EcoFlow PowerInsight Home Energy Monitor
$499.00 CAD
Regular price $499.00 CAD
Sale price $499.00 CAD Regular price $549.00
-$50
· 10-Inch Touchscreen: clear visuals and intuitive control.
· Energy Data Tracking: view your home energy data in real-time, by day, month, and year.
· Home Device Control: control your home appliances with Smart Plugs & Matter.
· Temperature Auto-Adjustment: Auto-adjust the temperature to a more appropriate level with a built-in sensor.
$5,899 CAD $8,598 CAD
6-90kwh Capacity
7.2-21.6kW Output
EcoFlow DELTA Pro 3 Portable Power Station-Recommend
$3,799 CAD $4,499 CAD
EcoFlow Smart Home Panel 2-Recommend
$2,099 CAD $2,699 CAD
$499 CAD $549 -$50
The all-in-one home energy monitor
Data monitoring
Discover your home's eco-friendly potential
Curious about your home's eco-friendliness? You'll find all the answers here!
Solar power generation
Home energy consumption and sources
Remaining battery
PowerInsight is a comprehensive energy dashboard that lets you easily view your home energy data in real-time, by day, month, or even year.
Energy optimization
Always find a better way to save energy and money
Meet your smart energy optimizer and money saver!
EcoFlow PowerInsight optimizes energy use and saves costs by smartly leveraging battery/solar power, grid feeding, battery timing, and device usage alerts.
Smart device control
Control your devices and run a smart, connected home
Whether you want to turn off all your lights when you leave or crank up the heating before you get home, do it all at the touch of a button.
Using Matter support and smart plugs, control all the connected appliances around your home.
See what works with EcoFlow PowerInsight
Wi-Fi | Matter
*Supported appliances will be added in the future.
Third-party devices
- Smart Plugs: Shelly, Tapo
- Smart Meters: Shelly 3EM
- Thermostats: EcoBee, Google Nest
Matter
- Smart Lights
- Smart Plugs and Outlets
- Thermostats and Other Temperature Controllers
- More to come: Smart Locks, Contact Sensors
Temperature auto-adjustment
Stay comfortable while saving energy
With a built-in indoor temperature sensor, PowerInsight adjusts your home's climate so it's always just right. By constantly monitoring the air temp, you're lowering energy use and your bills.
Why choose EcoFlow PowerInsight?
Wall bracket
Wall bracket
Power Cable (USB-C to USB-C)
Screw (4×30mm) *4 & Anchor (Ø6×27mm)*4
Quick Start Guide & Warranty Card
Specifications
244.4mm*158.6mm*12.4mm (H*W*D)
Weight
Approx. 600g
Color
Black
Button
Power on/off
Size
10.1 inch
Type
IPS
Resolution
1280 x 800 pixels
Screen
10-point multi touch
CPU
MT8168
ROM
16GB
RAM
2GB
Battery
3000mAh
Charging
5V/2A charging, Pogo Pin charger
WLAN
802.11 a/b/g/n/ac 2.4GHz, 5GHz
Bluetooth
Bluetooth 5.0
Sensors
Temperature and Humidity Sensor
Ambient Light Sensor
Proximity Sensor
Where can I place my EcoFlow PowerInsight?
There are two ways to place it: on the wall or on flat surfaces. 1. On the Wall: You can fix the bracket to the wall, and then place PowerInsight onto the bracket. (The bracket and the fixing screws required for installation are included in the installation list.) 2. On Flat Surfaces: Place it on a stand holder (not included in the box) like a tablet.
Does it support expandable memory card?
How is it different from running the app on a tablet? Can I use a third-party tablet instead of PowerInsight?
Can one of the two Type-C ports of the bracket be used for output?
Do I need to keep it plugged in?
Does it support smart voice?
What EcoFlow products can it be used with?
What third-party products can it be used with?
Does it support the simultaneous use of multiple sets of PowerInsight?
Can I update firmware for connected products using PowerInsight?
Can I remotely control the power on and off of products using PowerInsight?
Are there any sensors built into it?
Does it support LAN connection and control?
What is Matter?
How to add Matter devices to the EcoFlow ecosystem?
Can I use EcoFlow app to scan the Matter QR code of EcoFlow Smart Plug to add this device?
What are the requirements for the mobile phone and the Wi-Fi connection to PowerInsight when adding Matter devices?
How many Matter devices can be added to one account?
Select your language
