EcoFlow DELTA + 110W Portable Solar Panel - DELTA (1300) / 1 - EcoFlow CA
EcoFlow CA
EcoFlow DELTA + 110W Portable Solar Panel EcoFlow DELTA + 110W Portable Solar Panel EcoFlow DELTA + 110W Portable Solar Panel EcoFlow DELTA + 110W Portable Solar Panel EcoFlow DELTA + 110W Portable Solar Panel EcoFlow DELTA + 110W Portable Solar Panel EcoFlow DELTA + 110W Portable Solar Panel EcoFlow DELTA + 110W Portable Solar Panel
$1,399.00 CAD
9 Reviews
Regular price $1,399.00 CAD
Sale price $1,399.00 CAD Regular price $2,398.00
-$999
Up to EcoCredits for cash deduction. Log in
EcoFlow DELTA Power Station represents the new standard of battery-powered generators. Compatible with a wide range of devices, you can stay powered for hours whenever and wherever.
  • RECHARGE 0%--80% WITHIN 1 HOUR
  • 6X 1800W AC OUTLETS & 1260Wh CAPACITY
  • FASTEST RECHARGE BY SOLAR AND CAR
  • POWER 13 DEVICES SIMULTANEOUSLY
    Stay off the grid with EcoFlow 110W Solar Panel Charger. Made up of the efficient monocrystalline silicon cells,  it can recharge DELTA and your electric devices, and keep your equipment running without interruption when connected to our portable power station.
    • COMPATIBLE WITH MOST GENERATORS
    • UPGRADE HIGH EFFICIENCY
    • PORTABLE & FOLDABLE KICKSTAND PANEL
    • WATERPROOF & DURABLE
      *Please NOTE: This item is only applicable to orders in Canada
      Model
      Number of Solar Panel
      $1,399 CAD $2,398 -$999
      Stay in charge of any situation with DELTA and keep your devices powered at all times. DELTA has a huge 1260Wh capacity that’s perfect for power outages, outdoor adventures, and professional work.
      High Capacity
      X-Stream Fast Charge
      6x AC Outlets
      Power Multiple Devices
      The world’s fastest charging portable power stations
      EcoFlow have the world's fastest charging power stations. DELTA charges from 0-80% in under an hour, giving you a quick boost of power even during the worst situations.
      So Much More Sun
      32 premium monocrystalline silicon cells provide a high conversion efficiency of 22%. Recharge even faster by chaining multiple panels in series or in parallel.
      Better Together
      Recharge freely and naturally when you link EcoFlow’s 110W Solar Panel to a DELTA portable power station.
      Title
      Light 10W
      CPAP 40W (AC)
      Refrigerator 120W (AC)
      Microwave 1300W (AC)
      Washer 500W (AC)
      50" TV 110W (AC)
      Hair Dryer 1600W (AC)
      Coffee Maker 1000W (AC)
      Electric Frying Pan 1200W (AC)
      Phone 11Wh (Type-C)
      Laptop 60Wh (Type-C)
      Camera 16Wh (USB)
      Drone 40Wh (Type-C)
      Speaker 10W (AC)
      Blender 500W (AC)
      Car Fridge 60W (DC)
      Projector 65W (AC)
      PS5 200W (AC)
      Circular Saw 1400W (AC)
      Air Conditioner 1800W (AC)
      Electric Hammer 1260W (AC)
      Electric Drill 1080W (AC)
      Cutting Machine 1100W (AC)
      Electric Oven 1650W (AC)
      Electric Grill 1150W (AC)
      Air fryer 1500W (AC)
      Solar charging
      Harness the power of the sun by connecting DELTA to three 160W solar panels to fully charge in just 3.5-7 hours. Alternatively, you can connect DELTA to four 110W solar panels to fully charge in 4-8 hours.
      Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam
      What’s in the Bundle
      1. EcoFlow DELTA 2. DELTA Bag 3.Solar Panel Charging Cable 4. 1.5m AC Charging Cable 5. 1.5m Car Charging Cable 6. User Manual of DELTA 7. 110W Solar Panel 8. 110W Solar Panel Bag 9. User Manual of 110W Solar Panel
      Compare The Models
      DELTA
      Capacity:1260Wh
      Life Cycles: 800+ Cycle
      Output: 1800W (Surge 3300W)
      AC Input: 1200W Max
      Solar Input: 400W
      $1399
      RIVER Pro
      Capacity:720Wh
      Output: 600W (Surge 1200W)
      AC Input: 660W Max
      Solar Input: 200W
      $649
      RIVER Max
      Capacity:576Wh
      Life Cycles: 500+ Cycle
      AC Input: 500W Max
      Solar Input: 200W
      $599
      DELTA can be recharged to 0%~80% in 1 hour, and be fully recharged within 1.6 hours.
