EcoFlow DELTA Pro 3 Smart Extra Battery | EcoFlow
EcoFlow DELTA Pro 3 Smart Extra Battery EcoFlow DELTA Pro 3 Smart Extra Battery EcoFlow DELTA Pro 3 Smart Extra Battery EcoFlow DELTA Pro 3 Smart Extra Battery
$7,999.00 CAD
Regular price $7,999.00 CAD
Sale price $7,999.00 CAD Regular price $11,297.00
-$3,298
Get up to $2,399.70 in rebates through the Residential Clean Energy Credit. Learn More >
Up to $2,399.70 in rebates
Amount 30% off
Claim By: December 31, 2032
Program: Residential
  • Rentals do not qualify.
  • Must be grid-tied.
Compatibility - Works seamlessly with EcoFlow DELTA Pro 3 (The EcoFlow DELTA Pro Smart Extra Battery is compatible with the EcoFlow DELTA Pro 3. ).
Scalable Power - Expandable up to 12kWh for increased capacity.
Long-Lasting Battery - LFP battery with 4000 life cycles to 80% capacity.
Easy to Use - Plug-and-play design for straightforward operation.
Stackable Design - Perfect for home or indoor power backup applications
Recommend
EcoFlow DELTA Pro 3 Portable Power Station-Recommend
$3,299 CAD $4,499 CAD
EcoFlow Smart Home Panel 2-Recommend
$2,499 CAD $2,699 CAD
EcoFlow 400W Portable Solar Panel-Recommend
$799 CAD $1,399 CAD
22.6% Conversion Rate | IP68
You Could Apply for 30% Tax Credit*, When You Install EcoFlow DELTA Pro 3 as a Home Power Solution Learn more
$7,999 CAD $11,297 -$3,298
Forget Refuelling
Each unit provides 4kWh of power, and you can expand up to 12kWh by stacking up to 2 Extra Batteries on one EcoFlow DELTA Pro 3. Ensure your home stays powered for longer without constant refueling.
Plug and Play
The smart extra batteries are easy to connect with the main unit of EcoFlow DELTA Pro 3. Enjoy a seamless, plug-and-play setup. The compact and portable design adds convenience to your power management.
Explore the Secure Feeling EcoFlow Brings to You
Built with state-of-the-art automotive-grade LFP cells for safe and reliable service. Our strong 5-year warranty ensures peace of mind.
Energize Every Moment That Needs Electricity
Power almost all your essential home appliances with the robust 4000W and dual 120V/240V capabilities of a single unit. Add extra batteries to extend the convenience even further.
Off-grid
RV
Jobsite
Cutting-Edge Design, Sleek and Striking
Boosts portability with wider wheels, ergonomic handle, and a compact design. Perfect for dynamic lifestyles and maximizing family space.
Effortless All-in-One Command With the EcoFlow App
Control and monitor your home's power remotely with ease using the EcoFlow app. Track every watt and customize your power usage for optimal efficiency.
4096Wh
Input Port
40V-58.4V=80A Max.
Output Port
40V-58.4V=100A Max.
Dimension
694mm*295mm*215mm
Weight
33kg (72lb)
What’s in the box
1. EcoFlow Delta Pro 3 Smart Extra Battery
2. Quick Start Guide
3. Safety Guide
4. Warranty Card
5. EcoFlow Extra Battery Cable
Compatible with
EcoFlow DELTA Pro 3
Display
LED Array
Discharge Temperature
14°F~113°F
Charge Temperature
32°F~113°F
Storage Temperature
14°F~113°F
Disclaimer
Effective date: Jan 1, 2023
Thanks for sharing!
Select your language
