DELTA 3 Max Series Portable Power Station (2048Wh) | EcoFlow CA | DELTA 3 Max (2048Wh) / DELTA 3 Max Portable Power Station
EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh)
$1,099.00 CAD
Member Exclusive Product
Regular price $1,099.00 CAD
Sale price $1,099.00 CAD Regular price $2,099.00
-$1,000
DELTA 3 Max Plus (2048Wh)
1. 3000W Powerful Output: 6000W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws.
2. 5 Ways to Charge, Ready in Just 43 Mins: Ready in Just 43 mins (0-80%) with generator charging.
3. 2-10kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop.
4. Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most.
1. 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws.
2. 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging.
3. Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product.
Common Features
1. Long-Lasting, Durable, and Reliable: Equipped with automotive-grade full-tab LFP cells, offering 10 years of reliable power, 24/7 protection BMS, and EV-grade CTC structure that protects against overnight condensation and off-road bumps during transport.
2. 10ms Auto-Switch: Fast enough to keep critical devices like NAS systems and servers running smoothly.
3. 25dB Whisper-Quiet Operation: Ultra-low noise (≤25dB at 600W).
4. OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. Storm Guard Mode automatically activates backup power before extreme weather hits. Self-Powered Mode and Scheduled Tasks save you money daily.
5. Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Series
Product
EcoFlow 500W Alternator Charger (Recommended Accessory)
$329 CAD $549 CAD
EcoFlow 400W Portable Solar Panel (Recommended Accessory)
$889 CAD $1,399 CAD
$329 CAD $549 CAD
$889 CAD $1,399 CAD
$1,099 CAD $2,099 -$1,000
2kWh Portable Power Station with 3000W Max Output
EcoFlow DELTA 3 Max Plus (2048Wh)
Peak Performance. Total Peace of Mind.
A New Era of Power Performance
25% More Power : 3000W Output, 2kWh Capacity
Next-level energy for next-level peace of mind.
3000W Output, 6000W Surge
Powerful. Stable. Built to Handle It All.
EcoFlow DELTA 3 Max Plus (2048Wh) delivers 3000W AC rated output (6000W surge). With X-Boost™ 3.0 technology, it supports devices up to 3800W—effortlessly taking on your heavy-duty appliances. The inverter samples AC voltage and current every 33μs with high precision using a DSP chip, ensuring pure sine wave output with beyond grid-level stability—ideal for powering sensitive electronics reliably.
RV Camping
RV Camping
Kitchen
Kitchen
Living Room
Living Room
Laundry Room
Laundry Room
Office
Office
Garage
Garage
RV Camping
Kitchen
Living Room
Laundry Room
Office
Garage
5 Ways to Charge Up — Ready in Just 43 Mins [1]
Wall Charging
Wall Charging
Generator Charging
Generator Charging
Alternator Charging
Alternator Charging
Solar + Alternator Dual Charging
Wall Charging
Generator Charging
Alternator Charging
1800W Input, 0-80% in 64 mins. [4] EcoFlow’s exclusive Storm Guard Mode [5] monitors severe weather alerts and automatically triggers AC charging remotely using industry-leading X-Stream fast charging tech—so it can be ready long before a disaster hits.
Charges at up to 2600W via smart generator—0–80% in 43 minutes. With exclusive Generator Auto Start/Stop Mode, [6] the EcoFlow Smart Generator 4000 (Dual Fuel) recharges DELTA 3 Max Plus (2048Wh) automatically when battery levels run low—delivering hands-free backup power for storms, outages, and off-grid use.
1000W Input, 0-80% in 96 mins*. After the storm clears, just 96 minutes of sunlight is all it takes to recharge DELTA 3 Max Plus (2048Wh). Pair it with EcoFlow 220W Solar Panels (25% high-efficiency) for reliable power during camping trips, van life, or off-grid living. [7]
1000W Input, 0-80% in 95 mins. With the EcoFlow Alternator Charger Plus 1000, [8] get ready in just 95 minutes while on the move—10× faster than conventional solutions. [9]
Go from 0-80% charged in just 51 minutes—dual input from 1000W solar and 1000W alternator charging keeps you powered faster than ever, even on the go.
