TITAN Early-Bird Offers Are Here
Get TITAN Launch Updates & Exclusive Offers
Pay $50 = 5% TITAN Discount + FREE TRAIL 300 DC
60 Days Price Match
Enjoy a 5-Year Warranty
Up to 12 Months at 0% APR
Get the Highlights
Power Almost Everything. Start for Less.
Power Your Whole-Home Essentials, Even a 3-Ton AC
TITAN 5000 can power these everyday essentials together. Even without solar, 7.2kW keeps your critical loads running.
7.2kW Rated Output
5–30kWh Capacity
10 Circuits. One Smart Panel. Finer Control
EcoFlow Smart Home Panel 10 puts control in your app. Traditional setups require extra hardware—and extra cost.
Tech Breakthrough. Cost Breakthrough
50% Lower Upfront Cost. Smarter Choice.
TITAN combines EcoFlow’s disruptive technology with user-friendly design to significantly reduce costs across the entire product lifecycle compared with traditional solutions.
Top-Tier Savings, On Par with Any Mainstream Solution
Use More Solar. Buy Less Grid Power. Save More at Peak Rates.
Work With The Grid
Rooftop-grade Solar Input
Full Power. Lower Bills
Work With The Grid
Industry-Leading Intelligence
It Learns. It Plans. It Saves
Your Habits. Automatically OptimizedTomorrow's Sun, Already Planned.Lower Rates In. Bigger Savings Out.Every Circuit. Your Priority.
*Subscription feature in the EcoFlow app.
Learns Your Energy Habits
Learns your routines and automatically manages energy use.
Plans 3 Days Ahead
Forecasts solar production up to 3 days ahead and plans when to store and use energy.
Charge Off-Peak. Use On-Peak
Stores energy when rates are low. Uses it when rates rise.
10-Circuit Control
Direct backup power where it matters most.
Explore the EcoFlow TITAN Series
positioning
Flagship Model, Ultimate Home Power for Multi-day Backup and Greater Daily Savings
positioning
Essential Model, Reliable & Simple for Whole-Home Backup
positioning
Power Model, High-performance & Intelligence for Everyday Use
5–30kWh
5–30kWh
5–30kWh
Output
7.2kW
Output
4kW
Output
7.2kWPV Boost 10kW X-Boost 2.0 · 5kW/Line
Voltage
120V/240V
Voltage
120V
Voltage
120V/240V
Home Backup Integration
Yes with Smart Home Panel 10 (240V)
Yes with Smart Home Panel 10 (120V)
AC Outlets
2× 5-20R
1× L14-50R
AC Outlets
3× 5-20R
1× L14-30R
AC Outlets
3× 5-20R
1× TT-30R
USB Ports
1× USB-C
1× USB-A
USB Ports
1× USB-C
1× USB-A
USB Ports
Solar Input
4kW1 MPPT
Solar Input
3.2kW1 MPPT
Solar Input
8kW2× 4kW MPPT
Weight
119 lb (54kg)
Weight
110.2 lb (46.5kg)
Weight
121.3 lb (55kg)
Tech Specs
(W × H × D): 24.5 × 13.2 × 16.9 in (623 × 336 × 428 mm)
119.0 lb (54 kg)
5 years
Capacity (per unit)
5kWh (5,017.6Wh)
Expandable Capacity
Up to 30kWh (1 unit + 5 Extra Batteries)
Rated Output Voltage & Frequency
120V / 240V AC, 60Hz (split-phase)
Rated Output Power
7,200W
AC Outlets
3 × NEMA 5-20R, 1 × NEMA L14-30R
UPS Switchover
<20 ms with Smart Home Panel 10
USB-C
1 × 60W (5V/9V/12V/15V/20V⎓3A)
USB-A
1 × 18W (5V⎓3A, 9V⎓2A, 12V⎓1.5A)
Max. PV Input
4,000W total, 1 port (40–450V, 16A)
Max. AC Input
7,200W
Connectivity
Wi-Fi & Bluetooth 5.0
Intelligent Management
EcoFlow OASIS 3.0
Grid Connection
Supported with Smart Home Panel 10 (No Export)
Charging Temperature
32°F–113°F / 0°C–45°C
Discharging Temperature
14°F–113°F / -10°C–45°C
Operating Altitude
<9,842 ft (3,000 m)
IP Rating
IP20
(W × H × D):24.4 × 13.3 × 10.1 in (621 × 337 × 256 mm)
82.7 lb (37.5 kg)
5 years
LFP (LiFePO₄)
