notice The Grid Was Down.
0 Ms Downtime, 0 DB Silent Backup
Peace of mind with an advanced design.
EcoFlow X-Cooling
Boost Performance with BMS
Our state-of-the-art LFP tech and advanced battery management system (BMS) regulates vital data, ensuring the safety, longevity, and high performance of EcoFlow DELTA Pro Ultra.With each battery offering a cycle life of 3500+, you'll get years of use before capacity drops to 80%. Even then, it keeps powering on.
Operating temperatures: -20°C to 45°C
290V high voltage tolerance
6144Wh, 102.4V⎓60A
30kWh (5 x DPU Battery)
AC Continuous Output
7200W
Expanable Capacity(System*)
90kWh (15 x DPU Battery)
AC Surge Output
10.8kW
Scalability(System*)
21.6kW
IP Rating
IP54
Battery Cycle Life
UPS
DC Output
12.6V⎓30A, 378W Max
AC Output Socket (Backup UPS)
2 x 120V, 20A Max per port
1 x 120V/240V, 30A Max
USB-A
AC Output Socket (Online UPS)
1 x 120V, 30A Max
USB-C
AC Input
Solar Charging Input
Total 5600W, 2 ports
Inverter Dimension
Inverter Net Weight
31.7 kg (70 lb)
Battery Dimension
Battery Net Weight
50.7 kg (111.8 lb)
5-year warranty
Connection
Bluetooth & Wi-Fi & 4G
Discharging temp
-20°C to 45°C | -4°F to 113°F
Charging temp
Storage temp
Select your language
