EcoFlow TITAN Plus Whole Home Battery Storage 5-30kWh EcoFlow TITAN Plus Whole Home Battery Storage 5-30kWh EcoFlow TITAN Plus Whole Home Battery Storage 5-30kWh EcoFlow TITAN Plus Whole Home Battery Storage 5-30kWh EcoFlow TITAN Plus Whole Home Battery Storage 5-30kWh EcoFlow TITAN Plus Whole Home Battery Storage 5-30kWh EcoFlow TITAN Plus Whole Home Battery Storage 5-30kWh
Last Chance for Early Bird
Launches & Ships Nov 3
Ends in
Days
7.2-10kW Output
5-30kWh Capacity
10 Years Years of Use
1. 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required.
2. 100% Whole-Home Savings. Save up to $1,100 per year.
3. Only 50% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle.
4. OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
5. North America Highest Safety Standards. UL 9540A tested and UL 9540 certified, with EV-grade LFP cells and 24/7 BMS monitoring.
NOTICE: ⚠️ AC coupling with an existing rooftop solar system requires the Smart Home Panel 10 (SHP10 240V) and a CT sensor.
Learn more
Coupon Holders Benefits
Get $3,049 OFF
Share&Win
Service & Benefits
$50 TITAN Coupon Holders
Log In to Claim Exclusive Benefits!
  • *for coupon purchased before Nov 3
Customer Service
+1(800)-368-8604
English & French Support
Mon-Fri 9am-7pm
Members' Benefits
1. Earn More, Save More: Get 1 EcoCredit per $1 spent – redeem 20 Credits for $1 off anytime, or exchange for exclusive gifts and discounts.
2. Join EcoCredits Monthly Madness: Unlock more EcoCredits fun! Available every 4th Thursday of the month.
3. Bonus Rewards: Earn extra EcoCredits when you refer friends – unlock cash bonuses and special perks.
4. Priority Support: Enjoy 24/7 assistance, extended warranty coverage, and seamless trade-in options.
5. VIP Access: Be the first to shop new products, attend members-only events, and get insider update. Sign up>>
5-Year Warranty
Selection Summary
TITAN 5000 Plus Whole-Home Backup Power
$5,299 CAD $6,499
$5,299 CAD $6,499 -$1,200
Save up to $3,049⁸
Subscribe and Get 5% Off
Get TITAN Launch Updates & Exclusive Offers
Get the Highlights
Power Almost Everything. Start for Less.
Power Your Whole-Home Essentials, Even a 3-Ton AC—and MorePower Your Whole-Home Essentials, Even a 3-Ton AC—and More
With up to 10kW output when paired with solar, TITAN 5000 Plus can power these everyday essentials together. Even without solar, 7.2kW keeps your critical loads running.
7.2–10kW Rated Output
5–30kWh Capacity
Powered by
Same 7.2kW. More Power Where You Need It
VS. Portable Power Station
VS. Traditional Home Batteries
3 Ways TITAN Powers Beyond Limits
5–30kWh Battery Capacity
8kW Solar Input
99% Generator Compatibility
8kW Solar Input
8kW Solar Input
10 Circuits. One Smart Panel. Finer Control
EcoFlow Smart Home Panel 10 puts control in your app. Traditional setups require extra hardware—and extra cost.
10 Circuits. One Smart Panel. Finer Control10 Circuits. One Smart Panel. Finer Control
Tech Breakthrough. Cost Breakthrough.
50% Lower Upfront Cost. Smarter Choice.
TITAN combines EcoFlow’s disruptive technology with user-friendly design to significantly reduce costs across the entire product lifecycle compared with traditional solutions.
Powered by
Top-Tier Savings, On Par with Any Mainstream Solution
Use More Solar. Buy Less Grid Power. Save More at Peak Rates.
Work With The Grid
Rooftop-grade Solar Input
Full Power. Lower Bills
Work With The Grid
Already Have Solar?
Keep the solar system that’s already working
With the TITAN Series AC coupling solution, TITAN works seamlessly with compatible existing rooftop solar, so you can upgrade your energy system without replacing what already works and maximize your solar savings.