Capacity (per unit)
5kWh (5,017.6Wh)
Max. Units per System
5 (30kWh total)
Operating Altitude
<9,842 ft (3,000 m)
IP Rating
IP20
(W × H × D): 14.2 × 20.3 × 4.0 in (360 × 515 × 102 mm)
22.49 lb (10.2 kg)
Installation
Wall-Mounted
5 years
120V / 240V AC, 60 Hz (split-phase)
Switchover Time
≤20 ms
Supported Circuits
10
Connectivity
EcoFlow OASIS 3.0
CT Sensor
Built-In (for self-consumption and no-export control)
a. Traditional home storage has flaws that can't be fixed. Traditional home battery systems typically require a substantial upfront investment, and every expansion, relocation, or service visit can add another bill.
b. TITAN delivers home-battery-class performance. The TITAN Plus outputs 7,200–10,000W and accepts up to 8kW of solar input — enough to run most household appliances during an outage while maximizing everyday savings on your electricity bill.
c. DIY design cuts cost, time, and upkeep. Start from 5kWh and scale up to 30kWh as your needs grow — no over-buying on day one. Installation cost and time drop dramatically versus a fixed system, and because the system is modular and movable, maintenance, upgrades, and even moving house stay inexpensive. Paired with the SHP10 smart panel, TITAN delivers automatic whole-home backup without backfeeding the grid.
TITAN Series — the balanced pick for most homes. Each unit starts at 5 kWh and expands to 30 kWh, with output from 4 kW to 7.2 kW (up to 10 kW with solar on TITAN 5000 Plus). Paired with SHP10, it backs up the circuits that run a typical home. TITAN is also stronger on everyday savings: the TITAN 5000 Plus takes up to 8kW of solar input and works with the grid, so more of what your home uses comes off your own roof. So if you are looking for the perfect balance between cost-effectiveness and practicality, TITAN series is the ideal choice.
DELTA Pro Ultra stands out for its superior backup capabilities, offering higher single-unit capacity (6 kWh) and more smart circuits (12), and a much higher ceiling once you parallel units and stack batteries — 6 to 90 kWh of capacity and 7.2 to 21.6 kW of output. It's the better fit for homes with frequent outages or in higher-risk areas.
DELTA Pro Ultra X is our flagship home energy system, built to be the last one you buy — with 12-36 kW of output and 12-180 kWh of capacity — more than most mainstream home batteries on the market.
This approach lets you keep your existing panels and inverter while adding storage and energy management. You don't have to start by replacing your solar system. Your installer will confirm the appropriate connection setup.
It's a way to expand around the system you already own. Wanting more storage doesn't have to mean replacing your entire setup. The connection design will depend on your existing equipment and home configuration.
Through AC coupling, everyday energy management can serve your home beyond the selected circuits protected during an outage. That means the system can put your solar energy and lower-cost electricity to work even when the grid is running normally.
If your utility offers time-of-use rates, TITAN or TITAN Plus with the appropriate home connection setup can also charge during lower-cost hours and discharge during higher-cost hours to reduce peak-rate purchases. If you pay the same rate throughout the day, focus first on the backup protection it can provide.
