EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station
$1,199.00 CAD
Regular price $1,199.00 CAD
Sale price $1,199.00 CAD Regular price $1,798.00
-$599
DELTA 3 Plus is temporarily out of stock and expected to be back in stock early next year. Need one sooner? Shop DELTA 2  here.
•1800W AC output, 2200W (surge 3600W) with X-Boost
•5 fast recharging methods (AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), Multicharging)
•5-year warranty
EcoFlow DELTA 3 Series Waterproof Bag
$89 CAD
$399 CAD $599 CAD
$89 CAD
Notify Me When Available
$1,199 CAD $1,798 -$599
DELTA 3 Series
AC Charging
Car Charging
Generator Charging
Multi-Charging
Solar Input with 1000W MPPT, Full Charge in 70 Minutes²
EcoFlow DELTA 3 Plus with 500W MPPT × 2 charges fully in 70 minutes, even with limited sunlight. Outdoors, it recharges during lunchtime.
Hybrid Power with Generator, Full Charge in 56 Minutes with 1500W AC Input⁴
Multi-Charging (AC + Solar), Full Charge in 56 Minutes with 1500W Input⁵
With 1500W max input, it takes 56 minutes to fully charge. During daily use, plug in both AC and solar to charge DELTA 3 Plus, prioritizing solar to save money.
EcoFlow DELTA 3 Series supports 99% of household devices, including refrigerators, TVs, and computers. Plus, with X-Boost, continuously power appliances over 2600W, such as ovens (2150W), hair dryers (1800-2500W), and kettles (1200-2600W). Perfect for home backup, RV, and outdoor usage, this powerhouse ensures you're never left in the dark.
Outdoors
RV
Home backup
Professional work
30 dB Ultra-quiet Operation.
*EcoFlow DELTA 3 Series power stations are compatible with the following Extra Battery models via an Alternator Charger XT150 Output Cable: DELTA 3 Extra Battery, DELTA 2 Extra Battery, DELTA 2 Max Extra Battery, and DELTA Pro 3 Extra Battery.
Smaller Size, Same Power
1 Extra Battery, 5 x the Power
LFP Battery
IP65 Battery Pack
BMS
13 Outputs
Compact and lightweight
Net Weight (kg)
≤12.5kg
1024 Wh
Extra Battery
Supports the following Extra Battery models via an Alternator Charger XT150 Output Cable: DELTA 3 Extra Battery, DELTA 2 Extra Battery, DELTA 2 Max Extra Battery, and DELTA Pro 3 Extra Battery.
Total Output Ports
13
2600W
USB-A Output (Fast Charge)
2 ports, 36W Max
2 ports, 140W Max
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A Max
AC Charging
1500W
2 ports, DC Charge Input, 11V-60V 500W Max*2
1500W
Car Charging
800W, in 1.3 Hour
LFP (LiFePO4 battery)
4000 cycles to 80+% capacity
Connectivity
IP65
UPS
<10ms
Noise
600W<30db;1200W<40db
5 years
Footnotes
Thanks for sharing!
Select your language
