EcoFlow DELTA Pro Ultra X Whole-Home Backup Power EcoFlow DELTA Pro Ultra X Whole-Home Backup Power EcoFlow DELTA Pro Ultra X Whole-Home Backup Power
$10,999.00 CAD
Regular price $10,999.00 CAD
Sale price $10,999.00 CAD Regular price $14,097.00
-$3,098
To enable whole-home backup power, the DELTA Pro Ultra X Series must be used with the Smart Home Panel 3 and Smart Gateway to integrate with the home’s electrical system. The Smart Home Panel 3 and Smart Gateway are sold separately and are not currently available in Canada.
·100% Whole-Home Power Station: Delivers 12–36kW output and 12–180kWh capacity.
·Smart & Reliable When It Matters Most, 20ms Auto switchover
·Save up to $4,000/year, 3-Year ROI
·End-to-End System Protection, The Highest Safety Standard
*12kW/12kWh based on standard bundle (1 × EcoFlow DELTA Pro Ultra X Inverter + 2 × Smart Extra Batteries). Max 36 kW / 180 kWh with expansion. Actual performance varies by configuration.
Recommend
EcoFlow 500W Solar Kit (4 x 125W Bifacial Modular Solar Panel)
$1,199 CAD
25% Conversion Rate
$1,199 CAD
25% Conversion Rate
$10,999 CAD $14,097 -$3,098
Whole-Home Power. Unbound.
High Power. High IQ.
DELTA Pro Ultra X scales from 12 to 36kW. With a new Adaptive Start algorithm, it intelligently identifies connected appliances and tailors startup for each, seamlessly handling surges up to 45kW and high-demand appliances like a 5-ton AC.
Get Through Any Outage
12–180kWh Capacity—Power That Lasts
Generator-Ready for Unlimited Backup
10kW Solar Surge
10kW Solar Surge
10kW Solar Surge
Start with 12kWh. Scale instantly to 180kWh
with up to 30 plug-in expansion batteries—no tools, no hassle. Power grows with your needs.
With the EcoFlow FlowMaster Generator Rectifier, you can charge while delivering up to 12kW output—no downtime, no compromise. Compatible with all major portable generators.
Take in 10kW solar input¹—enough to recharge 12kWh to 80% in just approximately 1 hour.
Even during storm season, enjoy a full daily recharge and steady, unshakeable energy.
Always Reliable When It Matters Most
Before the Storm: Get Alerts
When the Storm Hits: Lights Stay On
Storm Guard Mode sends real-time alerts through the app and you can charge your DELTA Pro Ultra X to 100% using solar or grid power in advance, to fully prepared for the outage.
With EcoFlow DELTA Pro Ultra X, switches your whole home from grid to battery power. The lights stay on, Wi-Fi stays up, and even the game console keeps running.
Your 24/7 Money Saver
Here's a Typical Day of Savings
Day and night, power shifts between solar, storage, and off-peak rates—maximizing every watt to get you the best deal. Here's what that might look like on a typical day of use.
No Wasted Watts
Compatible with Existing Rooftop Solar²
With the EcoFlow Current Sense Transformer, every extra watt is redirected to your DPUX battery—never wasted or sold back to the grid for pennies.
The Highest Safety Standards
EV-grade full-tab cells
Durable battery pack
Dual BMS Protection³
3-Level System Safety Architecture
Smart Extreme-Weather Protection⁴
The first EV-grade full-tab cells deliver higher capacity with lower resistance, less heat, and longer-lasting performance.
1/10,000 Precision Screening: Pairs only cells with identical capacity, voltage, and resistance, ensuring the pack resists overcharging and discharging for longer life. 24/7 Self-Maintenance: Automatic SOC balancing maximizes efficiency across the battery’s entire lifespan.
Local BMS – X-Guard® System: 44+ safeguards including overcharge/discharge, extreme temperatures, short circuits, load/current issues, and component failures. Comprehensive monitoring ensures safety in every scenario. Cloud BMS – Big Data Protection: 100+ anomaly detectors run 24/7, with instant alerts, local service response, and remote emergency support.
Power Protection: 1.2M circuit samples/sec, millisecond-level anomaly detection for inverter and battery. Connection Monitoring: Advanced cable and interface safeguards track temperature rise, integrate software recognition, and allow one-touch power cut for full electrical security. Load Isolation: Continuous voltage/current monitoring with triple-layer isolation. Faulty devices are cut off automatically while critical loads stay powered.
Heats batteries to ~10°C (~50°F) in extreme cold for safe charging and longer runtime, while high-temp protection allows charging even at up to 50°C (122°F).
What's in the box?
Standard Capacity
12.288kWh, 6144Wh x 2
Maximum Capacity with 1 inverter
61.440kWh, 6144Wh x 10
12kW, 120/240V, 60Hz
Up to 36kW in 3 parallel units
Maximum Capacity with 3 inverters
184.32kWh, 6144Wh x 30
Net Weight (lb)
Inverter: 34.5±0.2kg(70.06±0.44 lb)
Battery: 50.5±0.2kg(111.3±0.44 lb)
Dimension (mm)
Inverter: 675 × 475 × 230 mm (26.6 × 18.7 × 9.06 in.)
Battery:660 × 455 × 204 mm (26 × 18 × 8 in.)