Built to Last
From battery chemistry to structural design, DELTA 3 Max Plus (2048Wh) is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years. [2]
Easily Scales Up—From Hours to Days
2–10kWh expandable capacity
Compatible with Smart Generators for unlimited runtime
Require connecting 1 × DELTA 3 Max Plus + 2 × DELTA Pro 3 SmartExtra Battery or 1 × DELTA 3 Max Plus + 2 × DELTA 3 Max Plus Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter has released Canada local now.*
Half-Day Outage
Half-Day Outage
1-Day Outage
1-Day Outage
2-Day Outage
2-Day Outage
3-Day Outage
3-Day Outage
Half-Day Outage
1-Day Outage
2-Day Outage
3-Day Outage
Covers essential power needs during a 4–8 hour outage—keeping food fresh, heat running, lights on, and communication devices charged. [12]
Delivers 1 day of outage protection—ensuring uninterrupted cooking, heating, lighting, and connectivity. [12]
Powers home essentials for up to 2 days [12] with 6kWh capacity—keeping your kitchen running, lights on, and devices connected. [13]
Supports a family of four through 3 days of everyday living [12] with 10kWh capacity——keeping food fresh, heat running, lights on, and entertainment devices charged. [14]
Go Hybrid—Extend Backup with a Smart Generator
Pair DELTA 3 Max Plus (2048Wh) with EcoFlow Smart Generators to achievelonger runtime—automatically switching between fuel and battery to keep you powered through multi-day outages or off-grid adventures. [15]
Monitor your energy usage, savings, and solar generation—all with one intuitive dashboard. Easily track battery status, real-time electricity rates, and financial savings.
Compatibility
[1] 0-80% in 43 minutes was measured in optimal conditions using the EcoFlow Smart Generator 4000 (Dual Fuel).
[2] Based on proper product usage, DELTA 3 Max Plus (2048Wh) is estimated to have a lifespan of approximately 10 years, according to internal simulation test data. This information is for reference only; actual user experience may vary.
[3] Compared with EcoFlow DELTA 2 Max.
[4] All charging speed data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
[5] Feature requires preset activation via the EcoFlow App.
[6] To enable this feature, connect DELTA 3 Max Plus (2048Wh) to the Smart Generator using the charging cable and enable the preset in the EcoFlow App. Communication is handled via Bluetooth or Wi-Fi.
[7] EcoFlow Solar Panels are sold separately.
[8] EcoFlow Alternator Charger Plus 1000 will be launched soon and is sold separately.
[9] Compared with car cigarette port charging.
[10] Refers to the internal resistance of EF Full-Tab LFP Cells being 1.5mΩ, which is 25% lower than the 2mΩ internal resistance of the previous EF #C33 Battery Cell.
[11] A 25% reduction in single-cell internal resistance. According to the heat generation formula Q = I²Rt, under the same current, a 25% reduction in resistance leads to a proportional 25% decrease in heat generation.
[12] Multiple appliances' backup time based on ideal conditions; actual results may vary.
[13] Require connecting 1*DELTA 3 Max Plus (2048Wh) + 2* DELTA 3 Max Plus Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
[14] Require connecting 1*DELTA 3 Max Plus (2048Wh) + 2* DELTA Pro 3 Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
[15] EcoFlow Smart Generators are sold separately.
[16] Certain features in the EcoFlow app will be available soon. Please refer to the EcoFlow app for details on feature availability.
[17] Unless otherwise noted, all images, videos, and screen display contents about the product itself on this page are for reference only. Actual product effects (including but not limited to appearance, color, and size) and screen display contents (including but not limited to backgrounds, UI, and illustrations) may vary.
[18]*DELTA 3 Max Plus works with: DELTA 3 Max Plus Smart Extra Battery, DELTA Pro 3 Smart Extra Battery, DELTA 3 Smart Extra Battery, EcoFlow 800W Alternator Charger, EcoFlow Alternator Charger 600, EcoFlow Alternator Charger Plus 1000.
22.1+0.4kg
Dimensions (HWD)
494mm×242mm×305mm
Rated Capacity
2048Wh 51.2V 40Ah
Cell Chemistry
LFP(LiFePO4)
120V~60Hz 3000W total (surge 6000W), 20A(x4) Max per port
X-Boost
3800W
USB-A(x1): 5V-3A/9V-2A/12V-1.5A, 18W Max
USB-C(x1): 5/9/12/15V-3A, 20V/28V--5A, 140W Max(HID)
USB-C(x2): 5/9V/12V/15V-3A 20V-2.25A, 45W Max per port, total 45W
12V DC Output Port
12.6V-30A, 378W Total
Anderson: 30A Max (Shared power with car cigarette lighter)
Cigarette Lighter Output Port
12.6V-10A, 126W Total
CAR:10A Max (Shared power with Anderson port)
AC Input (Charge Only)
100-120V~15A 50/60Hz
Maximum PV Input Power(W)
1000W
Optimal operating temperature
20°C to 30°C (68°F to 86°F)
Charge Temperature
0°C-45°C(32°F-113°F)
Discharge Temperature
-10 to 45°C(14°F-113°F)
Storage Temperature
5-Year Warranty
Communication Method
Wi-Fi & Bluetooth
EMC
Class B
UPS
<10ms
Thanks for sharing!
Select your language
Unlock Exclusive Member Savings
Member Price
$3,358.00
Original Price
$3,598.00