Industry-Leading Intelligence
It Learns. It Plans. It Saves
Your Habits. Automatically OptimizedTomorrow's Sun, Already PlannedLower Rates In. Bigger Savings OutEvery Circuit. Your Priority
*Subscription feature in the EcoFlow app.
Learns Your Energy Habits
Learns your routines and automatically manages energy use.
Plans 3 Days Ahead
Forecasts solar production up to 3 days ahead and plans when to store and use energy.
Charge Off-Peak. Use On-Peak
Stores energy when rates are low. Uses it when rates rise.
10-Circuit Control
Direct backup power where it matters most.
Storm Backup That Thinks Ahead
Prepare early. Switch instantly. Keep essentials powered longer.
Get Alerts Before the Storm
Backup in Under 20ms³
Make Backup Last Longer
Turn on Storm Mode to get alerts and automatically charge TITAN before severe weather arrives.
Switch from grid to battery in under 20ms to keep your essentials running.
Keep essentials running longer by reducing power to non-essential circuits.
North America Highest Safety Standards⁷
Tested for fire risks and electrical safety. Built for peace of mind at home.
LFP and larger cells work together for better fire safety, more balanced charging, and fewer potential points of failure.
More power reaches your home. Less is lost as heat.
Explore the EcoFlow TITAN Series
TITAN 5000 Plus
Advanced
TITAN 5000 Plus
From $5,299
TITAN 5000
Standard
TITAN 5000
From $4,199
TITAN 5000 Classic
Basic
TITAN 5000 Classic
From $3,299
positioning
Flagship Model, Ultimate Home Power for Multi-day Backup and Greater Daily Savings
positioning
Power Model, High-performance & Intelligence for Everyday Use
positioning
Essential Model, Reliable & Simple for Whole-Home Backup
5–30kWh
5–30kWh
5–30kWh
Output
7.2kW PV Boost 10kW X-Boost 2.0 · 5kW/Line
Output
7.2kW
Output
4kW
Phase configuration
120V/240V Split-Phase
Phase configuration
Phase configuration
120V Single-Phase
Home Integration
with Smart Home Panel 10 (240V)
Home Integration
Home Integration
with Smart Home Panel 10 (120V)
AC Outlets
2× 5-20R
1× L14-50R
AC Outlets
3× 5-20R
1× L14-30R
AC Outlets
3× 5-20R
1× TT-30R
USB Ports
USB Ports
1× USB-C
1× USB-A
USB Ports
1× USB-C
1× USB-A
PV Input
8kW
2× 4kW MPPT
PV Input
4kW
1 MPPT
PV Input
3.2kW
1 MPPT
Weight
121.3 lb (55kg)
Weight
119 lb (54kg)
Weight
110.2 lb (46.5kg)
EcoFlow TITAN 5000 Plus ×1
EcoFlow Solar to HP500 Charging Cable ×1
EcoFlow AC Charging Cable-C20 ×1
Quick Start Guide ×1
Tech Specs
(W × H × D): 24.5 × 13.2 × 16.9 in (623 × 336 × 428 mm)
121.3 lb (55 kg)
5 years
Capacity (per unit)
5kWh (5,017.6Wh)
Expandable Capacity
Up to 30kWh (1 unit + 5 Extra Batteries)
Rated Output Voltage & Frequency
120V / 240V AC, 60Hz (split-phase)
Rated Output Power
7,200W. Up to 10,000W with solar (PV + AC combined)
AC Outlets
2 × NEMA 5-20R, 1 × NEMA L14-50R
UPS Switchover
<20 ms with Smart Home Panel 10
Max. PV Input
8,000W total, 2 ports (40–450V, 16A, 4,000W each)
Max. AC Input
7,660W (10,000W max. with solar)
Connectivity
Wi-Fi & Bluetooth 5.0
Intelligent Management
EcoFlow OASIS 3.0
Grid Connection
Supported with Smart Home Panel 10 (No Export)
Charging Temperature
32°F–113°F / 0°C–45°C
Discharging Temperature
14°F–113°F / -10°C–45°C
Operating Altitude
<9,842 ft (3,000 m)
IP Rating
IP20
(W × H × D):24.4 × 13.3 × 10.1 in (621 × 337 × 256 mm)
82.7 lb (37.5 kg)
5 years
LFP (LiFePO₄)
Capacity (per unit)
5kWh (5,017.6Wh)
Max. Units per System
5 (30kWh total)
Operating Altitude
<9,842 ft (3,000 m)
IP Rating
IP20
(W × H × D): 14.2 × 20.3 × 4.0 in (360 × 515 × 102 mm)
22.49 lb (10.2 kg)
Installation
Wall-Mounted
5 years
120V / 240V AC, 60 Hz (split-phase)
Switchover Time
≤20 ms
Supported Circuits
10
Connectivity
EcoFlow OASIS 3.0
CT Sensor
Built-In (for self-consumption and no-export control)
Operating Temperature
Storage Temperature
-22°F–158°F / -30°C–70°C
Operating Altitude
<9,842 ft (3,000 m)
IP Rating
IP20
The $50 TITAN Coupon gives you 5% off eligible TITAN Series products plus 1 FREE TRAIL 300 DC during the Launch Sales Period. The $50 Coupon is not a deposit and cannot be applied toward your TITAN purchase.
