EcoFlow DELTA 2 Smart Extra Battery EcoFlow DELTA 2 Smart Extra Battery
Regular price $899.00 CAD
Sale price $899.00 CAD Regular price $2,398.00
-$1,499
• Expandable Capacity
• Convenient Recharging
• Fast Recharging
• Power multiple devices
• Control from anywhere
$899 CAD $2,398 -$1,499
⚠️ Firmware Update Required for 1T2 Accessory
To use the 1T2 accessory properly, all compatible main units must be updated to the latest firmware version. Without the required firmware, you may experience operational issues.
Required firmware versions:
  • DELTA 3 Max Plus: v7.80.98.44 or above
  • DELTA 3 Ultra Plus: v7.80.98.46 or above
If you have not received the firmware update, please contact our customer support team to have it pushed to your device. To complete the upgrade, connect each EB to the main unit separately — the process requires two separate upgrades. Once both upgrades are complete, the 1T2 accessory will function normally.
Expandable Capacity
DELTA 2 expands up to 2048Wh with smart extra battery, keeping your home powered on in any emergency.
DELTA 2 and its Extra Battery charge and discharge in unison. Recharging from portable solar panels, AC outlets, or our Smart Generator is easy.
Fast Recharging
Charge up with DELTA 2 from 0-80% in 80 minutes and 0-100% in 130 minutes with AC input.
Internal Storage Compartment
Get extra storage for accessories conveniently, saving space at home or on the go.
Power Multiple Devices
DELTA 2 fits with every port you'll ever need to power any devices anywhere, so you will always feel right.
Get all the same info about battery percent, remaining recharge time, hours left, and more on the built-in screen. You can check the battery's status anywhere from the EcoFlow app.
Payment options through Affirm Canada Holdings Ltd. (“Affirm”). Your rate will be 0–31.99% APR (where available and subject to provincial regulatory limitations). APR offered is based on creditworthiness and subject to an eligibility check. Not all customers will be eligible for 0% APR. Payment options depend on your purchase amount, may vary by merchant, and may not be available in all provinces/territories. Actual payment option terms will be shown at checkout. A down payment (or a payment due today) may be required. Affirm accepts debit cards and PAD as forms of repayment on payment options. Select payment options may be eligible for repayment in the form of credit cards. Please review the terms and conditions of your credit card when using it as a form of repayment. Sample payment options may be: a $800 purchase could be split into 12 monthly payments of $72.21 at 15% APR, or 4 interest-free payments of $200 every 2 weeks. For more information, please seehttps://www.affirm.com/en-ca/how-it-works.
Thanks for sharing!
Select your language
