DELTA Pro 3 + Smart Home Panel 2 | EcoFlow | Default Title
EcoFlow DELTA Pro 3 + Smart Home Panel 2
$5,299.00 CAD
Regular price $5,299.00 CAD
Sale price $5,299.00 CAD Regular price $7,198.00
-$1,899
Get up to $1,589.70 in rebates through the Residential Clean Energy Credit. Learn More >
Up to $1,589.70 in rebates
Amount 30% off
Claim By: December 31, 2032
Program: Residential
  • Rentals do not qualify.
  • Must be grid-tied.
Whole-home power solution
EcoFlow DELTA Pro 3 + EcoFlow Smart Home Panel 2
DELTA Pro 3 will be shipped in in early August
-Intelligent subpanel for home battery systems.
-20 ms auto switchover
-EcoFlow app control
-Modular design
-12-circuit sub-panel
EcoFlow DELTA Pro 3 Smart Extra Battery-Recommend
$2,799 CAD $3,399 CAD
EcoFlow 400W Portable Solar Panel-Recommend
$799 CAD $1,399 CAD
22.6% Conversion Rate | IP68
EcoFlow DELTA Pro 3 Portable Power Station-Recommend
$3,299 CAD $4,499 CAD
You Could Apply for 30% Tax Credit*, When You Install EcoFlow DELTA Pro 3 as a Home Power SolutionLearn more
$5,299 CAD $7,198 -$1,899
An Intelligent Subpanel for Outage Protection and Savings in One.
The EcoFlow Smart Home Panel 2 is the center of your whole-home backup solution, working alongside EcoFlow DELTA Pro 3, generators, and solar panels to protect your home. With a fast, automatic switchover, you'll have reliable backup whenever needed. It allows you to customize your energy usage based on time-of-use rates and your home's solar energy production.
The Commanding Force Behind Your Power System.
The Whole-Home Backup System Hub.
EcoFlow Smart Home Panel 2 is the hub of the powerful EcoFlow DELTA Pro 3, allowing you to maximize your energy system's potential. Connect your home circuits to 3 × EcoFlow DELTA Pro 3 units with 6 × Extra Batteries for energy storage of up to 36kWh. It's not just for longer backup but also lets you control and run every single household appliance. EcoFlow Smart Home Panel 2 is future-proofed to work with our next-gen power solutions and the EcoFlow DELTA Pro.
Even Plan B Has a Plan B.
Compatible with Solar and Gas Generators.
EcoFlow Smart Home Panel 2 can manage energy from various sources, including solar and gas. With the sun's rays, brighten your home with cost-effective green energy and dramatically reduce your electricity expenses. When the weather turns gray and you're all out of the sunshine, a seamless connection to EcoFlow Smart Generator 4000 (Dual Fuel)*, or any 3-12kW portable gas generator, ensures your home stays energized without a hitch.
The Nights of Fumbling For a Torch are Over.
20-ms Auto-Switchover
When an outage hits, there's no need to brave the dark, cold night to switch to your backup manually. EcoFlow Smart Home Panel 2's automatic switchover feature ensures your home remains powered even when you're away. Forget spoiled food and damaged appliances. Embrace uninterrupted power so that life never stops.
Leave the Power Prep to the Pro.
EcoFlow App
EcoFlow Smart Home Panel 2 ensures your home is blackout-proof with ample energy at all times. Even when an outage lingers on, it's business as usual.
Backup Extension
Categorize your home circuits into three levels of power supply priority with Circuit Control mode. Ensure protection for the most mission-critical tasks and massively extend backup time.
Emergency Weather Prep
With automatic storm warnings mode, batteries fully recharge 24 hours before an extreme weather event. Locking energy until an outage occurs. EcoFlow Smart Home Panel 2 monitors the weather hourly, updating the system based on the forecast, offering a more precise backup strategy.
Savings Just Roll on in.
With the EcoFlow App
With Backup Reserve mode, EcoFlow Smart Home Panel 2 secures an assigned battery percentage. Fear an impending outage? Set a higher reserve for home backup. For everyday use, set a lower portion and customize your EcoFlow Smart Home Panel 2's performance using Self-Power, Scheduled Tasks, or TOU Modes to lower your energy bills.
TOU Mode
Based on Time Of Use peak and off-peak rates and your energy habits, EcoFlow Smart Home Panel 2 intelligently manages battery charge and discharge, significantly offsetting electricity costs.
Self-Power Mode
Once battery capacity exceeds the pre-set reserve, solar begins to top up energy supplies while powering the home to lower utility bills.
See Your Entire Energy Strategy at Work.
EcoFlow App, PowerInsight & Web Dashboard
View real-time energy insights for your home anywhere you go. On your phone, wall-mounted dash, or even online. Get a complete home energy consumption overview as well as solar and gas input, battery capacity, and much more. With EcoFlow Smart Home Panel 2 comes PowerInsight, a wall-mounted screen, and a web dashboard, accessible anywhere online.
See your entire energy strategy at work.
EcoFlow App
EcoFlow PowerInsight
Web Dashboard
Control, and customize your power usage at your fingertips.
Home Energy Manager, an all-in-one dedicated monitor.
A full suite of data and customizations accessible online.
Disclaimer
Effective date: Jan 1, 2023"
Thanks for sharing!
Select your language