When purchasing eligible TITAN products, log in to or create an EcoFlow account using the same email address used for your Coupon purchase. Your Coupon benefits will be automatically applied to eligible products.
The 5% discount applies to TITAN Series standalone main units and eligible bundles that include a TITAN Series main unit. Standalone Add-on Batteries, Smart Home Panel 10, accessories, installation services, shipping, taxes, and other excluded items are not eligible.
Yes. One Coupon can be used for one order, and multiple eligible TITAN Series products in that order can all receive 5% off. Each qualifying order includes 1 FREE TRAIL 300 DC.
No. Multiple Coupons cannot be combined to increase the discount. For example, two Coupons cannot provide 10% off one order. If you purchase two Coupons and want two gifts, you must place two separate qualifying orders.
The TRAIL 300 DC will be automatically added to your qualifying order. You do not need to add it to your cart manually. Gift availability is limited and subject to the official Terms & Conditions.
First, make sure you are logged in with the same EcoFlow account associated with the email used for your Coupon purchase and that your order contains eligible TITAN products. If the benefit still does not appear, please contact EcoFlow Customer Support.
The $50 Coupon is non-refundable during the promotion period, except as provided in the official Terms & Conditions. If you do not complete an eligible TITAN purchase by December 31, 2026, at 11:59 PM PST, the $50 will be refunded to your original payment method after the promotion ends. If your eligible TITAN order is canceled or returned, the $50 will be refunded with the order, and the free TRAIL 300 DC must also be returned.
TITAN + SHP10 matches the performance of mainstream installed home batteries while eliminating their biggest drawbacks: high upfront cost and expensive long-term maintenance.
a. Traditional home storage has flaws that can't be fixed. Traditional home battery systems typically require a substantial upfront investment, and every expansion, relocation, or service visit can add another bill.
b. TITAN delivers home-battery-class performance. The TITAN Plus outputs 7,200–10,000W and accepts up to 8kW of solar input — enough to run most household appliances during an outage while maximizing everyday savings on your electricity bill.
c. DIY design cuts cost, time, and upkeep. Start from 5kWh and scale up to 30kWh as your needs grow — no over-buying on day one. Installation cost and time drop dramatically versus a fixed system, and because the system is modular and movable, maintenance, upgrades, and even moving house stay inexpensive. Paired with the SHP10 smart panel, TITAN delivers automatic whole-home backup without backfeeding the grid.
All three systems cover whole-home backup and everyday savings. They differ in scale — and in which one fits your home.
TITAN Series — the balanced pick for most homes. Each unit starts at 5 kWh and expands to 30 kWh, with output from 4 kW to 7.2 kW (up to 10 kW with solar on TITAN 5000 Plus). Paired with SHP10, it backs up the circuits that run a typical home. TITAN is also stronger on everyday savings: the TITAN 5000 Plus takes up to 8kW of solar input and works with the grid, so more of what your home uses comes off your own roof. So if you are looking for the perfect balance between cost-effectiveness and practicality, TITAN series is the ideal choice.
