EcoFlow DELTA 2 + DELTA 2 Smart Extra Battery
EcoFlow DELTA 2 + DELTA 2 Smart Extra Battery EcoFlow DELTA 2 + DELTA 2 Smart Extra Battery
Regular price $899.00 CAD
Sale price $899.00 CAD Regular price $2,398.00
-$1,499
    • Expandable capacity
    • Huge AC output
    • 7x Faster AC charging
    • Built to last 6x longer
    • Control from anywhere
    • 5-Year warranty
      $899 CAD $2,398 -$1,499
      See What the Pros Think
      EcoFlow DELTA 2
      Power pretty much anything
      A 1800W AC output means you can power more than 90% of yoour home appliances. That's your microwave, fridge, or even coffee maker covered in a blackxout. Or, try plugging in up to 15 devices at once for when you're around the table with the farmily. Unlike other brands, DELTA 2 can preventoverloading from devices up to 2200W thanks to X-Boost technology.
      Ourdoor
      Home backup
      DIY
      Power 15 Devices at Once
      1800W AC Output from 6 Outlets
      With a capacity of 1kWh to start with, you've got enough energy for your essentials for hours on end. Need even more? Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA 2 Max Extra Battery to hit 3072Wh. Great for home backup or everyday appliances. Use an extra battery to expand capacity. Great for extended power outages, long camping trips, or your RV.
      4 Ways to Charge Up - Ready in Just 50 Mins
      Pair with solar panels and charge in as fast as 3-6 hours with 1x400W, 2x220W portable solar panels. With its MPPT (Maximum Power Point Tracking) smart algorithm, DELTA 2 can actively detect the voltage and current in real-time to reach the maximum power point with >98% efficiency. That means a more efficient charge than other brands. Pick from a range of solar panels to get the speed you need you need (110W, 160W, 220W, 400W). With that, you've got access to free energy anywhere.
      AC Charging
      DC Charging
      Car Charging
      Ready for emergencies.
      Control from anywhere.
      A simple power outage solution to power your essential home appliances with 1800W AC output by directly connecting the DELTA 2 with your home's power inlet box* with a generator cord for partial home backup. With a plug-and-play design, it's easier than ever to prepare for blackouts. *including transfer switch which has a male L14-30 twist-lock connection that can accept a L14-30 extension cord.
      What's in the box?
      1024 Wh
      Extra Battery
      6 outlets, 1800W total (Surge 2700W)
      2200W
      2 ports, 5V, 2.4A, 12W Max
      USB-A Fast Charge
      Car Power Output
      1 port, 12.6V, 10A, 126W Max
      DC5521 Output
      2 ports, 12.6V, 3A, 38W Max
      AC Charging
      X-stream Fast Charge 1200W max
      AC Input Voltage
      100~120V (50Hz/60Hz)
      11-60V, 15A, 500W max
      Car Charging
      Support 12V/24V battery, 8A
      DC Charging
      1100W
      LFP (LiFePO4 battery)
      3000 cycles to 80+% capacity
      Connectivity
      Wi-Fi & Bluetooth
      Net weight (lbs)
      27lbs
      Net Weight (kg)
      12kg
      Thanks for sharing!
      Select your language
