Smart Home Panel 10 (240V/120V) Smart Home Panel 10 (240V/120V) Smart Home Panel 10 (240V/120V) Smart Home Panel 10 (240V/120V) Smart Home Panel 10 (240V/120V)
Ends in
Days
10 Curcuits
<20 ms* Auto Switchover
5-Year Warranty
Pre-order: Smart Home Panel 10 is expected to ship by the end of November.
· Intelligent subpanel for TITAN home battery systems.
· Precisely monitor and control 10 circuits in the EcoFlow app. · Save more every day by working with the grid and your existing solar system. · A smarter system with OASIS 3.0 helps you plan and manage. · EcoFlow’s easiest-to-install Smart Home Panel to date NOTICE: ⚠ AC coupling with existing rooftop solar requires the Smart Home Panel 10 (SHP10 240V)
Learn more
Exclusive Benefits
Selection Summary
Smart Home Panel 10 (120V)
$1,599 CAD $1,999
$1,599 CAD $1,999 -$400
Intelligent Subpanel for TITAN
Automatic Backup and Save More Every Day
Use the left and right arrow keys to scroll through the cards.
10-Circuit Automatic Backup
Work with the Grid to Save More Every Day
Smarter System and Bigger Savings with AI Mode
Precise Control of 10 Circuits and Seamless Backup
Connect up to 10 selected circuits to TITAN + Smart Home Panel 10 for backup power*.
Check each connected circuit’s power use and turn it on or off in the EcoFlow app.
Precise Control of 10 Circuits and Seamless BackupPrecise Control of 10 Circuits and Seamless Backup
*Not compatible with GFCI/AFCI breakers
Work with the Grid, Save More
While the grid is on, the TITAN + Smart Home Panel 10 system can use stored energy to support not only the selected circuits connected to Smart Home Panel 10, but also the household demand beyond the backup circuits by AC Coupling*, which means greater savings in everyday use.
Built-in CT sensing measures total home energy use to help the system manage that power and make sure the energy flows within your home only.
* AC coupling is only available on the 240V Smart Home Panel 10.
Fully Compatible with Existing Rooftop Solar or Even a Home Battery System
You don't have to rip out what you already paid for. Just keep your system. Both TITAN and Smart Home Panel 10 are fully compatible with it.
As Battery Storage with an Existing Solar System
Add More Battery Storage with an Existing Solar System
Store surplus energy from your existing solar panels for use after sunset. Smart Home Panel 10 paired with TITAN works with your compatible inverter and adds backup for selected circuits.
Need more stored energy? Add a compatible TITAN + Smart Home Panel 10 system alongside your existing home battery, with additional storage and backup for selected circuits.
* Compatibility with third-party rooftop solar is only available on the 240V Smart Home Panel 10.
Use More of Your Solar. Aviod Peak Pricing
With solar, TITAN paired with Smart Home Panel 10 can store surplus solar for later. Use stored solar or electricity charged at lower off-peak rates to reduce grid purchases when rates rise.
Use More of Your Solar. Aviod Peak PricingUse More of Your Solar. Aviod Peak Pricing
* Estimated annual energy-cost savings are based on a 15kWh TITAN 5000 Plus system paired with 240V Smart Home Panel 10, 8kW solar, approximately 16.5kWh of daily household electricity use, optimized solar self-consumption, and SDG&E TOU-DR2 rates in San Diego, CA. Payback uses the same estimated annual savings for both compared systems. Actual savings and payback vary by home, solar production, rate plan, and system use. Estimated payback is based on system prices at launch and may vary with subsequent changes in prices or offers.
Automatically Ready Before the Storm. In Control Through the Outage.
Prepare for storms, switch to backup automatically, and prioritize the circuits you rely on—all with your TITAN + Smart Home Panel 10 system.
Get Alerts Before the Storm
Backup in Under 20 ms*
Make Backup Last Longer
Turn on Storm Mode to get alerts and automatically charge TITAN before severe weather arrives.
* System switchover under 20 ms based on TITAN + Smart Home Panel 10 system testing. Actual performance varies with wiring, load type, installation environment, and system settings.