DELTA Pro Ultra stands out for its superior backup capabilities, offering higher single-unit capacity (6 kWh) and more smart circuits (12), and a much higher ceiling once you parallel units and stack batteries — 6 to 90 kWh of capacity and 7.2 to 21.6 kW of output. It's the better fit for homes with frequent outages or in higher-risk areas.
DELTA Pro Ultra X is our flagship home energy system, built to be the last one you buy — with 12-36 kW of output and 12-180 kWh of capacity — more than most mainstream home batteries on the market.
A whole house generator ensures that you and your family have energy security when a power outage strikes. With extreme weather events becoming more common and the aging power grid becoming increasingly unreliable, there has never been a better time to invest in a whole house generator. You can also save on your electricity bills over time — or even eliminate them completely with clean, renewable solar power.
Yes. Paired with SHP10, TITAN and TITAN Plus use AC coupling to work alongside compatible existing rooftop solar. They store daytime solar energy you aren't using right away, so you can use it in the evening or during peak hours.
This approach lets you keep your existing panels and inverter while adding storage and energy management. You don't have to start by replacing your solar system. Your installer will confirm the appropriate connection setup.
Yes. TITAN or TITAN Plus paired with SHP10 can work alongside a compatible existing home battery system through AC coupling, adding storage capacity and backup options while preserving your original investment.
It's a way to expand around the system you already own. Wanting more storage doesn't have to mean replacing your entire setup. The connection design will depend on your existing equipment and home configuration.
Paired with SHP10, TITAN and TITAN Plus can help in two ways: store surplus solar energy to reduce grid purchases later, and work with time-of-use rates by charging when electricity costs less and using stored energy when rates are higher.
Through AC coupling, everyday energy management can serve your home beyond the selected circuits protected during an outage. That means the system can put your solar energy and lower-cost electricity to work even when the grid is running normally.
Yes. You don't need solar to use TITAN. You can charge it from the grid and have energy ready for an outage, then add compatible solar panels that connect directly to the unit later if you choose.
If your utility offers time-of-use rates, TITAN or TITAN Plus with the appropriate home connection setup can also charge during lower-cost hours and discharge during higher-cost hours to reduce peak-rate purchases. If you pay the same rate throughout the day, focus first on the backup protection it can provide.
Yes. TITAN and TITAN Plus deliver 7.2kW of 120V/240V output and can directly start and run a compatible 3-ton central air conditioner without an added soft starter, provided its startup requirements are within the unit's capabilities. TITAN Plus delivers up to 10kW when battery and solar supply power together.
With SHP10, you can connect up to 10 selected household circuits for automatic backup, helping keep essentials such as air conditioning, refrigeration, and lighting powered. TITAN Classic is designed for 120V essentials such as refrigerators, lights, and communications equipment. The appliances you run together need to stay within your model's operating and startup power capabilities.
Yes. You don't have to buy all your capacity upfront. Each TITAN main unit includes a 5kWh battery and supports up to five TITAN Battery 5kWh expansion batteries, for a total capacity of 30kWh.
Start with the backup you need today, then add stored energy as your household's needs change. Expansion batteries require the appropriate connection cables, sold separately. Adding batteries increases stored energy and runtime capacity; it does not change the main unit's rated output power.
Yes. You can plug appliances directly into the appropriate outputs on the TITAN main unit.
Adding SHP10 connects TITAN to up to 10 selected household circuits for automatic backup and circuit management. TITAN and TITAN Plus can also use AC coupling for everyday home energy management. You can start by powering appliances directly or choose a setup that connects to your home's circuits.
More of the preparation is done before the system reaches your home. TITAN uses an all-in-one, floor-standing main unit, while SHP10 integrates circuit breakers, monitoring, and prewired connections. That reduces the parts your installer needs to source, the wiring they need to prepare, and the assembly they need to complete on-site.
If you're using TITAN on its own to power appliances directly, you can follow the product guide to set it up. Installing and wiring SHP10 into your home's electrical system requires a qualified, licensed electrician.
You can hire your own qualified local installer and provide the relevant installation guide. TITAN's modular design and SHP10's prewired construction reduce the assembly work your electrician needs to complete on-site.
