EcoFlow DELTA + 220W Portable Solar Panel - DELTA (1300) / 1 - EcoFlow CA
EcoFlow CA
EcoFlow DELTA + 220W Portable Solar Panel EcoFlow DELTA + 220W Portable Solar Panel EcoFlow DELTA + 220W Portable Solar Panel EcoFlow DELTA + 220W Portable Solar Panel
$1,699.00 CAD
Write a review
Regular price $1,699.00 CAD
Sale price $1,699.00 CAD Regular price $2,798.00
-$1,099
Up to EcoCredits for cash deduction. Log in
The new standard of battery-powered generators: Compatible with a wide range of devices, you can stay powered for hours whenever and wherever.
Charge from 0%-80% within 1 hour:  EcoFlow patent X-Stream Technology empowers EcoFlow DELTA to recharge at 10 times the speed of most battery powered stations in the market.
6x AC Outlets (Total 1800W) & 1260Wh capacity: The large inverter load makes DELTA a power station for home appliances and heavy-duty DIY tools under 1800W (3300W Surge, Pure Sine Wave) with 1260Wh capacity. Learn more about DELTA >>
Two in one EcoFlow’s 220W Bifacial Portable Solar Panel is two in one. With a 220W primary side, and a 155W side on the back for ambient light, you can capture up to 25% more solar energy and charge your portable power station even faster.
Tempered glass. Built to last The thin, one-piece tempered glass design makes it five times tougher than comparable panels, it can withstand heat up to 300°F too. Safe to say it can withstand the elements.
Compact. Portable It’s a portable solar panel designed from the ground up to be compact. 10% smaller than comparable 220W panels, it saves space with thinner tempered glass, and less surface area required for the same input. Learn more about 220W Solar Panel>>
Model
Number of Solar Panel
$1,699 CAD $2,798 -$1,099
♻️220W shipments are expected to begin from mid October Learn more
