EcoFlow RAPID Power Bank (25K, 170W, 100W Built-In and Retractable Cab - Black / RAPID Pro Charger (140W | 4 Ports | GaN)
EcoFlow RAPID Power Bank (25K, 170W, 100W Built-In and Retractable Cables) + 140W Charger EcoFlow RAPID Power Bank (25K, 170W, 100W Built-In and Retractable Cables) + 140W Charger EcoFlow RAPID Power Bank (25K, 170W, 100W Built-In and Retractable Cables) + 140W Charger
$184.99 CAD
Free Shipping
Regular price $184.99 CAD
Sale price $184.99 CAD Regular price $339.98
-$154.99
1. 170W Fast Charge: Simultaneous two-port output up to 170W, supports charging up to four devices at the same time. 100W max for single-port charging.
2. 100W Max Input Power: The power bank can be recharged up to 50% in 26 minutes.
3. 25,000mAh Capacity, Air-Travel-Friendly*: Can fully charge a MacBook, meeting remote work needs for 1-2 days. Can charge your phone 4-5 times, eliminating battery anxiety.
4. Multi-Device Power Bank: 2× USB-C ports, 1× 67cm retractable USB-C cable, 1× 26cm lanyard Type-C cable
5. Smart TFT Screen, Clear and Dynamic Display
* Airline regulations vary by region and carrier. Please confirm battery restrictions with your airline before travel.
RAPID Power Bank (25,000mAh, 170W, 100W Built-In and Retractable Cables)
RAPID Pro Charger
$184.99 CAD $339.98 -$154.99
Subscribe to get 5% off and updates of RAPID
Multi-Functional Fast Charging for Everyday Convenience
Premium Fast Charging
Fast Recharging
Multi-Function Power
Premium and Compact Design
Charging with EcoFlow X-Stream Tech
When devices need power, it gets a maximum 100W boost through the USB-C port. With smart distribution, it can deliver power across your laptop, phone, tablet, and earbuds—four devices all at the same time.
100W Recharge in a Flash
Low on power before your commute or flight? This power bank recharges up to 50% in just 26 minutes—perfect for two full phone charges or a quick laptop top-up to last the day.
With 100W USB-C port or cable input:
- Recharge from 0% to 80% capacity (20,000mAh) in 53 minutes
- Recharge from 0% to 100% capacity (25,000mAh) in 80 minutes
Built-in Design, Ready When You Are
No more lost cables—the 100W built-in USB-C retractable and lanyard cables are always there, tucked neatly into the power bank's sleek design, with a retractable mechanism that lets you access power in seconds.
Massive 25,000mAh Capacity in a Compact Size
90Wh air-travel-friendly*, while high-density cells maximise capacity in a travel-ready design.
- Charge a MacBook Pro 1 time, extending battery life by 24 hours
- Charge an iPhone 16 4.6 times, extending battery life by 115 hours
- Charge a Steam Deck 1.75 times, extending battery life by 10 hours
Superior Safety
Smart Screen Display
Universal Compatibility
Advanced Protection, Maximum Performance
Protected by EcoFlow's X-Guard
Features pro-grade battery technology found in electric car batteries. EcoFlow RAPID's Battery Management System continuously monitors the charging process with quadruple protection to prevent overcharging, over-discharging, overheating, and short circuiting, ensuring safe and stable operation.
Smart TFT Screen with a Dynamic Display
Enhance your charging experience with an intelligent power display. You can view your real-time capacity, port power, battery health, temperature, charging cycles,emojis, and more. The crystal-clear TFT display screen lets you check your data at any angle, in any lighting condition.
Compatible with 99% of Daily-use Electronic Devices
Fits in anywhere you go.
Remote Work
Travel
Office Work
Remote Work
Remote Work
Remote Work
Remote Work
Travel
Travel
Travel
Travel
Office Work
Office Work
Office Work
Office Work
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Single-Port
Two-Port
Three-Port
Four-Port
Learn More About EcoFlow
Specs - EcoFlow RAPID Power Bank (25,000mAh, 170W, 100W Built-In and Retractable Cables)
25000mAh(90Wh)
≈580g
157*53.8*48.8mm (±0.5mm)
(Retractable Cable: 67cm)
(Lanyard Cable: 26cm)
Total Output
170W
Outlets
4
Single Output
C1(Cable1)/C2(Cable2)/C3: 100WA: 18W
APP
No
Input
100W
Screen Display
TFT
Wich devices are compatible?
Compatible devices are laptops, phones, tablets, headphones, smartwatches, game consoles and other devices with USB-C ports such as MacBook Pro/Air, iPhone,iPad, Dell XPS and Samsung Galaxy.
BC1.2/Apple2.4A/QC3.0/FCP/SCP/AFC/UFCS/PD3.0/PPS
How to keep the power bank charging and discharging quickly?
To ensure fast and stable charging and discharging performance when using the power bank, we recommend the following.