Switch from grid to battery in under 20 ms to keep your essentials running.
Keep essentials running longer by reducing power to non-essential circuits.
More Built In. Less Installation Work.
With 10 circuit breakers, built-in CT sensing, and factory-prewired connections, Smart Home Panel 10 reduces the components and wiring work needed on site.
Plug In TITAN. Power Your Home’s EssentialsPlug In TITAN. Power Your Home’s Essentials
Once Smart Home Panel 10 is installed, simply plug in TITAN with the dedicated cable to back up your selected circuits.
What makes Smart Home Panel 10 different?What makes SHP10 different?
Choose the Right Smart Home Panel 10 & TITAN Version That Fits You
EcoFlow TITAN 5000 Classic + 120V Smart Home Panel 10
Essential 120V Backup
Keep essential 120V circuits powered during an outage
EcoFlow TITAN 5000 + 240V Smart Home Panel 10
Home Backup and Everyday Savings
Back up selected 120V/240V circuits and store surplus energy from compatible rooftop solar to reduce grid purchases.
EcoFlow TITAN 5000 Plus + 240V Smart Home Panel 10
More Solar. More Power for Your Home
Connect up to 8 kW of solar input. Power more of your selected loads with up to 10 kW output when solar and battery work together.*
Output
4kW
Output
7.2kW
Output
7.2kW battery only;up to 10kW with PV + battery*
Voltage
120V single-phase
Voltage
120V/240V split-phase
Voltage
PV Input
3.2kW
PV Input
4kW
PV Input
8kW
Selected Backup Circuits
Up to 10
Up to 10
Up to 10
Whole-Home Energy Monitoring
Yes
Yes
Yes
AC Coupling / Works with the Grid
No
Yes
Yes
System Capacity
5–30kWh
System Capacity
5–30kWh
System Capacity
5–30kWh
EcoFlow Smart Home Panel 10 (120V)
EcoFlow Smart Home Panel 10 (120V) (×1)
Mark-off template (×1)
Warranty card (×1)
Warranty card (×1)
EcoFlow Smart Home Panel 10 (240V)
EcoFlow Smart Home Panel 10 (240V) (×1)
CT Clamp (×2)
CT Clamp (×2)
Warranty card (×1)
Warranty card (×1)
Tech Specs
9.4 ± 0.2 kg
10.2 ± 0.2 kg
Number of Load Branches
10
10
360 × 515 × 102 mm (14.2 × 20.3 × 4.0 in.)
Enclosure Protection
IP20
IP20
Maximum Continuous Input Current (A)
44 A
44 A
Rated Input Voltage (V)
120 V AC, 60 Hz
208/240 V AC, 60 Hz
Overvoltage Category
IV
IV
Ecosystem Compatibility
TITAN 5000 Classic
TITAN 5000 / TITAN 5000 Plus
Switchover Time
≤20 ms
Switchover Time
≤20 ms
Intelligent Management
EcoFlow OASIS 3.0
EcoFlow OASIS 3.0
AC Coupling / Work with grid
No
Yes
Communication Method
2.4 GHz Wi-Fi / Bluetooth
Subcircuit power detection accuracy
3%
3%
Main circuit power detection accuracy
Not applicable
Not applicable
EMC
Class B
EMC
Class B
5 years
5 years
Certificates
UL 67; UL 1741; UL 3141; CSA C22.2 No. 107.1; CSA C22.2 No. 29
Certificates
Noise Emission
≤40 dB
Noise Emission
≤40 dB
Branch Circuit Rated Current
24 A (1P) × 1; 16 A (1P) × 1; 12 A (1P) × 8
24 A (2P) × 1; 16 A (2P) × 1; 16 A (1P) × 2; 12 A (1P) × 4
Maximum Operating Altitude
<3,000 m (9,842.52 ft)
Storage Temperature Range
−30°C to 70°C (−22°F to 158°F)
Operating Temperature Range
−10°C to 45°C (14°F to 113°F)
* Up to 10kW output on TITAN 5000 Plus requires compatible PV input working together with the battery. Battery-only output is up to 7.2kW.
Thanks for sharing!
Select your language