Yes. With the system properly installed and the TITAN main unit powered on, TITAN + SHP10 switches automatically within 20ms of a grid outage to power the connected backup circuits. You don't need to find your way to the electrical panel in the dark to make the switch yourself.
When TITAN is used on its own with appliances connected directly, its EPS function switches to battery power within 10ms of a utility power interruption. The standalone unit and the TITAN + SHP10 system have different transfer times.
You can recharge with solar panels connected directly to TITAN, as long as they meet its input requirements. You can also use an EcoFlow or third-party generator with the included AC charging cable. That gives you ways to replenish energy during a longer outage, in addition to expanding your battery capacity.
A conventional rooftop solar system connected to the grid shuts down during an outage for anti-islanding protection, so it cannot continue charging TITAN through that existing connection. For solar recharging during an outage, use panels connected directly to TITAN's solar input.
No. With a system configuration that supports the relevant features, you can set your daily operating strategy and adjust your self-consumption level in the EcoFlow app. The system then manages solar, stored energy, and household demand according to your settings, without requiring you to control each charge or discharge cycle
Storm mode adds another layer of preparation. When enabled, it starts charging the battery to 100% ahead of a supported severe weather event detected by the system, helping you prepare for a possible outage.
TITAN uses lithium iron phosphate (LFP) cells, known for their thermal stability, along with a battery management system and multiple electrical protections to monitor and manage operation.
TITAN main units carry UL 2743, UL 1973, and UL 9540 certifications; TITAN Battery 5kWh carries UL 1973 certification. The equipment is suitable for homes and garages that meet its placement requirements: a dry, ventilated indoor location within the specified temperature range.
TITAN is designed with home use in mind. In testing at an ambient temperature of 77°F (25°C), measured from 3.3 feet (1 meter) away, TITAN Classic operates below 30dB at 2,000W output. TITAN operates below 39dB at 3,600W, and TITAN Plus operates below 39dB at 5,000W.
These figures reflect the specified test load for each model. Actual sound levels vary with the load and cooling needs.
TITAN main units, TITAN Battery 5kWh, and SHP10 each come with a 5-year warranty, providing long-term coverage for your power station, expansion batteries, and home connection equipment. Refer to the official warranty policy for your region for coverage details.
Footnote:
1. Cost Comparison
Upfront cost comparisons are based on the compared TITAN and Traditional Systems configurations and prices at launch in Canada. Actual costs and relative savings vary by configuration, home, and subsequent changes in prices or offers.
2. Annual Energy-Cost
SavingsEstimated annual energy-cost savings are based on a modeled Toronto, Ontario scenario using a 15kWh TITAN 5000 Plus system paired with Smart Home Panel 10, 8kW solar, approximately 24.7kWh of daily household electricity use, optimized solar self-consumption, and Ontario Ultra-Low Overnight (ULO) electricity rates. The estimate excludes fixed charges, delivery charges, taxes, rebates, and solar export revenue. Actual savings vary by home, solar production, rate plan, and system use.
3. Automatic Switchover
Automatic switchover occurs within 20 ms. For devices sensitive to power interruptions, including medical equipment, check the device manufacturer’s backup power requirements and verify that the device operates properly during switchover before relying on the system for backup power.
4. Cell Heat
Up to 50% less heat under load is based on EcoFlow internal cell-level testing under comparable current conditions.
5. Whole-Home Power
“Whole-home power” refers to the ability to power household appliances within the selected system’s output and capacity limits. When paired with Smart Home Panel 10, automatic backup covers up to 10 selected household circuits. Actual appliance coverage and runtime vary by model, configuration, loads, and available energy.
6. North America Highest Safety Standards
“Highest” refers to the highest applicable safety standards for residential energy storage systems in North America, encompassing UL 9540 complete-system certification and UL 9540A thermal runaway fire-propagation testing. Applies to certified system configurations.
7. Save up to $3,399 based on the combined value of applicable discounts and free gifts on select TITAN Series bundles.
Actual savings vary by product configuration and applicable offers.
*Product performance data shown on this page are based on EcoFlow’s internal testing under specific test conditions. Actual performance may vary depending on system configuration, connected loads, usage patterns, environmental conditions, and battery condition.
Thanks for sharing!
Select your language