1. Choose the Right Charger:
Use a charger that supports fast charging protocols and has a high output power (such as PD 65W or 100W). Avoid using low-power chargers (such as 5V/1A).
2. Use a Good Charging Cable:
Select original or high-quality fast charging cables. Keep connectors clean and secure, and avoid excessively long cables.
3. Device Compatibility:
Make sure the connected devices support fast charging protocols; otherwise, fast charging will not be achieved.
Battery life and temperature FAQs
The power bank retains over 80% of its battery capacity after 300 charge cycles. It supports charging and discharging at altitudes below 3000 meters and in environments with temperatures between 0°C and 40°C. If not used for an extended period, it is recommended to store the power bank in an environment between -20°C and 40°C and to recharge it at least once every three months.
Can the RAPID Pro power bank be taken on the plane?
Yes, according to regulations by the International Civil Aviation Organization (ICAO) and most airlines, carrying a power bank with a capacity under 100Wh is allowed. The RAPID Pro, with a capacity of 25000mAh (90Wh), meets this requirement and can be carried on board without concern.
Why is there a difference rated capacity and nominal capacity?
Nominal capacity refers to the total capacity of the battery cells inside the power bank, while rated capacity refers to the actual amount of power the power bank can deliver under standard output conditions (such as 5V/3A). Nominal capacity is a theoretical value, whereas rated capacity accounts for energy conversion efficiency, circuit losses, and other factors, and is therefore lower than the nominal capacity.
Does it support multi-port charging and discharging at the same time?
Yes. When charging through the USB-C port, output is supported from another USB-C port or one USB-C + USB-A port simultaneously, but not from two USB-C ports simultaneously.
Campaign Period Period
EcoFlow RAPID Power Bank officially launches on August 25, 2025. The EcoFlow RAPID Power Bank Series Launch Campaign (hereinafter referred to as "campaign period") runs from August 25, 2025, 12:00 AM (PDT) to September 7, 2025, 11:59 PM (PDT).
Eligibility of Participants
This promotion is available to all Canada residents with a valid shipping address in continental Canada (Offers are not valid in Northwest Territories, Nunavut, or Yukon.) who are 18 years or older as of August 25, 2025 (hereinafter referred to as "Participants").
Launch Benefits
Benefit 1: Double EcoCredits+ Free Gift in Purchase
  • For orders with a pre-tax subtotal of $79.99 or more:
Receive one (1) free EcoFlow RAPID 20W GaN Charger with 60W Cable(MSRP: $24.99 CAD).
Limit one charger per order.
  • For orders with a pre-tax subtotal of $149.99 or more:
Receive one (1) free EcoFlow RAPID 65W GaN Charger with 100W Cable(MSRP: $69.00 CAD).
D.For canceled/returned orders: all double EcoCredits will be fully reversed, and for orders over $79.99, the undamaged charger must be returned with the product; partial refunds (including price adjustments) will proportionally deduct EcoCredits, with failure to return the charger resulting in its value being deducted from the refund amount.
Benefit 2: Get More for Less
A. 5-10 units purchased: 7% discount for all units; 11-20 units purchased: 9% discount for all units;10+ units purchased: 10% discount for all units. The discount applies automatically at checkout.
B. Only valid for the same product in the same order on our official EcoFlow website (ca.ecoflow.com). Cannot be combined with other promotions.
C. This discount can't be stacked with other coupons.
D. If you request a partial return, the applicable discount will be recalculated based on the remaining quantity. And the refund amount will be adjusted accordingly.
E.If a product purchased through a referral link is returned or exchanged, it will follow the standard return and exchange procedures as outlined in the EcoFlow Return and Refund Policy.
F. The referrer's unique referral link may not be shared, sold, or used in any way except by the referrer alone to obtain qualified referrals; referrers are limited to one qualified referral for each referred customer; in other words, additional/repeat purchases made by a referred customer are not counted as additional qualified referrals. Referral links shared to or obtained through other sources (such as through a posting to a third-party intermediary or website) will not be honored.
G. If the referrer and referee share an IP/device, only the referred person may receive a reward. EcoFlow may prohibit a referrer from participating in the program or receiving a credit or reward, at EcoFlow's sole discretion, if EcoFlow determines that such referrer is attempting to undermine the fairness, integrity, or legitimate operation of the program in any way by cheating, hacking, deception, or any other unfair playing practices or intending to annoy, abuse, threaten, or harass any other referrers or any representatives of EcoFlow.
H.For other questions regarding the referral program, please refer to:https://www.ecoflow.com/ca/referral
Coupon Terms
C. Coupons are valid only for customers in Canada and may only be used on ca.ecoflow.com.
General Terms
B. Delivery service is unavailable for orders shipped to Northwest Territories, Nunavut, or Yukon. Please refer to our shipping policyfor more details.
E. During the promotion, all orders must comply with EcoFlow's purchase agreement and return policy.
This promotion is not available for wholesale or distributor orders.
Thanks for sharing!
Select your language
