Ecoflow DELTA Pro Ultra + DELTA Pro Ultra Extra Battery - Flash Sale
$7,649.00 CAD
Regular price $7,649.00 CAD
Sale price $7,649.00 CAD Regular price $13,397.00
-$5,748
-LFP battery
-Battery automatically starts self-heating if the temperature is lower than 32℉, allowing the battery to run as normal
Recommend
Subscribe DELTA Pro Ultra for latest updates
$7,649 CAD $13,397 -$5,748
EcoFlow DELTA Pro Ultra
The Most Powerful Whole-Home Backup Solution
Month-Long Power Security.
6-90kWh Capacity
One Unit Covers Every Appliance.
One Hour Of Solar For One Day Of Power.
5.6kW-16.8kW Solar Input
By Leveraging High And Low-PV Technologies, A Single Inverter Sets New Portable Solar Input Standards With A 5.6kW Input*. Connect Three Inverters For A Monumental 16.8kW, Gaining A Full Day's Home Energy In 60 Minutes. Whether You Prefer A Portable Setup Or A Rooftop Solar System, You Can Achieve True Energy Independence.
Flexible Solar Systems
Rigid Solar System
With Its Flexible Plug-And-Play Design And Unrivaled Solar Input, EcoFlow DELTA Pro Ultra Empowers You To Tailor Your Solution To Fit Your Energy Needs. EcoFlow DELTA Pro Ultra Includes A PV Locking Feature, Assuring Safety And A Solid Energy Connection.
Always In Charge
With a Generator or EV pile
Always In Charge
Always In Charge
You Won't Even Notice The Grid Was Down.
0 Ms Downtime, 0 DB Silent Backup
Peace of mind with an advanced design.
EcoFlow X-Cooling
Boost Performance with BMS
Our state-of-the-art LFP tech and advanced battery management system (BMS) regulates vital data, ensuring the safety, longevity, and high performance of EcoFlow DELTA Pro Ultra.With each battery offering a cycle life of 3500+, you'll get years of use before capacity drops to 80%. Even then, it keeps powering on.
Operating temperatures: -20°C to 45°C
290V high voltage tolerance
6144Wh, 102.4V⎓60A
30kWh (5 x DPU Battery)
AC Continuous Output
7200W
Expanable Capacity(System*)
90kWh (15 x DPU Battery)
AC Surge Output
10.8kW
Scalability(System*)
21.6kW
IP Rating
IP54
Battery Cycle Life
UPS
DC Output
12.6V⎓30A, 378W Max
AC Output Socket (Backup UPS)
2 x 120V, 20A Max per port
1 x 120V/240V, 30A Max
USB-A
AC Output Socket (Online UPS)
1 x 120V, 30A Max
USB-C
AC Input
Solar Charging Input
Total 5600W, 2 ports
Inverter Dimension
Inverter Net Weight
31.7 kg (70 lb)
Battery Dimension
Battery Net Weight
50.7 kg (111.8 lb)
5-year warranty
Connection
Bluetooth & Wi-Fi & 4G
Discharging temp
-20°C to 45°C | -4°F to 113°F
Charging temp
Storage temp
Thanks for sharing!
Select your language
