EcoFlow DELTA 3 1500 Portable Power Station | EcoFlow CA | DELTA 3 1500 Portable Power Station-Silver
EcoFlow DELTA 3 1500 Portable Power Station EcoFlow DELTA 3 1500 Portable Power Station EcoFlow DELTA 3 1500 Portable Power Station EcoFlow DELTA 3 1500 Portable Power Station EcoFlow DELTA 3 1500 Portable Power Station EcoFlow DELTA 3 1500 Portable Power Station
$1,099.00 CAD
Regular price $1,099.00 CAD
Sale price $1,099.00 CAD Regular price $1,299.00
-$200
1.5-5.5kWh expandable capacity with DELTA 3 Extra Battery, DELTA 2 Extra Battery, DELTA 2 Max Extra Battery or DELTA Pro 3 Extra Battery
  • 1800W AC with 15 outlets (Up to 2200W with X-boost)
  • UPS switchover in 15 ms
  • AC fast charging from 0%-80% in 60mins
  • 5-year warranty
$499 CAD $699 CAD
EcoFlow DELTA 3 Series Waterproof Bag
$89 CAD
$1,099 CAD $1,299 -$200
EcoFlow DELTA 3 (1500) Portable Power Station
Same Size, 1.5 Times More Capacity
1536Wh Capacity
With a size nearly identical to 1kWh-class products, this model offers 1.5 times the capacity—letting your appliances run 1.5 times longer, all while maintaining convenient portability and easy storage. It’s the perfect solution for situations where "1kWh isn’t quite enough, but 2kWh is too much"—ideal for one- or two-night camping trips and more.
Always Be Prepared with Unmatched Fast Charging
5 industry-leading charging methods—recharge up to 80% in just 1 hour
Charge While Driving
AC Charging
Generator charging
Multiple inputs
Harness the sun's energy with a massive solar input of up to 5000W. Fully charge the DELTA 3 (1500) in as little as 3.5 hours using EcoFlow Portable Solar Panels. [2]
With an 800W alternator charger, you can fully charge in just 2 hours-8x faster than traditional methods. Charge on the go, with no advance preparation needed. [3]
EcoFlow's 1500W X-Stream AC input allows the DELTA 3 (1500) tocharge from 0-80% in just 60 minutes, or fully charge in 90 minutes. Beready for power outages or spontaneous camping trips. [4]
Fully charge the DELTA 3 (1500) in only 1.5 hours. The EcoFlowSmart Generator 3000 (Dual Fuel) automatically tops up your power ovvernight ensuring constant backup with zero hassle. [5]
Achieve a full charge in just 90 minutes using a combined input ofup to 1500W from both AC and solar-solar is prioritised to save you morey. [6]
Power 99% appliances without overloading
1800W Output (3600W Surge), Up to 2200W with X-Boost
EcoFlow DELTA 3 (1500) can power 99% of household appliances, including refrigerators, TVs, and computers. With X-Boost, continuously run high-power appliances up to 2400W, from ovens (2150W) to hair dryers (1800-2500W).
Outdoors
RV
Home backup
Professional work
UPS for home backup
15 ms auto-switch to battery power
Constantly run your refrigerator, fish tank, or CPAP in case of emergencies. Keeps your home essentials powered up no matter what.
Long-lasting and durable, ensuring constant and reliable backup
Triple protection for guaranteed safety from the inside out
LFP battery
IP54-rated
BMS
Third-generation LiFePO4 (LFP) cells provide fast charging without compromising lifespan. With 3,000 cycles to 70% capacity, you'lI enjoy up to 10 years of dependable use-25% above the industry standard.
IP54-rated for resistance to water splashes, dust, and smoke,delivering durability in all environments. Built to withstand harsh conditions for lasting performance.
Over 40 protective measures guard against current, voltage, temperature, and circuit risks. An intelligent management system and thermal runaway protection ensure maximum safety, preventing explosions and fires.
Expand Capacity to Keep Appliances Running Every Day
Up to 5.5kWh with Extra Batteries from the DELTA Series
The DELTA 3 (1500) supports four types of extra batteries from the DELTA series. Customise your power setup to match your needs or flexibly use any extra DELTA batteries you already own.
Peace of Mind for Backup Power—Convenient for Everyday Use
An intelligent energy management system powered by EcoFlow Oasis.
Powerful Yet Lightweight, Take Power Anywhere.
36.3 lb & 15.7 × 8.3 × 11.1 in
Power home appliances, outdoor activities, or DIY. Easily lift up and take it anywhere.
15.7 x 8.3 x 11.1 in(40 x 21 x 28 cm)
36 lbs/ 16.5kg
1536Wh
Life Span
3000 cycles to 70%
UPS
<15ms
AC Input
1500W
Solar Input
500W, 15A,single port
Car Charger
12V/24V, 8A
1800W, surge 3600W
X-Boost
2200W
12W
USB-A Fast Charge
18W
100W
Car Output
126W
DC5521 Output
38W
AC Charging
1500W
500W Max 3.5 hours
Car charging
12.6V/10A 126W Max~12.1 hours
Footnote:
All the test results displayed on the page are based on our internal testing, subject to different conditions, including temperature variations, humidity levels, and equipment calibration standards. Please note that these results are provided for informational purposes only and should not be considered as conclusive evidence for all scenarios. Data was tested in a controlled laboratory environment and actual user experience may vary.
3. The input and output wattage of the Smart Extra Battery will decrease to 100W when ambient temperature is higher than 95°F (35°C).
4. The IP54 water-resistance rating applies only to the battery pack, not the entire package. It does not prevent water immersion but can prevent fire or explosion in the event of a short circuit if the battery is splashed with water or rain, ensuring user safety and property protection
Thanks for sharing!
Select your language
