Get the Highlights
Power Almost Everything. Start for Less
TITAN Early-Bird Offers Are Here
Get TITAN Launch Updates & Exclusive Offers
Pay $50, Secure 5% OFF TITAN + Free TRAIL 300 DC
60 Days Price Match
Enjoy a 5-Year Warranty
Up to 12 Months at 0% APR
Power Your Whole-Home Essentials
Refrigerator + TV + Computer + Whole-Home Lighting + Wi-Fi. All at Once.Covers All 120V Essential Loads.
Start with 5kWh. Scale Up to 30kWh
From 1-Day to 1-Week Backup
Seamless Backup
Quieter Than a Whisper
Runs at 30 dB—so quiet, you may forget it’s running.
VS.Gas Generator
Other Portable Power Stations
Charging Ways
Noise
Switch over
MTS needed
Smart Control
Solar Input
TITAN 5000 Classic
Charging Ways
Gas Generator / EV Charger
Noise
Switch over
With SHP10
Smart Control
Solar Input
Scale to 30kWh
Gas Generator
Charging Ways
Noise
Switch over
Manual Setup
Smart Control
Solar Input
10-Circuit Smart Control. Works with Your Existing Solar
The new Smart Home Panel 10 integrates TITAN with your household circuits, giving you smart control over 10 dedicated circuits to keep your most critical appliances powered and managed.
Easier-to-Install Smart Home Panel 10
Reduce Installation Costs¹ and Time.
DIY-Friendly. Modular by Design.
Simple setup. Factory wiring. Plug-in connections.
Factory Pre-Wired SHP10
Pre-wired. No custom field wiring needed.
Industry-Leading Intelligence
It Learns. It Plans. It Saves
Your Habits. Automatically OptimizedTomorrow's Sun, Already PlannedLower Rates In. Bigger Savings OutEvery Circuit. Your Priority
*Subscription feature in the EcoFlow app.
Learns Your Energy Habits
Learns your routines and automatically manages energy use.
Plans 3 Days Ahead
Forecasts solar production up to 3 days ahead and plans when to store and use energy.
Charge Off-Peak. Use On-Peak
Stores energy when rates are low. Uses it when rates rise.
10-Circuit Control
Direct backup power where it matters most.
Backup Power That Pays for Itself
With up to 3200W of solar input and AI TOU Mode, TITAN 5000 Classic can help lower your electricity bills.
Up to $950
Saved Each Year
Explore the EcoFlow TITAN Series
positioning
Power Model, High-performance & Intelligence for Everyday Use
positioning
positioning
Flagship Model, Ultimate Home Power for Multi-day Backup and Greater Daily Savings
Positioning
120V/240V Home Battery More Power. More Saving
Positioning
120V/240V Home Backup
Positioning
Essential 120V Home Backup
5–30kWh
5–30kWh
5–30kWh
Output
7.2kWPV Boost 10kW X-Boost 2.0 · 5kW/Line
Output
7.2kW
Output
4kW
Voltage
120V/240V
Voltage
120V/240V
Voltage
120V
Home Backup Integration
Yes with Smart Home Panel 10 (120V)
Yes with Smart Home Panel 10 (240V)
AC Outlets
3× 5-20R
1× TT-30R
AC Outlets
2× 5-20R
1× L14-50R
AC Outlets
3× 5-20R
1× L14-30R
USB Ports
USB Ports
1× USB-C
1× USB-A
USB Ports
1× USB-C
1× USB-A
Solar Input
8kW
2× 4kW MPPT
Solar Input
4kW
1 MPPT
Solar Input
3.2kW
1 MPPT
Weight
121.3 lb (55kg)
Weight
119 lb (54kg)
Weight
110.2 lb (46.5kg)
Tech Specs
(W × H × D): 24.5 × 13.2 × 16.9 in (623 × 336 × 428 mm)
102.5 lb (46.5 kg)
5 years
Capacity (per unit)
5kWh (5,017.6Wh)
Expandable Capacity
Up to 30kWh (1 unit + 5 Extra Batteries)
Rated Output Voltage & Frequency
120V AC, 60Hz (single-phase)
Rated Output Power
4,000W
AC Outlets
3 × NEMA 5-20R, 1 × NEMA TT-30R
UPS Switchover
<20 ms with Smart Home Panel 10
USB-C
1 × 60W (5V/9V/12V/15V/20V⎓3A)
USB-A
1 × 18W (5V⎓3A, 9V⎓2A, 12V⎓1.5A)
Max. PV Input
3,000W total, 1 port (30–250V, 16A)
Max. AC Input
4,000W
Connectivity
Wi-Fi & Bluetooth 5.0
Intelligent Management
EcoFlow OASIS 3.0
Charging Temperature
32°F–113°F / 0°C–45°C
Discharging Temperature
14°F–113°F / -10°C–45°C
Operating Altitude
<9,842 ft (3,000 m)
IP Rating
IP20
(W × H × D):24.4 × 13.3 × 10.1 in (621 × 337 × 256 mm)
82.7 lb (37.5 kg)
5 years
LFP (LiFePO₄)
Capacity (per unit)
5kWh (5,017.6Wh)
Max. Units per System
5 (30kWh total)
Operating Altitude
<9,842 ft (3,000 m)
IP Rating
IP20
(W × H × D): 14.2 × 20.3 × 4.0 in (360 × 515 × 102 mm)
22.49 lb (10.2 kg)
Installation
Wall-Mounted
5 years