With SHP10, you can connect up to 10 selected household circuits for automatic backup, helping keep essentials such as air conditioning, refrigeration, and lighting powered. TITAN Classic is designed for 120V essentials such as refrigerators, lights, and communications equipment. The appliances you run together need to stay within your model's operating and startup power capabilities.
Start with the backup you need today, then add stored energy as your household's needs change. Expansion batteries require the appropriate connection cables, sold separately. Adding batteries increases stored energy and runtime capacity; it does not change the main unit's rated output power.
Adding SHP10 connects TITAN to up to 10 selected household circuits for automatic backup and circuit management. TITAN and TITAN Plus can also use AC coupling for everyday home energy management. You can start by powering appliances directly or choose a setup that connects to your home's circuits.
You can hire your own qualified local installer and provide the relevant installation guide. TITAN's modular design and SHP10's prewired construction reduce the assembly work your electrician needs to complete on-site.
When TITAN is used on its own with appliances connected directly, its EPS function switches to battery power within 10ms of a utility power interruption. The standalone unit and the TITAN + SHP10 system have different transfer times.
A conventional rooftop solar system connected to the grid shuts down during an outage for anti-islanding protection, so it cannot continue charging TITAN through that existing connection. For solar recharging during an outage, use panels connected directly to TITAN's solar input.
Storm mode adds another layer of preparation. When enabled, it starts charging the battery to 100% ahead of a supported severe weather event detected by the system, helping you prepare for a possible outage.
TITAN main units carry UL 2743, UL 1973, and UL 9540 certifications; TITAN Battery 5kWh carries UL 1973 certification. The equipment is suitable for homes and garages that meet its placement requirements: a dry, ventilated indoor location within the specified temperature range.
These figures reflect the specified test load for each model. Actual sound levels vary with the load and cooling needs.
Footnote:
1. Cost Comparison
Upfront cost comparisons are based on the compared TITAN and Traditional Systems configurations and prices at launch in Canada. Actual costs and relative savings vary by configuration, home, and subsequent changes in prices or offers.
2. Savings & Payback
Estimated annual energy-cost savings are based on a modeled Toronto, Ontario scenario using a 15kWh TITAN 5000 Plus system paired with Smart Home Panel 10, 8kW solar, approximately 24.7kWh of daily household electricity use, optimized solar self-consumption, and Ontario Ultra-Low Overnight (ULO) electricity rates. The estimate excludes fixed charges, delivery charges, taxes, rebates, and solar export revenue. Actual savings vary by home, solar production, rate plan, and system use.
3. Automatic Switchover
Automatic switchover occurs within 20 ms. For devices sensitive to power interruptions, including medical equipment, check the device manufacturer’s backup power requirements and verify that the device operates properly during switchover before relying on the system for backup power.
4. Cell Heat
Up to 50% less heat under load is based on EcoFlow internal cell-level testing under comparable current conditions,actual results vary with operating conditions.
5. Whole-Home Power
“Whole-home power” refers to the ability to power household appliances within the selected system’s output and capacity limits. When paired with Smart Home Panel 10, automatic backup covers up to 10 selected household circuits. Actual appliance coverage and runtime vary by model, configuration, loads, and available energy.
6. Freedom to Move / Nearly $0
Applies to user removal of TITAN units and extra batteries. Excludes transportation and any electrical work required to remove or reinstall the Smart Home Panel or other hardwired components.
7. North America Highest Safety Standards
“Highest” refers to the highest applicable safety standards for residential energy storage systems in North America, encompassing UL 9540 complete-system certification and UL 9540A thermal runaway fire-propagation testing. Applies to certified system configurations.
8. Save up to $3,399 based on the combined value of applicable discounts and free gifts on select TITAN Series bundles. Actual savings vary by product configuration and applicable offers.
*Product performance data shown on this page are based on EcoFlow’s internal testing under specific test conditions. Actual performance may vary depending on system configuration, connected loads, usage patterns, environmental conditions, and battery condition.