      Under perfect sunlight conditions, DELTA can be fully charged with the following solar panel setups: 1x 110W solar panel: 16h-32h 2x 110W solar panel (in series): 7.5h-15h 3x 110W solar panel (in series): 5h-10h 4x 110W solar panel: 4-8hrs
      Yes. During this situation, DELTA will prioritise AC charging, and default to DC charging when AC charging is not used.
      It can be an emergency power source (EPS), which will have the same result as UPS for most electronics. Here's the difference. When your DELTA is plugged into the wall, anything plugged into it gets power from the grid, not its battery. If power from the grid stops, DELTA automatically switches to its battery supply mode within 30 milliseconds. That means anything connected will not have power for 30 milliseconds, which may mean sensitive electronics like desktop computers and data servers turn off. Test your devices individually to see if they need UPS to stay powered.
      DELTA can power essential devices whether you’re at home or outdoors. Devices include lights, microwave ovens, fridges, hairdyers, laptops, phones, electric frying pans, and more.
      Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
      Yes, if the only thing between it and the sun is transparent, but it won’t charge as well compared to being outside. You can compare the difference by looking at the input section of your power station’s LCD screen.
      Specs of DELTA (1300)
      30.9lbs (14kg)
      Dimension
      15.7 x 8.3 x 10.6 in (40 x 21 x 27 cm)
      Charge Temperature
      32 to 113°F (0 to 45°C)
      Discharge Temperature
      -4 to 113°F (-20 to 45°C)
      Color
      Gray & black
      24 months
      Charge Method
      AC Wall Outlet, 12V Car Adaptor, Solar Panel
      Full Recharge Time
      1.6 Hours (AC) 13.5 Hours (12/24V Car Adaptor) 4-8 Hours (Using 4x 110W Solar Panels in parallel) 3.5-7 Hours (Using 3x 160W Solar Panels) 4-8 Hours (Using 1x400W Solar Panel)
      1260Wh (50.4V)
      Cell Chemistry
      Lithium-ion
      Shelf Life
      1 year (after fully charged)
      Life Span
      800 Cycles to 80%+ capacity
      Management Systems
      BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection.
      Testing and certification
      UL CE FCC RoHS PSE
      Cell Type
      18650
      AC Charge Input Power
      X-Stream charge (1200W max)
      AC Charge Input Voltage
      100-120Vac (50Hz/60Hz)
      Solar Charge Input
      400W 10-65V DC 10A max
      Car Charger
      12V/24V DC 8A max
      AC Output (x6)
      1800W total (Surge 3300W), 120Vac (60Hz)
      USB-A Output (x2)
      5V DC, 2.4A, 12W Max, per port
      USB-A Fast Charge (x2)
      5V/2.4A,9V/2A,12V/1.5A 18W Max
      USB-C Output (x2)
      5V DC, 9V DC, 15V DC, 20V DC, 3A, 60W Max, per port
      Car Power Output (x1)
      108.8W, 13.6V DC, 8A max
      Specs of DELTA (1000)
      30.9lbs (14kg)
      Dimension
      Charge Temperature
      Color
      Gray & black
      24 months
      Charge Method
      Full Recharge Time
      1.6 Hours (AC) 10.5 Hours (12/24V Car Adaptor) 2.6-5.3 Hours (Using 3x 160W Solar Panels) 3.2-6.3 Hours (Using 1x 400W Solar Panel)
      1008Wh
      Cell Chemistry
      NCM
      Shelf Life
      Life Span
      500 cycles to 80+% capacity
      Management Systems
      UL CE FCC RoHS PSE
      Cell Type
      18650
      X-Stream charge (1000W max)
      Solar Charge Input
      Car Charger
      12V/24V DC 8A max
      AC Output (x6)
      1600W total (Surge 3100W), 120Vac (60Hz)
      USB-A Output (x2)
      USB-C Output (x2)
      Specs of 110W Solar Panel
      Weight
      13.2 lb (Solar Panel 8.8 lb)
      Unfolded Dimensions
      62.5 × 20.2 × 1.0 in (158 × 51.4 × 2.4 cm)
      Folded Dimensions
      16.5 × 20.2 × 1.0 in (42 × 51.4 × 2.4 cm)
      12 months
      Rated Power
      110W (±5W)
      Efficiency
      21%–22%
      Connector Type
      Solar Connector
      Open Circuit Voltage
      21.7V (Vmp 18.5V)
      Short Circuit Current
      6.3A (Imp 6.0A)
      Cell Type
      Monocrystalline Silicon
      Operating & Storage Temperature
      −4°F to 185°F