120V / 240V AC, 60 Hz (split-phase)
Switchover Time
≤20 ms
Supported Circuits
10
Connectivity
EcoFlow OASIS 3.0
CT Sensor
Built-In (for self-consumption and no-export control)
TITAN Series — the balanced pick for most homes. Each unit starts at 5 kWh and expands to 30 kWh, with output from 4 kW to 7.2 kW (up to 10 kW with solar on TITAN 5000 Plus). Paired with SHP10, it backs up the circuits that run a typical home. TITAN is also stronger on everyday savings: the TITAN 5000 Plus takes up to 8kW of solar input and works with the grid, so more of what your home uses comes off your own roof. So if you are looking for the perfect balance between cost-effectiveness and practicality, TITAN series is the ideal choice.
DELTA Pro Ultra stands out for its superior backup capabilities, offering higher single-unit capacity (6 kWh) and more smart circuits (12), and a much higher ceiling once you parallel units and stack batteries — 6 to 90 kWh of capacity and 7.2 to 21.6 kW of output. It's the better fit for homes with frequent outages or in higher-risk areas.
DELTA Pro Ultra X is our flagship home energy system, built to be the last one you buy — with 12-36 kW of output and 12-180 kWh of capacity — more than most mainstream home batteries on the market.
• TITAN: Keep your home comfortable and manage energy every day. It supports 120V/240V appliances, including compatible 3-ton central air conditioners, with 7.2kW output and up to 4kW solar input. Pair it with SHP10 for AC coupling.
• TITAN Plus: Get the fullest TITAN experience. Building on TITAN's capabilities, Plus offers up to 8kW of total solar input across two inputs, greater power capacity on a single 120V leg, and up to 10kW output when battery and solar work together. It's designed for households with more demanding appliances and greater solar energy needs.
If your utility offers time-of-use rates, TITAN with the appropriate home connection setup can also charge during lower-cost hours and discharge during higher-cost hours to reduce peak-rate purchases. If you pay the same rate throughout the day, focus first on the backup protection it can provide.
Start with the backup you need today, then add stored energy as your household's needs change. Expansion batteries require the appropriate connection cables, sold separately. Adding batteries increases stored energy and runtime capacity; it does not change the main unit's rated output power.
Adding SHP10 connects TITAN to up to 10 selected household circuits for automatic backup and circuit management. TITAN and TITAN Plus can also use AC coupling for everyday home energy management. You can start by powering appliances directly or choose a setup that connects to your home's circuits.
You can hire your own qualified local installer and provide the relevant installation guide. TITAN's modular design and SHP10's prewired construction reduce the assembly work your electrician needs to complete on-site.
When TITAN is used on its own with appliances connected directly, its EPS function switches to battery power within 10ms of a utility power interruption. The standalone unit and the TITAN + SHP10 system have different transfer times.
A conventional rooftop solar system connected to the grid shuts down during an outage for anti-islanding protection, so it cannot continue charging TITAN through that existing connection. For solar recharging during an outage, use panels connected directly to TITAN's solar input.
Storm mode adds another layer of preparation. When enabled, it starts charging the battery to 100% ahead of a supported severe weather event detected by the system, helping you prepare for a possible outage.
TITAN main units carry UL 2743, UL 1973, and UL 9540 certifications; TITAN Battery 5kWh carries UL 1973 certification. The equipment is suitable for homes and garages that meet its placement requirements: a dry, ventilated indoor location within the specified temperature range.
These figures reflect the specified test load for each model. Actual sound levels vary with the load and cooling needs.
