EcoFlow DELTA 3 Plus Solar Generator (PV220W) | EcoFlow CA | DELTA 3 Plus+ 220W Portable Solar Panel
EcoFlow DELTA 3 Plus Solar Generator (PV220W) EcoFlow DELTA 3 Plus Solar Generator (PV220W) EcoFlow DELTA 3 Plus Solar Generator (PV220W)
$1,248.00 CAD
Regular price $1,248.00 CAD
Sale price $1,248.00 CAD Regular price $1,998.00
-$750
    • Expandable capacity: 1-5kWh expandable capacity to fit your energy storage needs. Ideal for home backup, RVing, outdoors or even everyday use.
    Built to last 6× longer: Get 10 years of daily use until hitting 80% of its original capacity. That’s down to its LFP battery chemistry giving you 3000+ cycles.
    Huge AC output: With X-Boost mode get up to 2200W output power to run 99% of home appliances.
    Capture more energy: 99% MPPT efficiency maximizes solar generation anytime.
    Up to 25% conversion with a unique bifacial design to guarantee a fast solar charging speed
    Comprehensive warranties: DELTA 3 Plus includes a 5-year warranty and 12 months for the NextGen 220W Bifacial Portable Solar Panel.
    *DELTA 3 Plus and NextGen 220W Bifacial Portable Solar Panel will be shipped separately.
    Shipment services to Alaska, Puerto Rico, and Hawaii aree temporarily suspended.
    $1,248 CAD $1,998 -$750
    Capture More Energy with a Dual-Sided Design
    With a 220W primary side and a 175W side on the back for ambient light, you can capture up to 28% more solar energy and charge your DELTA 3 Plus/DELTA 3 even faster.
    Generate Even More Energy
    With the portable solar panel industry's first use of TOPCon solar technology, we've raised the bar on conversion efficiency, reaching 25%. Allows more energy intake in less time charging for DELTA 3 Plus/DELTA 3.
    Capture More Solar with an Adjustable Angle
    With a newly integrated solar angle guide and stand, adjust the angle of the panel by 30 degrees in seconds to get the most sunshine at all times.
    What's In The Box?
    Thanks for sharing!
    Select your language
