EcoFlow DELTA 2 + 160W Portable Solar Panel - DELTA 2 / 1
EcoFlow CA
EcoFlow DELTA 2 + 160W Portable Solar Panel EcoFlow DELTA 2 + 160W Portable Solar Panel
$1,599.00 CAD
2 Reviews
Regular price $1,599.00 CAD
Sale price $1,599.00 CAD Regular price $1,898.00
-$299
EcoFlow DELTA 2 solar generator: Secure your power supply with an EcoFlow DELTA 2 solar generator bundle at home or on the go. Plug in 160W Portable Solar Panels and get up to 500W input to charge from anywhere in as fast as 3 hours.
Expandable home emergency power 1-3kWh expandable capacity to grow your storage to your needs. Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
Rapid dual charging X-Stream tech means that DELTA 2 charges 7 times faster than the competition. That’s 0–80% in just 50 minutes and 0-100% in 80 minutes with AC input. Plug in portable solar panels and charge in as fast as 4-8 hours with 2 x 160W portable solar panels.
Intelligent Solar Power The EcoFlow 160W Portable Solar Panel is designed to produce maximum power at any time of the day when paired with an EcoFlow power station. The solar panel has a high conversion efficiency of up to 22%, and the EcoFlow MPPT power station algorithm delivers improved performance in cold and cloudy environments within the operation range.
Power multiple devices 1800W AC output means you can power more than 90% of your home appliances. Or, try plugging in up to 15 devices at once. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2200W thanks to X-Boost technology. Learn more about DELTA 2 >>
Portable & Foldable The EcoFlow 160W Portable Solar Panel is portable, foldable, and compact from camping to outdoor activities. Learn more about 160W Portable Solar Panel >>
Model
Number of Solar Panel
$1,599 CAD $1,898 -$299
EcoFlow DELTA 2 Solar Generator is a must-have for any home that puts power security & comfort first. Ensure you're prepared with the power station made for almost any situation your family could find themselves in. All while staying green.
Make it a triple.
Expand capacity.
With a capacity of 1kWh to start with, you've got enough energy for your essentials for hours on end. Need even more? Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
Optimize your energy.
X-Stream tech means you can charge from 0%-80% in 50 mins, or 0-100% in 80 minutes with AC input, that's faster than you'll pack your trunk for the next road trip. Pair with solar panels and charge in as fast as 4-8 hours with 2 x 160W portable solar panels. With its MPPT (Maximum Power Point Tracking) smart algorithm, DELTA 2 can actively detect the voltage and current in real-time to reach the maximum power point with >98% efficiency.
Charge faster,
wherever you go.
A single portable solar panel with a unique folding design, our 160W portable solar panel combines powerful energy production with portability. To achieve a higher solar conversion efficiency of up to 22%, we use multi busbar monocrystalline cells, so you get even more energy to recharge your portable power station.
Built to last 6x longer.
Power pretty much anything.
A 1800W AC output means you can power more than 90% of your home appliances. That's your microwave, fridge, or even coffee maker covered in a blackout. Or, try plugging in up to 15 devices at once for when you're around the table with the family. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2400W thanks to X-Boost technology.
Control, monitor,
and manage your energy use.
Take solar power on the go.
EcoFlow's 160W portable solar panel is a camping or RV must-have. The compact design saves valuable space for your other travel essentials. When you're ready to head off on your next adventure, simply collapse the panel down to store in your van or car.
1. DELTA 2 2.AC Charging Cable3. Car charging cable 4. DC5521 to DC5525 cable 5.User Manual6. App quick start guide 7. Warranty card 8. 160w Portable Solar Panel
*The solar to XT60 charging cable is included in EcoFlow portable solar panels.
Specs of DELTA 2
1024 Wh
Extra Battery
6 outlets, 1800W total (Surge 2700W)
2200W
2 ports, 5V, 2.4A, 12W Max
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A, 38W Max
AC Charging
1200W
11-60V, 15A, 500W max
Car Charging
Support 12V/24V battery, 8A
Smart Genertaor Charging (DC)
1100W
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
27 lbs / 12 kg
Specs of 160W Solar Panel
Unfolded Dimensions
26.8*61.8*1.0 in (68*157*2.4 cm)
Folded Dimensions
26.8*16.5*1.0 in (68*42*2.4 cm)
Weight
15.4 lb (Solar Panel 11 lb)
12 months
Rated Power
160W(±5W)
Efficiency
21%–22%
Connector Type
Solar Connector
Open Circuit Voltage
21.4V (Vmp 18.2V)
Short Circuit Current
9.6A (Imp 8.8A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−4°F to 185°F