5 years
Screen
Extra Battery
AC Outlets
NEMA 5-20 (x2) 120V 20A
NEMA L14-30 (x1) 120/240V 30A
NEMA 14-50 (x1) 120/240V 50A
UPS
<10ms standalone, <20ms with Smart Home Panel 3
Rated AC Input Power
12kW,100/200-120/240V, 50A
DC Input
Total 10kW, 2 ports
80-500V/15A, 5000W Max Each
Noise Level
Noise level <30 dB at 0.5 m (ambient temperature 25 °C, 4 kW output)
IP Rating
IP54
Battery Temperature
Operating&Storage temp: −4°F to 113°F (−20°C to 45°C)
Inverter Temperature
Operating&Storage temp: −4°F to 122°F (−20°C to 50°C)
What are the specifications of the AC output ports of the DELTA Pro Ultra X?
The AC output ports and specifications of the DELTA Pro Ultra X are as follows:Front: NEMA 5 - 20 interface (120V 20A), L14 - 30 interface (120V/240V 30A), 14 - 50 interface (120V/240V 50A).Right side: 5 + 8 input/output interface (120V/240V 50A)
What are the specifications of the DC input ports of the DELTA Pro Ultra X? Are there any DC output ports?
The DC input ports and specifications of DELTA Pro Ultra X are as follows:High-PV input port: 80-500V//15A per interface, with a total maximum input of 10000W.There is no DC output port.
How many battery packs can the DELTA Pro Ultra X connect to at most?
The DELTA Pro Ultra X supports the parallel connection of up to 10 battery packs (with a single battery pack capacity of 6144kWh), which can significantly increase the backup power capacity.
What is the UPS switching time of the DELTA Pro Ultra X?
The UPS switching time of the DELTA Pro Ultra X is divided into two scenarios:When the DELTA Pro Ultra X operates independently: Power outage time < 10ms;When the DELTA Pro Ultra X operates in combination with the EcoFlow Smart Home Panel 3 (32 Circuits) or the Smart Gateway, the power outage switching time < 20ms.
What should be noted when connecting old batteries (DELTA Pro Ultra series) to the DELTA Pro Ultra X?
When connecting old batteries (with SN starting with Y712) to the DELTA Pro Ultra X, the following points must be followed:Only connect the old batteries to the rightmost Battery Port (the one farthest from the Power In/Out Port) for upgrading. Do not connect any batteries to the middle Battery Port to avoid abnormalities.Do not unplug the parallel connection cable during the upgrade process until the upgrade indicator on the screen disappears and the device restarts.
Which ecological products is the DELTA Pro Ultra X compatible with?
DELTA Pro Ultra X is compatible with the following products (some require additional accessories):Third-party devices: 3 - 7.2kW/12kW generators, charging piles, EV charging guns;EcoFlow products: EcoFlow Smart Home Panel 3 (32 Circuits) or Smart Gateway intelligent distribution box.
What are the core upgrades of the DELTA Pro Ultra X compared to the previous generation of DELTA Pro Ultra?
The total output power is increased from 7200W to 12000W;The maximum number of connectable battery packs is increased from 5 to 10;The maximum total PV input power is increased from 5600W to 10000W.
How about the solar charging capacity of the DELTA Pro Ultra X?
Supports two-way high-voltage PV inputs, with a voltage range of 80 - 500V for each way, a maximum working current of 15A per way, and a total power of up to 10,000W;The photovoltaic interface needs to be connected to the EcoFlow PV Switch Box (standard configuration).
Does the DELTA Pro Ultra X require a specific way to connect the battery packs to achieve an output power of 12KW?
Batteries need to be connected to both power-on pack ports on the Inverter. Additionally, it is recommended that the number of battery packs connected to the two ports be the same; if the number of battery packs connected to the two ports is inconsistent, the output power may not reach 12KW.
Can the DELTA Pro Ultra X output power in bypass mode when powered through the standard AC charging cable?
Yes, it's possible. The specification of the standard charging cable (EcoFlow AC Charging Cable (NEMA 5 - 15P to 5P8 Port)) is 15A, 120V. When charging with this cable, you can simultaneously output and carry a load from the front panel.
Can the DELTA Pro Ultra X change the power frequency to switch between 50Hz and 60Hz?
The frequency cannot be adjusted, and the default frequency is 60HZ. In bypass mode, the output frequency of the device is determined by the frequency of the input mains power (for example, if the mains power input is 60Hz, the output will be 60Hz; if the input is 50Hz, the output will be 50Hz).
Does the DELTA Pro Ultra X support charging by third-party generators?
Supported. There are two connection methods. You can directly connect to the Power in/out port via the accessory EcoFlow Generator Charging Adapter, or connect to the PV port through the EcoFlow FlowMaster Generator Rectifier [optional].
How to reset the Bluetooth connection of the DELTA Pro Ultra X?
When the device is turned off, press and hold the power button until the screen lights up, and then continue to hold it for about 5 seconds. When you hear the device beep twice in succession or see the device screen go off and then light up again, it indicates that the reset is successful.
Does the DELTA Pro Ultra X support grid connection?
It is not supported. The DELTA Pro Ultra X only draws power from the grid and will not actively transmit power back to the grid.
Disclaimer
1. Charging performance of reaching 80% in approximately 1 hour was measured under controlled conditions (ambient and cell temperature of 25 °C, with stable PV or AC charging power). Actual charging time may vary due to temperature, charging power fluctuations, or other environmental factors.
2. Compatibility tested with mainstream rooftop PV systems. Actual integration may vary depending on inverter, wiring, and installer setup. Rooftop solars are sold separately and are not included with this product.
3. The description of “44+ safeguards” and “100+ anomaly detectors” is based on EcoFlow’s internal BMS design specifications and testing data. These safeguards function as intended under proper product use and within rated conditions. Actual protective performance may vary depending on system configuration and operating environment.
4. Extreme-weather protection is based on EcoFlow internal design and testing. Operating range may vary depending on conditions, installation, and maintenance.
Select your language
